TheWolf Posted February 18, 2017 Author Share Posted February 18, 2017 Finished converting all my sprayers and gallons to the new logo. Mariner, zapdon, LFairbanks and 1 other 4 Link to comment Share on other sites More sharing options...
LFairbanks Posted February 18, 2017 Share Posted February 18, 2017 Does the Amsoil product you used come in anything more than a rattle can that you know of? I did a search and found nothing. Just thought it would be easier to buy it by like a gallon paint pale for example and use a sprayer on an air compressor. Link to comment Share on other sites More sharing options...
TheWolf Posted February 18, 2017 Author Share Posted February 18, 2017 Does the Amsoil product you used come in anything more than a rattle can that you know of? I did a search and found nothing. Just thought it would be easier to buy it by like a gallon paint pale for example and use a sprayer on an air compressor. I have only seen it in the aerosol can. The nice thing about the can is it comes with a spray straw, so you can spray it into frame holes and all the places water can get into. LFairbanks 1 Link to comment Share on other sites More sharing options...
stripesace Posted February 18, 2017 Share Posted February 18, 2017 Finished converting all my sprayers and gallons to the new logo. 20170217_154639.jpg It takes some serious patience to peel labels off of these bottles. Do you heat them up a little before trying to work them off? How's the adhesive hold up when you move them over. Link to comment Share on other sites More sharing options...
LT1xL82 Posted February 18, 2017 Share Posted February 18, 2017 It takes some serious patience to peel labels off of these bottles. Do you heat them up a little before trying to work them off? How's the adhesive hold up when you move them over. At first I tried without heat...basically a great way to mess up the labels! I use a heat gun, being careful not to dwell in one area. If it doesn't peel easily, I use a bit more heat. Then immediately reapply to new bottle that was cleaned with IPA and dried beforehand. It works great! Link to comment Share on other sites More sharing options...
TheWolf Posted February 19, 2017 Author Share Posted February 19, 2017 It takes some serious patience to peel labels off of these bottles. Do you heat them up a little before trying to work them off? How's the adhesive hold up when you move them over. I had no issues removing and re-sticking these new labels, without using any heat. These new labels are not like the older labels that had the old logo. These new ones peel off easy, and the adhesive mostly stays on the label. The old style labels required heat to remove, or the adhesive would separate from the label and stay on the bottle. On the first new label that I tried, I used a heat gun, and it almost instantly shrink-melted the label, ruining it. Just start at one corner, and pull gently and slow. If your bottles are cold, or it is not peeling off easily, then you could try a hair dryer on low, but I would say avoid the heat gun. The gallon labels re-stick fine. For the 32oz labels that I put on the red-headed Tolco bottles, the labels are a bit too long, so both ends of the label land on the raised graduations on the back of the bottle, causing them to not stay stuck. I addressed this by using a piece of clear packaging tape, applied vertically over both ends of the label, to hold them together. And like Joel already mentioned above, make sure to clean the outside of the bottle really good. After removing the old label, wash the outside with warm water to remove any product, and then wipe with some IPA, and let dry. While there was some adhesive residue left from the old labels, I did not bother to remove it, since it just makes the new label stick better. But, washing and IPA is still needed, since the new label is bigger, so that portion of the bottle that was not covered by the old label might have Detail Spray, or another product, that would interfere with the new label sticking. The old style labels (with the red car) that were on the Colad pressure sprayers were a pain to remove, even with heat. The paper backing just tears off and stays on the bottle. Link to comment Share on other sites More sharing options...
TheWolf Posted March 5, 2017 Author Share Posted March 5, 2017 Replaced the bucket labels with the new ones. Installed the Adam's 21" Metal Garage Sign. #bottlesonpoint ocdrifter, Gen9Rolla, Mariner and 3 others 6 Link to comment Share on other sites More sharing options...
red94chev Posted March 6, 2017 Share Posted March 6, 2017 Very nice, I recently undercoated my truck with Fluid Film which is similar to what you used. TheWolf 1 Link to comment Share on other sites More sharing options...
TheWolf Posted June 22, 2017 Author Share Posted June 22, 2017 Danny had a wool wash mitt, its fleece was a tangled mess. So he washed, brushed and rinsed it out, then the mitt was clean and fresh. Vossmd3, tmccoy2236 and 8675309'SS 3 Link to comment Share on other sites More sharing options...
LT1xL82 Posted June 22, 2017 Share Posted June 22, 2017 I had a dog that looked like that! TheWolf 1 Link to comment Share on other sites More sharing options...
pirahnah3 Posted June 23, 2017 Share Posted June 23, 2017 Haha, thats funny. Honestly saw the pics before reading and I thought it was about dog hair for a moment lol TheWolf 1 Link to comment Share on other sites More sharing options...
