foot56 Posted January 19, 2014 Share Posted January 19, 2014 Wash, Clay, Paint Correct, Seal, Glaze, Butter, Americana? or is that way to much wax? Thoughts? OmniCamaro and pfoushee 2 Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted January 19, 2014 Share Posted January 19, 2014 Sounds like you are on the right track, however you can skip the Buttery.........post up pics when done. THE Mook, OmniCamaro and drcornejoe440 3 Link to comment Share on other sites More sharing options...
0 HydroBlueJK Posted January 19, 2014 Share Posted January 19, 2014 Yea what Chris said, Americana or buttery but both is over kill Link to comment Share on other sites More sharing options...
0 mdolandese Posted January 19, 2014 Share Posted January 19, 2014 After the paint correct you could hit it with a quick isopropyl wipe down, to make sure you have removed all the haze or fine residue of the polish. It's not necessary, but that's what I do. Link to comment Share on other sites More sharing options...
0 foot56 Posted January 20, 2014 Author Share Posted January 20, 2014 After the paint correct you could hit it with a quick isopropyl wipe down, to make sure you have removed all the haze or fine residue of the polish. It's not necessary, but that's what I do. Do you mix it with water or just straight isopropyl? Link to comment Share on other sites More sharing options...
0 mc2hill Posted January 20, 2014 Share Posted January 20, 2014 Do you mix it with water or just straight isopropyl? 50/50 with water should be fine. scootertrash19 1 Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted January 20, 2014 Share Posted January 20, 2014 for an IP wipe down you can probably do a 30-40% dilution Link to comment Share on other sites More sharing options...
0 2quikta Posted January 25, 2014 Share Posted January 25, 2014 What do you use for the IP wipe down? Are single softs ok to use or is a more general (new blues) better? Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted January 25, 2014 Share Posted January 25, 2014 Either one will work fine....... Link to comment Share on other sites More sharing options...
0 mc2hill Posted January 25, 2014 Share Posted January 25, 2014 What do you use for the IP wipe down? Are single softs ok to use or is a more general (new blues) better? Or even a Waterless Wash Towel since you are working with liquids. Link to comment Share on other sites More sharing options...
0 6inarow Posted February 2, 2014 Share Posted February 2, 2014 does the paint finish go after the paint correction, before the glaze??? OmniCamaro 1 Link to comment Share on other sites More sharing options...
0 mc2hill Posted February 3, 2014 Share Posted February 3, 2014 does the paint finish go after the paint correction, before the glaze??? Yes. PFP is less aggressive than PCP so it is used to 'finish' the paint after using the correcting polish. Think of it like sandpaper - low numbers (PCP) to remove large stuff, big numbers (PFP) to get it "babys butt" smooth. BG has no correcting properties, but can hide small imperfections. Link to comment Share on other sites More sharing options...
0 THE Mook Posted February 3, 2014 Share Posted February 3, 2014 IMO If you are applying BG, the IPA wipedown may not be needed. I rarely hit a car with IPA if I am using BG before wax. Yes, eliminate the Buttery step. Americana is a better wax in terms of longevity and look. Link to comment Share on other sites More sharing options...
0 Trapp2012 Posted February 8, 2014 Share Posted February 8, 2014 IMO If you are applying BG, the IPA wipedown may not be needed. I rarely hit a car with IPA if I am using BG before wax. Yes, eliminate the Buttery step. Americana is a better wax in terms of longevity and look. Same as Mook said. I've only been using adams Paint correcting polish set since it came out, I've used other products for 3-4 years. I've done about 8 corrections so far using the new stuff and have only used the IPA/Water wiped down two times. IMO its not "required" but I do use it on the panels I work extensively. And to the OP, make sure you tape off plastics and work product thoroughly to "flash". Work slow, check your work, and work some more. Link to comment Share on other sites More sharing options...
0 OmniCamaro Posted April 11, 2014 Share Posted April 11, 2014 Wash, Clay, Paint Correct, Seal, Glaze, Butter, Americana? or is that way to much wax? Thoughts? Thank you for posting this. I'm taking a screen shot so I'll have it for reference! Link to comment Share on other sites More sharing options...
0 Beemer Posted April 11, 2014 Share Posted April 11, 2014 Thank you for posting this. I'm taking a screen shot so I'll have it for reference! Please note: You don't need Buttery Wax and Americana Paste Wax. One or the other is fine. Link to comment Share on other sites More sharing options...
0 OmniCamaro Posted April 11, 2014 Share Posted April 11, 2014 Please note: You don't need Buttery Wax and Americana Paste Wax. One or the other is fine. Roger that. I only have Buttery so that won't be an issue for me Link to comment Share on other sites More sharing options...
0 Chewy Posted April 11, 2014 Share Posted April 11, 2014 I read this and thought you'd gotten a time machine and wanted to polish it. I just wanted a ride in the time machine! Link to comment Share on other sites More sharing options...
0 Ordie Posted April 11, 2014 Share Posted April 11, 2014 I read this and thought you'd gotten a time machine and wanted to polish it. I just wanted a ride in the time machine! Doctor Who is polishing the TARDIS Link to comment Share on other sites More sharing options...
0 OmniCamaro Posted April 16, 2014 Share Posted April 16, 2014 Does anyone know of a thread that explains each step AND in the correct order? Reason: I just today discovered that the Sealant should be given time to "set up?" Before moving on to the next step. Just did every step to my car and didn't wait at all. I know about the videos and I've watched them all, more than once. For me, when the time comes to actually get dirty I totally forget those things. A quick reference guide/checklist is needed, for me anyway. I thought I saw one before but can't seem to find it Link to comment Share on other sites More sharing options...
0 Chewy Posted April 17, 2014 Share Posted April 17, 2014 What sealant are you using? Link to comment Share on other sites More sharing options...
0 OmniCamaro Posted April 17, 2014 Share Posted April 17, 2014 What sealant are you using? The newest liquid paint sealant from Adam's. Link to comment Share on other sites More sharing options...
0 Team Adam's Posted April 17, 2014 Share Posted April 17, 2014 No cure time with LPS, that was the old Machine Super Sealant than needed 12+ hours to cure. Apply, remove, and move on to glaze and/or wax. No need to wait in between steps with the new sealant. Link to comment Share on other sites More sharing options...
0 Richard Kashinsky Posted April 19, 2014 Share Posted April 19, 2014 Wash, Clay, Paint Correct, Seal, Glaze, Butter, Americana? or is that way to much wax? Thoughts? I wash, dry, clay, Paint Correcting Polish, Paint Finishing Polish, Brilliant Glaze followed by Buttery Wax, Americana or Patriot Wax. I don't use alcohol on my cars. Period! Richard Kashinsky Link to comment Share on other sites More sharing options...
0 ramflava Posted April 19, 2014 Share Posted April 19, 2014 Another question to add is, when the word "seal" is used, is it Paint Sealant, or Quick Seal Spray, or both, or either one?Where would the spray fit in? Link to comment Share on other sites More sharing options...
0 Beemer Posted April 19, 2014 Share Posted April 19, 2014 For Adam's system the sealant goes on bare paint. Usually the first step after polishing. You can use either the Liquid Sealant or the Quick Sealant. Team Adam's 1 Link to comment Share on other sites More sharing options...
foot56
Thoughts?
28 answers to this question
