Team Adam's 4,667 Posted January 7, 2015 Chances are you've encountered tire blooming and you don't even know it. Blooming is what causes a tire to look brown. That new set of tires that you have to scrub over and over again to get them to look black, or the tires on a car you detail less frequently that are closer to the color of chocolate than they are black. Modern rubber compounds are becoming increasingly complex, far more than most people realize. Tire manufactures are continually pushing the envelop with chemistry and design to create tires that can keep up with the demand of todays cars and drivers. Higher mileage, more miles per gallon, better all-weather traction, or high speed and cornering as cars get better, faster, more intense the tires they roll on must change to keep up.We expect increased performance from our vehicles and tires are an integral part of that, but rarely do we take the time to understand what exactly has changed about tires other than going from bias ply to radial in the late 1960's.What does this all have to do with your tires turning brown? Read on.ANTI-OZONANT An anti-ozonant is probably something you've never heard of. Its an organic compound added to rubber materials that prevents, or at the very least, slows the deterioration caused by exposure to the elements. Anti-ozonants are used as an additive in most all of the exterior rubber and plastic parts to one degree or another, but they are most prevalent in tire manufacturing. The anti-ozonant additive keeps plastics and rubbers from becoming dry, brittle, oxidized or cracking. It does this by preventing the surface of the material from oxidizing and keeps the material pliable. Thanks to anti-ozonants in rubber compounds we have have high mileage tires, performance tires, and everything in between. Without it sports cars would shred tires incredibly fast after just a few high speed turns or long track runs where the tires were heated up. Even your daily driven commuter car would need tires far more often as the sun and heat slowly rotted away the rubber compounds. TIRE BLOOMING Tire rubber compounds are designed in a wat that allows the anti-ozonant to continually work its way to the outside of the tire and as such, continually keeps the outer surface and sidewall pliable and resistant to oxidation.Once anti-ozonant reaches the outside of the tire and is exposed to air and moisture it oxidizes, the result being a brownish residue. The term for this ugly brownish tire look is 'tire blooming'. Just like metals left exposed to the outside world will slowly begin to rust (oxidize) as it is exposed to water and air, so does the anti-ozonant component of the tire rubber. Making matters worse is the use of mold releases in the manufacturing processes. These lubricant type chemicals provide a non-stick surface for the inside of a tire mold. The mold release chemical bonds with the tire and hold anti-ozonants onto the surface of the tire. While some people will point to mold release as the primary and/or only source of tire blooming, it is in fact often times only a part of the problem. Even after the removal of mold release a tire will continue to push anti-ozonant to the surface allowing the brown residue to return. THE ROLE OF COLOR CHANGING WHEEL CLEANERS Wheel cleaners used to dissolve metallic contamination (Deep Wheel Cleaner among them) can have an accelerating effect on the oxidation of anti-ozonant. The reaction you see when brake dust it turned to a reddish slurry by Deep Wheel Cleaner or a similar product is, in a very simplified way, oxidation. The chemical reacts with the metallic contamination and begins to dissolve it. Tires that have not been cleaned properly before or have been left uncleaned for long periods of time will have substantial amounts of the anti-ozonant built up on the surface of the tire. When an active wheel cleaner comes into contact with this buildup it will accelerate the browning or blooming. Because of this its imperative to regularly scrub tires to remove the buildup of anti-ozonant and 'dead' rubber - think of it almost like exfoliating your skin. If you are a regular user of Deep Wheel Cleaner or similar color changing wheel cleaners for their ability to remove stubborn brake dust then be sure to spend an extra couple of minutes scrubbing your tires as well. Does this necessarily mean you should discontinue the use of Deep Wheel Cleaner? No, but it should be used with the understanding that the tire needs deep cleaning after the wheel to remove any residues or prevent tire blooming acceleration as a result of the oxidation process. Abrading the tire sidewall to remove this will prevent the blooming in the first place - the reason your sidewalls brown, but your treads don't is that the treads are continually worn away by driving so the surface never is allowed to sit long enough to display blooming. DON'T BLAME THE SILICONE For years the prevailing thought has been that silicone based tire dressings are the culprit for brown tires. Read any number of forums and the first thing most casual detailers will point to is the choice of tire shine the person with the issue uses. While silicone can be a messy and sticky solution to making your tires shine it isn't always the main culprit of the brown issue.Most browning related to silicone will be due to the silicone holding dirt and debris on the tires surface, not the tire itself turning brown. This type of browning is very