Team Adam's Posted March 6, 2015 Share Posted March 6, 2015 Plush to waffle weave, glass towels to wash pads, and even more recently polishing pads, microfiber has forever changed how shine freaks keep their cars looking great and how detailers correct, protect, and care for customers cars. The argument could be made that no single advancement in the world of car care has had a larger impact in the last decade than microfiber. Professionals and enthusiasts alike all keep a hefty supply of a wide variety of towels on hand at all times, but despite its omnipresence in the care care world there is still a fair amount of mis-information and mis-understanding as to how they should be cared for. In this FAQ article I'll be covering the basics of cleaning and care for your microfiber towels and a little bit of background on what makes them the preferred choice of detailers. WHAT IS MICROFIBER? What good is it to get into all the minutia of microfiber if you don't first have an understanding of the materials composition and history? Microfiber can be composed of many parts, most commonly in the detailing / car care industry we use a combination of polyesters and polyamides. These microscopic laboratory born fibers are around 1/100th the diameter of a human hair, this ultra fine thread is what gives microfiber its delicate touch and super soft feel. To put that size into perspective, if you were to think of a regulation basketball as the equivalent of the diameter of a human hair, an individual strand of microfiber would be smaller than an M&M chocolate candy! Why is this important? While you might see a fluffy towel with your naked eye on a microscopic level there is a very tiny, but very uniform and durable strand there. Almost all microfiber will share an identical fiber structure, regardless of weave or pattern. How the fibers are laid out will impart different characteristics to the material (plush for delicate surfaces, waffle weave for drying, flat for glass, suede for coatings, etc) Each individual strand has a star-like structure and all strands are virtually identical across the entire surface of a towel. If you could pull a fiber from one towel, and another from a different towel of similar quality and cross section them you'd likely not be able to tell them apart. This leads to a uniformly soft towel that performs the same regardless of fold or what portion is in contact with the surface. This is in stark contrast to the wild inconsistency of cotton fibers which can vary in shape and size from one strand to the next. (see the image below) The star shaped structure on each strand allow microfiber to trap small particles, dirt, moisture and debris making them very effective for cleaning. Compared to the inconsistent, tube-like, shape of cotton which is absorbent, but not ideal for cleaning microfiber has a clear advantage. WHERE DID MICROFIBER COME FROM? These tiny man made textiles were actually being produced back as early as the 1950's though the applications were extremely limited. Technology at the time had its limitations and it was next to impossible to produce long continuous strands in a consistent manner making it not only very expensive, but also very time consuming to produce. Technology began to catch up in the late 1960's when a team of Japanese researchers were able to produce microfibers in long continuous strands. This breakthrough lead to the adoption of microfiber for a variety of applications in the 1970's in the textiles industry. By the 1990's microfiber would gain popularity in the cleaning products market, but mostly in the janitorial and hospitality industries due to its sanitary properties and low tendency to shed or lint. In the early 2000's I personally had my first experience with this new 'micro towel' a friend of mine had gotten his hands on. It was softer than the cotton diapers we were all used to using in those days and in the coming years we began to see more and more variety in towels available. A good friend and fellow detailer actually began importing these towels as a side business around 2002 and instantly the SoCal detail market began to change. Everyone wanted these incredible new towels. In the years after that microfiber would explode and become widely accepted as the best option for any kind of detailing. The towels continued to improve and find new configurations - waffle weave, glass towels, foam core towels, applicators, and most recently the microfiber buffing pads. Its funny to think back on a time before microfiber, when a cotton diaper was the best option now, and even stranger to think that it wasn't all that long ago. WHAT DOES 'WEIGHT' MEAN? GSM or "Grams Per Square Meter" or "g/m2" is also referred to as the towels "weight". This measurement dictates the materials fiber density. In other words the relation between the mass of a towel and how much space or volume it takes up. Usually the higher the GSM the softer the towel. Plush towels for use on delicate surfaces should be at least 360gsm, but I personally prefer towels at least 460gsm or higher. Towels in the 200-350gsm range are best suited for non-delicate surfaces and tasks, like scrubbing leather seats or wiping off things under the hood. Now, the GSM rating isn't always the best way to define a towel. For example a waffle weave towel may have a lower GSM, but thats due to the way its constructed not as much due to the quality of the material.To be safe always buy your towels from a reputable source, and before jumping in with both feet test it in a small area to make sure its delicate enough for the job you're about to do. If you use a low GSM towel all over your car without first testing you'll have a lot of paint correcting to do! USE THE RIGHT TOWEL FOR THE JOB Because microfiber marks such a substantial investment in your detailing collection its important to do your best to preserve them to get the most use from them before they are retired. To this end its always a good idea to segment your towels into various types. Plush or deep fibers are generally best for extremely delicate jobs, like wiping or polishing clear coat, while shorter or looped fibers have superior scrubbing and cleaning power. Waffle weaves offer the best absorbancy gram for gram and flat weave towels are ideal for non-delicate surfaces where streak free performance is paramount. But don't just section your towels off by type! Sort your towels out in your collection for the jobs they're best suited for. Don't waste a good towel on a dirty job like wiping a door hinge or polishing metal. Preserve your best towels and retire old or stained towels to less important jobs. WHATS CONTAMINATING YOUR TOWEL MAKES A DIFFERENCE When you think about the contamination thats in your towels after a use you're talking about a pretty thick cocktail of polymers, waxes, oils, and other stubborn residues that need strong detergents to remove. For example waxes