TheWolf Posted November 27, 2017 Author Share Posted November 27, 2017 Good grief, I have really been neglecting this thread. I was really busy this summer and fall with projects around the house, but have gotten back to spending quality time in the garage this past week. I'll start by posting a tip for cleaning tires. If your tires are really dirty or have a lot of oxidation (look brown), then you may need to scrub with Tire & Rubber Cleaner more than once. After scrubbing, and the lather turns brown, rinse the tire and then scrub with Tire & Rubber Cleaner again, until the lather stays mostly white. This lets you know that all the dirt and oxidation has been removed. Really bad tires may even need more than two scrubbings the first time they are deep cleaned. Just scrub, rinse, repeat until the lather stays mostly white. Second part of this tip: If you don't already have some Tire & Rubber Cleaner, get the Tire & Rubber Cleaner Collection which also includes a gallon refill and the Tire Brush. This is definitely a product where you want to take advantage of the discounted 'cost per ounce' in the gallon refill. blcksilv08, mc2hill, Nickfire20 and 2 others 5 Link to comment Share on other sites More sharing options...
SaleenJOE Posted November 27, 2017 Share Posted November 27, 2017 Glad to see you get back to this thread. Always enjoy seeing what you are up to lol TheWolf 1 Link to comment Share on other sites More sharing options...
falcaineer Posted November 28, 2017 Share Posted November 28, 2017 LOVE this thread! Keep up the posts, Dan! TheWolf 1 Link to comment Share on other sites More sharing options...
avimore Posted November 28, 2017 Share Posted November 28, 2017 On 3/5/2017 at 11:04 AM, TheWolf said: Replaced the bucket labels with the new ones. Great work as always, Dan. I can't lie though, that middle sticker being higher than the other two is killing me! TheWolf 1 Link to comment Share on other sites More sharing options...
TheWolf Posted November 29, 2017 Author Share Posted November 29, 2017 19 hours ago, avimore said: Great work as always, Dan. I can't lie though, that middle sticker being higher than the other two is killing me! I'm glad it bothers you too! You can see that the middle bucket is not the same as the other two. I just so happened to start with the middle bucket, and wanted all the labels as high as possible, so less is hidden by the bucket caddies, and then realized that the other two buckets were built different. Oh well, the two buckets that do match are the wheel buckets that ride in the caddies, and the middle bucket is the rinse bucket on the detailing cart, so they are not next to each other, where it would be noticeable. avimore 1 Link to comment Share on other sites More sharing options...
TheWolf Posted December 1, 2017 Author Share Posted December 1, 2017 Polishing and Coating It had been about 2.5 years since the Raptor was polished, and while there were no swirls or major scratches, there were a few minor scratches that needed to be removed prior to applying Ceramic Paint Coating. In addition, a full polish is advised before applying Ceramic Paint Coating, so that the coating can get the best bond to a fresh surface of clear coat, as opposed to clear coat that has been exposed to the elements. The steps for this detail: Wash, clay, then wash again, towel dry Tape off all plastic and rubber trim (to avoid contact with polishing) Spot polish any scratches with Heavy Correcting Compound and the Rupes Nano Machine polish with Correcting Polish Machine polish with Finishing Polish (to get the most shine) Strip wash, and scrub all trim with Tire & Rubber Cleaner, rinse well Dry with Master Blaster (to get all the water out of the cracks) Let sit overnight to ensure it was completely dry prior to coating Prep all surfaces with Coating Prep and a few clean Single Soft Towels Apply Ceramic Trim Coating Let the trim cure for a day Wipe the paint again with Coating Prep and a clean towel, to remove any light dust Apply Ceramic Paint Coating Let the paint cure for a day Apply Ceramic Boost Washing and Prep Tips: I did not Strip Wash to begin with, since I was going to do a full polish anyway. Towel drying instead of using the Master Blaster prevents the issue of having dirt or other grit blown out of the cracks, where it could get picked up in the polishing pad and do major damage. Having sneaky drips during polishing is not really an issue. Scrubbing all the trim with Tire & Rubber Cleaner during the post-polish wash allows for complete rinsing of the TRC residue, which is more effective and also saves time during Coating Prep (ie not having to try to remove all of the TRC residue with just a towel and CP). The post-polish Strip Wash ensures that all polishing residue and oils are removed from the paint. This is much more effective than trying to clean the polishing residues with towels and Coating Prep. The cleaner the paint, the better the bond for the coating, the longer it will last. This photo was taken after the polish, and before the Strip Wash. It shows the rain water beading up on the polishing oils. Forced air drying after the post-polish wash is needed to get all the water out of the cracks. Sneaky drips can ruin a coating application. Polishing Tips: Taping off all the trim allows for polishing right to the edge of the paint, without getting polish on the trim. Even