easy to remove as silicone dressings also remove with scrubbing and a degreaser like All Purpose Cleaner. Don't think this means you should immediately start to treat your tires with tons of silicone, there are still a lot of reasons it's not an ideal way to dress your tires, but don't believe the story that your choice of tire dressing is the ONLY source for the brown residue. Silicone and water based dressings can be used and the tire can still exhibit blooming... its the tires surfaces and/or lack of heavy cleaning more than it is anything you've treated it with. REMOVING THE BLOOMING Removing the blooming is really a simple process - the use of a good degreasing agent, like Adam's All Purpose Cleaner, and a stiff bristle brush should be more than enough to remove even the worst blooming within a few treatments. Be sure to rinse the tires extremely well with clean after each cleaning to remove any chemical buildup. Once the brown residues are removed regular cleanings with All Purpose Cleaner shouldn't need to be as aggressive or frequent, but if you notice the blooming returning just scrub well. The application of a quality water based dressing like Super VRT or a dressing low in silicone content like Adam's Tire Shine will help slow the reappearance of blooming by providing a barrier between the tire surface and the environment. IT WILL COME BACK, ITS JUST A QUESTION OF WHEN Because anti-ozonants continue to work their way towards the outside of the tire even a car which sees very little use or doesn't have very dirty tires may experience tire blooming when eventually exposed to oxidizers due to lack of cleaning. As such it is recommended that even relatively clean tires be treated to a semi-regular scrubbing to remove the anti-ozonants from the outer layer of the tire sidewalls. Each tire will have a different amount of blooming it is prone to. Some tires may bloom very slowly, while others will bloom almost before your very eyes. The amount of anti-ozonant and the way the tire is designed to push it to the surface will determine how fast or slow it happens. Regardless, one thing remains true - regular cleaning and dressing of your tires will prevent or at the very least minimize the appearance of brown on your tires. 26 PHOKUS, stalebreadjr, Black Bowtie and 23 others reacted to this Quote Share this post Link to post Share on other sites
Junior 190 Posted January 8, 2015 Dropping serious knowledge! I like it sir. Quote Share this post Link to post Share on other sites
sportruck00 17 Posted January 8, 2015 Dropping serious knowledge! I like it sir. Yes, very legit! ShineDoc, given the continued advancement in tires, with the various compound and additive types is there a point where cleaners may be too harsh and adversely affect the tire? With the anti-ozonant it sounds like the primary objective is to maintain the rubber for longevity and more so from becoming dry, oxidized, etc. I know tire and rubber technology isn't your primary profession, but do you see where repeat cleaning and/or application of tire conditioners may be of harm? I am not overly concerned, but my mind was definitely jogged by your great research here. When it comes to performance $200+ tires this type of thing may become of interest. Again, I can’t personally think of a time where someone said they ruined their tire from attempts at protecting them.. Quote Share this post Link to post Share on other sites
Team Adam's 4,667 Posted January 8, 2015 As my contact in the tire industry explained when I asked a similar question: "You'll need new tires because of tread wear long before it's something to worry about" The anti-ozonant works it's way to the surface regardless of your frequency of cleaning, so in theory an uncleaned tire loses it at the same rate as one cleaned frequently if they're exposed to the same amount of air/water. 1 sportruck00 reacted to this Quote Share this post Link to post Share on other sites
ADL 23 Posted January 8, 2015 Very informative, thank you for the information, Dylan! On our two cars I have experienced both extremes. The Cooper performance tires on mine are slow bloomers to the point I have never found them to be the slightest tint of brown. The off-brand (so off I can't remember!) tires on my wife's car bloom so bad it's as if they were molded brown and they sometimes take multiple APC and stiff tire brush applications before they are satisfactory. Quote Share this post Link to post Share on other sites
TheBurninator 215 Posted January 8, 2015 Very nice writeup Dylan. Most of it was a refresher for me, but the part about DWC I had no idea about. Good info Quote Share this post Link to post Share on other sites
Maxcustody 47 Posted January 8, 2015 Great info........Thank you Sir!!! Quote Share this post Link to post Share on other sites
07stanggt 358 Posted January 9, 2015 Wow, now thats some write up !!!!! Great job. Quote Share this post Link to post Share on other sites
HurstGN 0 Posted January 13, 2015 Enlightening. Thanks Doc!! Quote Share this post Link to post Share on other sites
Natch02 146 Posted January 17, 2015 Thanks for the informative post. Quote Share this post Link to post Share on other sites
GratefulDiver 30 Posted January 22, 2015 Just got new set of Falkins for the up coming season. What, if anything should I do before I mount the tires and dress with VRT? Quote Share this post Link to post Share on other sites
