DaveyT Posted September 26, 2014 Share Posted September 26, 2014 Hi everyone. Does anyone use the hex grip applicators to apply Liquid Paint Sealant? If so, which color do you use. Thank you in advance for your feedback. Link to comment Share on other sites More sharing options...
0 SYMAWD Posted September 26, 2014 Share Posted September 26, 2014 I haven't used LPS, but you want the red applicator. Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted September 26, 2014 Share Posted September 26, 2014 I usually apply by machine, however for hand application you can use either Gray or the Red applicator. Link to comment Share on other sites More sharing options...
0 Natch02 Posted September 26, 2014 Share Posted September 26, 2014 Cyclo with black pad for me. Link to comment Share on other sites More sharing options...
0 The Guz Posted September 26, 2014 Share Posted September 26, 2014 I applied it with a standard yellow foam applicator or by machine. Link to comment Share on other sites More sharing options...
0 LFairbanks Posted September 26, 2014 Share Posted September 26, 2014 I have used these before, when applying by hand. Otherwise I do it by machine with the gray pad. http://adamspolishes.com/shop/adam-s-microfiber-applicator-pads-2-pack.html scootertrash19 1 Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted September 26, 2014 Share Posted September 26, 2014 I applied it with a standard yellow foam applicator or by machine.Bingo.....I forgot to mention the Yellow wax applicator. Link to comment Share on other sites More sharing options...
0 TheWolf Posted September 26, 2014 Share Posted September 26, 2014 Use a machine, if you have one, with a sealant or wax pad. I have found that the LPS is the hardest product to remove and a machine will help you get a nice, thin coat that will be easier to remove. When I apply anything by hand, even BG, I never get as thin and even a coat as with a machine, and the thicker and uneven coats are way more work to remove. A few weeks ago I was in a hurry and put on a coat of BG by hand and it ended up taking longer to remove it than the last application I did with the machine. If I had just gotten out the Cyclo to begin with, the overall time would have been shorter. Link to comment Share on other sites More sharing options...
0 Norton Posted September 26, 2014 Share Posted September 26, 2014 I use my PC7424XP with a Gray Pad to apply sealant. Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted September 26, 2014 Share Posted September 26, 2014 If applying by machine I personally recommend the 4" pad and backing plate as its easier to get into tight contours to spread a coat. However, I am always surprised at the amount of people who don't wax/seal by hand, noting difficulty of removal. I have been using a liquid paint sealant from another company for 4 years now and as long as you go by the phrase "Thin is in" meaning apply in ultra thin coats, and less is more, application and removal really is effortless. Sometimes after hours of polishing with the machine I like the quiet and serenity of doing my LSP by hand, maybe I guess i'm in the minority though. SSJ455 1 Link to comment Share on other sites More sharing options...
0 gapwedge Posted September 27, 2014 Share Posted September 27, 2014 It's a personal choice, but for Liquid Paint Sealant I use a machine with 4" gray foam pad. Glaze and wax by hand. Link to comment Share on other sites More sharing options...
0 SSJ455 Posted September 27, 2014 Share Posted September 27, 2014 I use the blue hex applicator. I also haven't found it too difficult to remove, though I make sure I don't get ahead of myself, ie half the hood then remove, the front fender and half the door then remove, etc. Link to comment Share on other sites More sharing options...
0 Numbr3t Posted October 25, 2014 Share Posted October 25, 2014 If I'm not mistaken...the blue hex is abrasive and you wouldn't want to use that to apply wax or sealant. Norton 1 Link to comment Share on other sites More sharing options...
0 Norton Posted October 25, 2014 Share Posted October 25, 2014 If I'm not mistaken...the blue hex is abrasive and you wouldn't want to use that to apply wax or sealant. +1. Blue and Orange hex applicators are designed for polishing, not sealing/waxing. RED and YELLOW hex applicators are the ones suited to sealant/wax application. Stick with Gray if using a machine. Link to comment Share on other sites More sharing options...
0 gbod Posted October 25, 2014 Share Posted October 25, 2014 I actually emailed support the other day about the hex grip applicators and which one to use for sealant. This was the reply: The Orange Foam in the Hex Grips is an abrasive foam, made for polishing out defects with Paint Correcting Polish. However, the foam in the other three (blue, yellow, and red) is all the same structure, non-abrasive, so they all three can be used interchangeably for any sealant, glaze, or wax. We color-code them so you can keep them straight as it's best to not mix-and-match which products you use on an individual applicator. Ricky Bobby 1 Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted October 26, 2014 Share Posted October 26, 2014 Been saying this for a while now even though people tried to tell me the Blue was a different foam. They color code the Blue to use with Revive which is non-abrasive. It's the same as the Yellow and Red GerryC 1 Link to comment Share on other sites More sharing options...
DaveyT
15 answers to this question
