EPOCH Posted August 5, 2013 Share Posted August 5, 2013 :: Question :: Which polishing machine is better and why? :: My Thoughts :: I know there's a 20$ difference in price but was wondering which polisher is better. I'm going to buy one at the end of the month and wanted to know what you guys thought of each machine. Link to comment Share on other sites More sharing options...
0 GerryC Posted August 5, 2013 Share Posted August 5, 2013 It's not a matter of which is better, it's a matter of which is better for you. Do you have really hard clearcoat or something with a lot of damage and you are comfortable using a machine? Flex is likely your choice. Is this your first time using a machine, have softer clearcoat or average surface damage? Cyclo might be a better fit. Watch the new polishing videos and they are explained in more detail: Link to comment Share on other sites More sharing options...
0 egott_91 Posted August 5, 2013 Share Posted August 5, 2013 It can be argued either way which is "better". I have 2 machines that I use. The Rupes LHR21 and the Cyclo 5-Pro. Rupes is better for correcting heavy damage, the cyclo is better at getting those smaller panels you can't fit a large pad on. It's all a matter of preference too. Have you ever used a machine? If not, the cyclo has less of a learning curve. If you've used a machine for awhile, the flex might be easy for you get the hang of. Link to comment Share on other sites More sharing options...
0 Feets31 Posted August 5, 2013 Share Posted August 5, 2013 http://www.adamsforums.com/topic/24222-do-i-add-the-flex-or-the-cyclo/ Here are some other thoughts on the two Link to comment Share on other sites More sharing options...
0 Team Adam's Posted August 5, 2013 Share Posted August 5, 2013 (edited) Gerry is correct... like with most things detailing its not about which is "BETTER" its about which one suits your needs and requirements. Short Pro/Con list for each off the top of my head. Pros Flex: Powerful and capable of more serious correction Graduated trigger "throttle" allows for more control Pistol grip and bale head are comfortable to work with Clutched startup makes for smooth start/stops Cons Flex: Can be a little fatiguing to work with for long periods of time (shoulder burn!)Vibrates a fair amount... not as bad as some tools, but not the smoothest tool to work with. Learning curve to get 'perfect' is slightly steeper thanks to the forced rotation and the wrinkle that adds to the process. Limited on pad size options even with aftermarket plates. Pros Cyclo: 100% made in the USA Smoothest operating tool in the business, very low vibration All metal housing is very durable All parts are easily serviceable. Dual 4" heads allow you to get into various spots that larger pads won't fit (pillars, etc) Can accept various attachments for other tasks besides polishing (coming soon) Easy to pick up and learn with. Cons Cyclo: Less powerful than the flex, may require more passes on more damaged finishes. Takes more time to fluff/brush 2 heads than just 1. Takes more time to setup for use (attach and center 2 pads each time) Edited August 5, 2013 by Dylan@Adams Link to comment Share on other sites More sharing options...
0 EPOCH Posted August 5, 2013 Author Share Posted August 5, 2013 (edited) Gerry is correct... like with most things detailing its not about which is "BETTER" its about which one suits your needs and requirements. Short Pro/Con list for each off the top of my head. Pros Flex: Powerful and capable of more serious correction Graduated trigger "throttle" allows for more control Pistol grip and bale head are comfortable to work with Clutched startup makes for smooth start/stops Cons Flex: Can be a little fatiguing to work with for long periods of time (shoulder burn!)Vibrates a fair amount... not as bad as some tools, but not the smoothest tool to work with. Learning curve to get 'perfect' is slightly steeper thanks to the forced rotation and the wrinkle that adds to the process. Limited on pad size options even with aftermarket plates. Pros Cyclo: 100% made in the USA Smoothest operating tool in the business, very low vibration All metal housing is very durable All parts are easily serviceable. Dual 4" heads allow you to get into various spots that larger pads won't fit (pillars, etc) Can accept various attachments for other tasks besides polishing (coming soon) Easy to pick up and learn with. Cons Cyclo: Less powerful than the flex, may require more passes on more damaged finishes. Takes more time to fluff/brush 2 heads than just 1. Takes more time to setup for use (attach and center 2 pads each time) http://www.adamsforums.com/topic/24222-do-i-add-the-flex-or-the-cyclo/ Here are some other thoughts on the two It can be argued either way which is "better".I have 2 machines that I use. The Rupes LHR21 and the Cyclo 5-Pro. Rupes is better for correcting heavy damage, the cyclo is better at getting those smaller panels you can't fit a large pad on.It's all a matter of preference too. Have you ever used a machine? If not, the cyclo has less of a learning curve. If you've used a machine for awhile, the flex might be easy for you get the hang of. Some great advice and glad I asked because this would be my first polishing machine I'm thinking about going with the cyclo. Edited August 5, 2013 by EPOCH Link to comment Share on other sites More sharing options...