though it takes a bit of time to tape, I think it is less work than cleaning off residue. If you are polishing with multiple machine sizes, switch off between the machines as you make your way around the vehicle, instead of polishing the whole vehicle with the large machine, then going back and doing all the tighter areas with the smaller machine. Switching off with the different machines allows the pads time to cool off, as overheating pads with these long-throw machines can ruin the pads. When I finish a panel with one machine, I will give it a shot of Detail Spray to keep the pad from drying out while I use the other machine. The extra liquid also helps cool the pad. When wiping off the polishing residue after completing an area, don’t wipe off the leading edge of the residue. Leaving just this leading edge reminds you were you left off with the polishing, so you don’t waste time re-polishing an area you already did on an adjacent area. When your polish bottle starts to run low, use a small cup to keep it inverted between uses, so the remaining product will stay in the dispensing end. Coating Tips: Number one tip, you need EXCELLENT LIGHTING! While you can get away with polishing in less than optimal lighting by using a flashlight to spot scratches or swirls, when you are applying coating, you have to be able to see that the application is uniform, see the coating “rainbow”, and have to be able to see that all the residue is wiped off. You will not have time to mess around with flashlights. If you typically use a task light (such as a light stand) for detailing, then get a helper who can move the light around as you work, so you can maintain progress on the coating application. If you are going to be coating both the trim and paint, then apply the Trim Coating first. That way, any trim coating that gets on the paint can be easily cleaned off. If you were to apply coating to the paint first, then any Paint Coating that gets on the trim will be noticeable, and cannot be cleaned off. When prepping the plastic and rubber trim with Coating Prep and a towel, allow the trim to completely dry before applying the Ceramic Trim Coating. Plastic and rubber trim is porous, so it can soak up some of the Coating Prep, and if this is not all the way dry, it can prevent the trim coating from curing properly. I would recommend at least an hour of drying time after prepping the trim (may need to be longer in cooler temps or higher humidity). When using the coating applicators, apply the coating to one of the sides adjacent to the side that has the raised closure stitching. On each applicator, there are three panels without seams, the two sides adjacent to the raised closure seam, and the side opposite the seam (which most people tend to use). Since the coating ends up soaking around the edges of the side you are using (and cures), if you use the side opposite the raised closure seem, then you really only have one surface that is useful. Since you may need to switch to a fresh side if you pick up any grime (or drop it), then using the side shown facing up in this photo would allow you to switch to the opposite side, and still have a useful application surface that does not have any seams. When applying the Ceramic Trim Coating, be careful not to get any on the paint, as it will interfere with the bonding of the Ceramic Paint Coating. If you do get some on the paint, wipe it away with a clean plush towel. For any areas on the trim that do not look uniform after the Trim Coating has dried for an hour, reapply Trim Coating so that it looks uniform. On any trim areas that are difficult or impossible to get to with the applicator pad, use a detailing swab for application of the Trim Coating. This photo also shows that I removed the hood and fender vents for coating applications, which was easier than trying to coat these items properly while still on the truck. When using the Coating Prep on the paint (after the Trim Coating has been applied and cured overnight), pay special attention to the areas around the trim that were previously coated. Any Trim Coating that may have gotten on the paint, which you wiped off, probably left some residue that is not easily seen. However, when you wipe with the Coating Prep, any residue will show up with a rainbow effect, allowing you to see it (until the Prep dries). Clean these residue areas with some Revive Polish on the corner of a clean plush towel, and then re-clean the area with Coating Prep to remove the residue and oils from the polish. The grill was cleaned and prepped using detailing swabs, to make sure all the areas were cleaned. Before starting the Paint Coating application, walk around the vehicle and come up with a plan on how you are going to break down each panel into 2’x2’ or smaller application areas. Just starting without a plan may result in applying the coating to too large of an area. Applying to too large of an area will not give you enough time to level the product before it starts to cure. If you find that the applicator starts to drag before you get over the area with two opposing passes, then make the application area smaller. Planning how to apply to each panel also helps with this tip: do not overlap the application area too much with the preceding application area. The fresh coating that is overlapped with the area that was just coated will not flash (rainbow). Wiping