mtnbiker326 Posted August 9, 2014 Share Posted August 9, 2014 Here are the results of my new tire shine and DWC. LOVE IT. It looks AWESOME!!!!!! Here are the before and after photos. (not perfect but I was only dedicating 2 hrs to the whole car) DWC is the ONLY product I have found that cuts BMW aggressive break pad dust with just one/two applications (and wheel woolie/utility towel to clean up the residuals). I am COMPLETELY SOLD on DWC and Tire Shine. Green wheel cleaner, Simple Green, Dawn, etc. can't even begin to hold a match to the fury of that which is Deep Wheel Cleaner!!!!!! Keep up the GREAT work Adam's Polishes! AusTroy, b_pappy and AmyAtAdamsAustralia 3 Link to comment Share on other sites More sharing options...
Team Adam's Posted August 11, 2014 Share Posted August 11, 2014 AWESOME stuff Chris, thanks for sharing the before and after pics!! Link to comment Share on other sites More sharing options...
Ricky Bobby Posted August 11, 2014 Share Posted August 11, 2014 I don't have one of the new ones but I LOVE my "OG edition" Adams woolie set with the DWC. Best part is that DWC is more liquid than Sonax FE (more of a gel), the sprayer on the Adam's bottles are better, it smells better than Sonax, and in my opinion it cleans faster and better than original Sonax FE. I'll be purchasing in gallons from here on out, I only use it on the wheels every 2-3 months or so and Car Shampoo with woolies and brushes for maintenance cleanings in between, but I always clean my barrels each time I wash. Best thing about DWC is it doubles as an excellent Paint decon spray too so you can save time on claying! mtnbiker326 1 Link to comment Share on other sites More sharing options...
Sizzle Chest Posted August 12, 2014 Share Posted August 12, 2014 Very nice! Good stuff!!! Link to comment Share on other sites More sharing options...
mtnbiker326 Posted August 14, 2014 Author Share Posted August 14, 2014 I don't have one of the new ones but I LOVE my "OG edition" Adams woolie set with the DWC. Best part is that DWC is more liquid than Sonax FE (more of a gel), the sprayer on the Adam's bottles are better, it smells better than Sonax, and in my opinion it cleans faster and better than original Sonax FE. I'll be purchasing in gallons from here on out, I only use it on the wheels every 2-3 months or so and Car Shampoo with woolies and brushes for maintenance cleanings in between, but I always clean my barrels each time I wash. Best thing about DWC is it doubles as an excellent Paint decon spray too so you can save time on claying! I will say that I am only using my OG edition woolies as well. I did not know that DWC decons paint as good as clay? There is no harmful effect on the clear from the DWC? Ricky Bobby 1 Link to comment Share on other sites More sharing options...
Ricky Bobby Posted August 14, 2014 Share Posted August 14, 2014 Read your bottle of DWC Chris, it specifically says it can be used to get orange specks out of paint (iron particles), if not on the bottle then its def on the Adam's website. As far as I can tell the active ingredient in DWC is the same ferrous fighting agent used in the popular paint decon spray "Iron-X", which I used to use a few years back. The Iron-X description actually states for use on paint or wheels. Since DWC is pH neutral, it will not negatively attack the clear on your paint just like it won't attack the clear negatively on the wheels. Just don't use it on a hot car and don't allow to dry on the surface. Next time you are doing "the full monty", give a light misting of DWC on your car, AFTER the wash, while the car is still wet, let it dwell for a minute or two, and you can either give agitation with a light sponge or wash pad and soapy water, or simply rinse down with a decent stream from your hose nozzle. Then go right into claying, you'll notice it should take you half the time. As far as I can see DWC is a phenomenal 2-in-1 product from Adams, probably the second most versatile product after Rinseless Wash. Fphillips, mtnbiker326 and NowDatsG 3 Link to comment Share on other sites More sharing options...
Team Adam's Posted August 14, 2014 Share Posted August 14, 2014 Chris, Jason nailed it. It's a GREAT paint decon product, although we don't really market it as such. It speeds along the claying process considerably since it removes a fair amount of contamination on it's own before a clay bar even hits the surface. Ricky Bobby 1 Link to comment Share on other sites More sharing options...
mtnbiker326 Posted August 18, 2014 Author Share Posted August 18, 2014 (edited) That is GREAT NEWS!!!!! That means that my clays will last even longer due to the larger contamination being removed more quickly with the DWC. Not all, but a fair amount. :) Edited August 18, 2014 by mtnbiker326 Link to comment Share on other sites More sharing options...
mtnbiker326 Posted August 18, 2014 Author Share Posted August 18, 2014 (edited) Read your bottle of DWC Chris, it specifically says it can be used to get orange specks out of paint (iron particles), if not on the bottle then its def on the Adam's website. As far as I can tell the active ingredient in DWC is the same ferrous fighting agent used in the popular paint decon spray "Iron-X", which I used to use a few years back. The Iron-X description actually states for use on paint or wheels. Since DWC is pH neutral, it will not negatively attack the clear on your paint just like it won't attack the clear negatively on the wheels. Just don't use it on a hot car and don't allow to dry on the surface. Next time you are doing "the full monty", give a light misting of DWC on your car, AFTER the wash, while the car is still wet, let it dwell for a minute or two, and you can either give agitation with a light sponge or wash pad and soapy water, or simply rinse down with a decent stream from your hose nozzle. Then go right into claying, you'll notice it should take you half the time. As far as I can see DWC is a phenomenal 2-in-1 product from Adams, probably the second most versatile product after Rinseless Wash. The funny thing is that I am buying and using DWC and Rinseless the most out of ALL the products I use (which is all of them). It is great to have multiple uses for the two MOST used products on my shelves. Now it will mean that I will be purchasing MORE of those two products even more frequently. Thanks Jason for inadvertently draining my wallet, more quickly, in the future Edited August 18, 2014 by mtnbiker326 Ricky Bobby and Team Adam's 2 Link to comment Share on other sites More sharing options...
CntryClub007 Posted June 9, 2015 Share Posted June 9, 2015 It cuts the BMW dust great. Link to comment Share on other sites More sharing options...
rcibotti5986 Posted September 4, 2015 Share Posted September 4, 2015 Couldn't agree more...before and after of my Charger's wheel...super clean and shiny now. Link to comment Share on other sites More sharing options...
Ricky Bobby Posted September 4, 2015 Share Posted September 4, 2015 Beautiful job on those charger wheels now seal them up and they will be a dream to clean! Link to comment Share on other sites More sharing options...