Ricky Bobby 1,517 Posted January 22, 2015 For a new set, you'll need to clean the snot out of them with multiple applications of APC full strength and the tire scrub brush, theres bound to be a ton of mold release on those new jawns. When you don't see brown being pulled from the tire and get white foam, you know you've got it stripped and ready to rock. Quote Share this post Link to post Share on other sites
GratefulDiver 30 Posted January 22, 2015 Any alternative to APC? Im fresh out and usually like to wait to order a few things at once when a sale comes around vs just one thing Quote Share this post Link to post Share on other sites
Ricky Bobby 1,517 Posted January 22, 2015 Any alternative to APC? Im fresh out and usually like to wait to order a few things at once when a sale comes around vs just one thing This may be debated but actually based on the chemical makeup of it you could try spraying Microfiber Revitalizer on the tire to see if its any stronger. MFR is basically a heavy duty degreaser/soap anyways, who knows, it might work better than APC. Dylan and I have discussed this before but if you have Stoner Tarminator it can be used to strip tires bc of the solvent content, be aware you'll probably use a full can on a set of tires. Quote Share this post Link to post Share on other sites
GratefulDiver 30 Posted January 22, 2015 How's green wheel cleaner for removing the blooming? I have a gallon of it lol. Or even simple green for that mater Quote Share this post Link to post Share on other sites
Ricky Bobby 1,517 Posted January 22, 2015 Green wheel cleaner is wayyyyyyy too gentle, don't waste the product. Simple green at full strength should work fine as well, its dirt cheap at $9 a gallon but definitely wear nitrile gloves (as with any APC), Simple Green has 2-butoxyethanol in it which is fairly toxic/carcinogenic Quote Share this post Link to post Share on other sites
Team Adam's 4,667 Posted January 22, 2015 This may be debated but actually based on the chemical makeup of it you could try spraying Microfiber Revitalizer on the tire to see if its any stronger. MFR is basically a heavy duty degreaser/soap anyways, who knows, it might work better than APC. Dylan and I have discussed this before but if you have Stoner Tarminator it can be used to strip tires bc of the solvent content, be aware you'll probably use a full can on a set of tires. I'd actually try leather & interior cleaner - the pH of it is right for cleaning rubber pretty well. Also, the stoners tarminator does make a pretty good rubber cleaner. I've actually used it a few times recently to clean tires, but you do use it differently. Spray onto a dry tire and scrub with a microfiber towel. You'll ruin about a dozen towels doing this so use the cheap-o ones or ones you aren't planning on using for delicate surfaces anytime soon. How's green wheel cleaner for removing the blooming? I have a gallon of it lol. Or even simple green for that mater Wouldn't even touch it. Simple Green is typically pretty good, you do have to get the dilution right and exercise some caution on certain wheel finishes for overspray. 1 Ricky Bobby reacted to this Quote Share this post Link to post Share on other sites
GratefulDiver 30 Posted January 23, 2015 Simple Green is typically pretty good, you do have to get the dilution right and exercise some caution on certain wheel finishes for overspray. The tires aren't mounted on the wheels yet so Im good there. I know you're not in to promoting or advising on other products here but what ratio of SG would be safe for the tires? Quote Share this post Link to post Share on other sites
sportruck00 17 Posted March 21, 2015 Any word/progress development on the once mentioned dedicated rubber tire cleaner? Quote Share this post Link to post Share on other sites
MattieDSC 10 Posted April 8, 2015 Thanks for the info I hate cleaning tires man they just never seem to come clean for me Quote Share this post Link to post Share on other sites
chops1sc 479 Posted June 14, 2015 My old truck went thru 2 sets of Mastercraft Courser A/T and I never saw any blooming. My new truck has Firestone Destination or something like that and they bloom before the tire even gets dry! Very frustrating! Quote Share this post Link to post Share on other sites
SherwoodNash 1 Posted January 6, 2016 I have a reverse question! I own a little 'rat' truck, and have just installed 4 new tires, what is the best way to *encourage* and keep a little sidewall browning? 1 KSRegalGS reacted to this Quote Share this post Link to post Share on other sites
stripesace 688 Posted January 6, 2016 I have a reverse question! I own a little 'rat' truck, and have just installed 4 new tires, what is the best way to *encourage* and keep a little sidewall browning? Spray em down with APC, scrub 'em clean, and then don't do anything to them.... Nature will take over from there. 1 Dan@Adams reacted to this Quote Share this post Link to post Share on other sites
NG13 172 Posted January 6, 2016 DWC will probably accelerate the blooming on the tires after you clean the mold release off them as John said above. DWC is an oxidizer which should help the blooming along a little faster than just nature itself. 1 Dan@Adams reacted to this Quote Share this post Link to post Share on other sites
tjk 243 Posted June 27, 2016 Any word/progress development on the once mentioned dedicated rubber tire cleaner? looks like some good things are in works Quote Share this post Link to post Share on other sites
