For anyone that has a foamlance/foam cannon heres a service
now this was taken from another forum.
how to disassemble/Assemble your H/D foam lance if its blocked or down in performance and may need cleaning! Thats if you are up to it.
It only takes a tiny piece of dirt/grit to block the lance and it will need a clean out for the limescale and soap build-up in the gauze in the end of the lance.
Ok here goes!
if you soak the guaze in vinegar over night this will clean it.
most of the time it will just be the guaze at fault if foam is not thick.
The lance
Step 1 Take off Karcher connector (unscrew) (this will have either threadlock or PTFE tape)
Step 2 Unscrew the Stainless Steel threaded bar (this will have either threadlock or PTFE tape)
Step 3 There you can see the injector that uncrews out via a flat screwdriver,unscrew it and it comes out,check that there is no grit in the hole in the injector.
Step 4 Unscrew with a flat screwdriver may need some wd40
Step 5 Now its time to remove the plastic body,get a small screwdriver and push the metal peg through.
You should now be left with this
Step 6 Prise the plastic/metal fan blades off with a flat screw drive
Step 7 In a vice unscrew the foam end body (use a suitable spanner or adjustable spanner)
You are now left with this
Step 8 Get a small screwdriver and insert in the small brass connector to reveal the metal gauze,if your lance is suffering from lack of foam this part will likely to be blocked with soap scum etc,a good soaking in a metal cleaner should do the trick
Step 9 Unscrew the black knob adjuster with a philips screwdriver
Step 10 Remove the rubber seal to prevent damage caused by furthur inspection of the lance
Step 11 Back in the vice with a adjustable spanner to remove the main part of the body
You are left with this
A quick check that all holes are not blocked with anything
Ok so now you have checked and cleaned the lance now its time to put it back together again..
This is the order from right to left on the strip down of the lance, from Karcher connector to the main body of the lance
Step 12 Some threadlock is required or PTFE tape to seal and lock the joints back together again,we will start with the main lance body
Step 13 Replace the rubber seal into the groove
Step 14 Replace the metal gauze into the brass connector
Step 15 Apply some threadlock or PTFE to the end brass connector thread and tighten
Step 15 Replace the black adjustable knob with a philips screwdriver
Step 16 Replace the black plastic/metal adjustable blades by pushing it on the brass end connector and it will click into place
Step 17 Replace the black plastic main body over the adjustable blades as pic
Step 18 Replace the metal peg into the black plastic body by just pusing it in
Step 19 Replace the injector by screwing it back in via a flat screwdriver
Step 20 Replace the steel bar into the foam lance main body with either threadlock or PTFE tape then replace the Karcher plastic connector onto the bar with PTFE and screwing it on tightly ensuring the Karcher plastic lugs are pointing upright to ensure the right vertical connection to your karcher gun/lance.
Ok that just about does it, this takes approx 10 minutes and is very easy to do,after being asked to post this prcedure on AF to help members to service and look after the lance they have.
Billyt
Ok here goes!
The lance
PTFE is better if you want to take apart again
17 answers to this question