0 IrishCurse Posted August 5, 2013 Share Posted August 5, 2013 Also, lets not forget that along with the Flex's corrective abilities, its also MUCH faster "pound for pound" correcting than the cyclo. I'm really looking at the Bigfoot too. Some very talented detailers on this site are using it more and more. Link to comment Share on other sites More sharing options...
0 EPOCH Posted August 5, 2013 Author Share Posted August 5, 2013 I'm going to get my car painted in December or January. So I'm wondering in that case I shouldn't need many corrections I wouldn't think but you never know. After watching the video's I really care decide LOL! Also, lets not forget that along with the Flex's corrective abilities, its also MUCH faster "pound for pound" correcting than the cyclo. I'm really looking at the Bigfoot too. Some very talented detailers on this site are using it more and more. Link to comment Share on other sites More sharing options...
0 xkwj43z Posted August 5, 2013 Share Posted August 5, 2013 I used my Cyclo for the first time this past weekend and... WOW! I am very happy with it. Pretty much zero vibration, low noise, but the noise just like all polishers starts to get annoying towards the end of the job. The biggest plus I think is that the Cyclo fits into spots the Flex can't, like pillars for example. For someone new to polishing I would suggest you purchase a Cyclo the learning curve was very short. BMWguy206 and Team Adam's 2 Link to comment Share on other sites More sharing options...
0 BMWguy206 Posted August 11, 2013 Share Posted August 11, 2013 Thank you for your review. I use to have a PC and Flex but sold them. Now I am thinking about buying another polisher and I am leaning more towards the Cyclo. I used my Cyclo for the first time this past weekend and... WOW! I am very happy with it. Pretty much zero vibration, low noise, but the noise just like all polishers starts to get annoying towards the end of the job. The biggest plus I think is that the Cyclo fits into spots the Flex can't, like pillars for example. For someone new to polishing I would suggest you purchase a Cyclo the learning curve was very short. xkwj43z 1 Link to comment Share on other sites More sharing options...
0 DonJuan692006 Posted August 12, 2013 Share Posted August 12, 2013 I'm going to get my car painted in December or January. So I'm wondering in that case I shouldn't need many corrections I wouldn't think but you never know. After watching the video's I really care decide LOL! The Cyclo would be perfect for you. I finally used mine over the weekend and man it was easy. The hardest part was getting the product/prime right. It did an excellent job at the the god awful amount of micro scratches I had (improper washing) and I feel like the deeper scratches just need another pass (I only did one each of correcting/finishing polish). Link to comment Share on other sites More sharing options...
0 BMWguy206 Posted August 21, 2013 Share Posted August 21, 2013 For those with the Flex 3401, how do you correct and polish the paint on the pillars and small areas? Link to comment Share on other sites More sharing options...
0 BKazzle Posted August 21, 2013 Share Posted August 21, 2013 For those with the Flex 3401, how do you correct and polish the paint on the pillars and small areas? Smaller backing plate and smaller pads for the Flex. If I need smaller, I have another polisher for that, plus I have Adam's drill attachments as well. Link to comment Share on other sites More sharing options...
EPOCH
:: Question ::
:: My Thoughts ::
12 answers to this question