off too much of this overlapped coating is going to build up too much residue in the towel, making the residue removal less effective, which creates more work and slows you down. If you didn’t catch this in the previous tip, the coating that is applied to an overlap area will not rainbow, so don’t sit there waiting for it to rainbow before removing the residue. Start wiping the residue from the application area as soon as you see the coating in the main application area rainbow. The coating in the overlapped are will stay wet (clear). For wiping the residue, fold the towel into quarters, and keep track of what part of the towel you are using. You do not want to just randomly use any part of the towel, since the coating residue will cure in the towel during the application. After using one surface of the towel for one or two panels, you will find that is becomes less effective at removing all of the residue. When switching faces on the towel, I marked the ‘used’ face with a Sharpie, so that I would not use that face again. Let the effectiveness of the residue removal tell you when to switch to a fresh towel surface. Once your find that the towel is not removing the residue as effectively (and leaving streaks), finish that application area, then switch to a clean surface for the next application area. Also, when you switch to a new towel surface, go back over the previously applied sections and re-wipe them with the fresh towel face to remove any missed residue. Detailing swabs were used to apply the Paint Coating to the grill. While some might be inclined to skip coating the grill, I think the extra time to prep and apply coating it is worth it, to make keeping it clean much easier. When applying the Ceramic Boost the day after the coating (so the coating has time to cure), take your time to look for any missed coating residue, and remove it by wiping with the Ceramic Boost, and buffing with a clean plush towel. Do not over-apply the Ceramic Boost, or you will have to spend extra time buffing out the streaks. Unless your garage has a ton of lighting, then you are likely going to find some coating residue the first time you pull it out of the garage and into the sunlight. Try removing the residue or streaks with Ceramic Boost. If that does not work, try some Brilliant Glaze. The dark bottles and dripper insert make it nearly impossible to keep track of how much coating is left in the bottle. Use a postal scale, or other small accurate scale, to measure the weight. The empty bottle weighs about 100g, and each ml of coating product weighs about a gram. You can either tare the scale with an empty bottle, or subtract 100g from the total weight, to approximate how much product is left. To keep track of stock, I mark the bottle with the date it was received, and also how much product is remaining in the bottle. falcaineer, ZMAN024, Beemer and 2 others 2 3 Link to comment Share on other sites More sharing options...
TheWolf Posted December 1, 2017 Author Share Posted December 1, 2017 Here's a couple shots that I took in the early morning, before driving it to work a few days after finishing the detail, and then getting rained on. blcksilv08, ZMAN024, falcaineer and 5 others 8 Link to comment Share on other sites More sharing options...
Nickfire20 Posted December 1, 2017 Share Posted December 1, 2017 (edited) Wow! That is perfection!! Also seems like a lot of tedious work. Wonderful job, and thanks for all the excellent tips!! Edited December 1, 2017 by Nickfire20 TheWolf 1 Link to comment Share on other sites More sharing options...
falcaineer Posted December 2, 2017 Share Posted December 2, 2017 (edited) Freaking. AWESOME! I want one!!! Edited December 2, 2017 by falcaineer TheWolf 1 Link to comment Share on other sites More sharing options...
sdfd504 Posted December 7, 2017 Share Posted December 7, 2017 Freaking amazing thread! I have a 2017 Raptor on the way from an out of state dealership so it's great to get tips from this thread on a huge truck like the Raptor. TheWolf 1 Link to comment Share on other sites More sharing options...
DonJuan692006 Posted June 16, 2019 Share Posted June 16, 2019 Are you still running the same pressure washer/DI setup? If so, how have they held up? Link to comment Share on other sites More sharing options...
TheWolf Posted June 17, 2019 Author Share Posted June 17, 2019 14 hours ago, DonJuan692006 said: Are you still running the same pressure washer/DI setup? If so, how have they held up? Yes, and it works great. On Saturday, the truck was covered in pollen, so I did a touchless wash by pressure washing with DI water, and then let it drip dry. Link to comment Share on other sites More sharing options...
TheWolf Posted July 1, 2019 Author Share Posted July 1, 2019 Tried out the Mega Foam Shampoo today. It goes on THICK and has good hang time. Seemed adequately lubricating. Used 2oz in the Adam's Foam Cannon with the electric pressure washer delivering 2.1 gpm at 1900 psi. If you are on Instagram, I posted a video to @danwolf73 mc2hill, falcaineer and tlbullet 3 Link to comment Share on other sites More sharing options...
mc2hill Posted July 1, 2019 Share Posted July 1, 2019 (edited) 10 hours ago, TheWolf said: You sure that is not shaving cream! Edited July 1, 2019 by mc2hill Yo-Yo Ma's Cousin, MasterBlasterII and TheWolf 1 2 Link to comment Share on other sites More sharing options...