and sealants are products that BY DESIGN resist removal from detergents, water, heat, etc on your paint. A "good durable" wax or sealant is defined by its ability to resist detergents thru more than a few washes. These products behave no differently when buried deep within the fibers of your towels. Anyone whos tried to strip wash a sealant knows that sometimes it takes a pretty aggressive mix of All Purpose Cleaner to get it completely removed.So knowing what kind of fight these products put up on your paint, why assume they'd be so much more easy going when bonded to a towel fiber? They aren't. This is why a stronger detergent or dedicated microfiber cleaner like Adam's Microfiber Revitalizer & Brightener is key to maintaining your towels. Removing product residues is just as important to your microfiber as any other part of their care and MFR&B was designed specifically to break down the things most commonly found in detailing towels. The types of contamination found in automotive detailing towels will be far different than the soil, food, and grime found in other towels around your home. While a dish towel might have a combination of last nights spaghetti sauce and that mystery food goo from the fridge, your detailing towels will be full of polish, wax, and sealant residues. Because of this the type of detergent you choose is important. Regular laundry soaps are still an effective option - most good detergents can remove most anything you find, or at the very least break them up enough to be effective. We've all seen the TV commercials where brand X removes grass stains, wine stains, ground in dirt - but I haven't seen one yet that says it'll remove carnauba wax and polymer sealants. Removing a grass stain from your socks is a much different proposition to removing a sealant from your towels. The option to avoid, and one incorrectly recommended by amateurs all over the web, are 'delicate' detergents like woolite. Products in this category are lacking in the areas needed to really remove all the residues found in your towels. Sure, if you need to clean a silk shirt or delicate unmentionables by all means reach for your woolite, but we're dealing with tough residues embedded deep into very tiny fibers - use a detergent capable of getting the job done. While microfiber is important, and should be cared for appropriately, it is fairly durable stuff and can handle stronger detergents to make sure they are 100% clean. Weaker detergents will continually leave behind a small amount of detailing contamination, leading to a slow buildup and eventually hampered performance. REGULAR CLEANING: Your microfiber should be cleaned after every use. While it might be tempting to let that drying towel sit and use it again next weekend you run the risk of contamination causing swirls or letting something set into the towels that will be more difficult to remove later. Cleaning microfiber is usually the least enjoyable part of a detail, but in the end staying on top of your laundry just ensures that your towels will be at their best and ready when you are. CLEANING TOWELS Always separate your dirtiest towels, like those used to clean wheels or for metal polishing, from your 'good' plush and drying towels to avoid cross contamination and wash them in separate loads. Keep cotton and other materials out of the wash loads. Wash microfiber only with other microfiber. Use a dedicated microfiber detergent like Microfiber Revitalizer or a dye free/perfume free liquid laundry soap - no powders or granulated. Set washer to a warm water setting. Some heat is required to break down waxes and polishes. Cold settings will not clean towels as effectively. If your washer is equipped with an extra rinse cycle, use it. This will make sure as much of the contamination and remaining soap is removed from the towels as possible. Microfiber can be machine dried if you prefer, use a low heat setting and NO FABRIC SOFTENER. Air or line drying is also an option, be sure to do this somewhere the towels cannot be contaminated with dust or lint. MICROFIBER PADS & APPLICATORS Just like with towels, separate any extremely dirty or contaminated pads from the group and wash separately to avoid cross contamination. Wash pads and applicators separate from towels. The foam backing and velcro can become snagged and damaged during agitation by a towel in the same load. Use a brush to break up heavy, caked in, polish residues on pads before washing. Microfiber Revitalizer is preferred, but if using regular laundry soap make sure its dye/perfume free. Set washer to a warm setting, not hot. Pads have a glue membrane that is sensitive to high heat so stick to warm wash water settings. Air dry all pads and applicators on a wire rack to maximize airflow and expedite drying. HEAVY STAINS AND CONTAMINATION: No matter what there is going to be occasions where a towel becomes extremely contaminated or stained from either something you removed from a vehicle (grease, oil, tar, etc) or it becomes saturated with a product to the point there is some discoloration. In these situations pre-treating or at the very minimum pre-soaking the microfiber to keep these stains from setting in is key. Obviously, you can't stop mid-detail and clean your microfiber accessories, so here are some quick tips to help with heavier contamination on the fly. Pre-treat any towel that becomes heavily soiled with grease, oil, brake dust, etc - spray liberally with All Purpose Cleaner or Microfiber Revitalizer. Soak the heaviest contamination and rub the towel against itself to agitate, then set aside for cleaning later. Pre-soak towels to help start the cleaning process long before you get around to doing your detail laundry. Prep a separate bucket with clean water and add 2-3oz of Microfiber Revitalizer. As towels become too dirty to continue using toss them into the pre-soak bucket. Place a grit guard, upside down and ON TOP of the towels after they've been put in the mix to hold them in the solution as they try to float to the top. For microfiber polishing pads or applicators use a stiff brush, like the pad conditioning brush, to break up residues before they harden and set in. Pads can also be added to your pre-soak bucket if desired. If a towel ever becomes so contaminated that it doesn't wash clean, it may be time to retire it to a new job. Rotate towels that have been heavily stained to less delicate tasks. MICROFIBER STORAGE: Where your towels are kept when they are not in use is just as important as how they are cared for, so make sure you have a solution for keeping your towels out of harms way and dust free between uses. Plastic storage totes are an inexpensive solution - the lid will keep your towels from collecting dust in an area like a garage and will also minimize the amount of crawly insects that might find a new home buried in all that plush softness. Always be sure your microfiber is completely dry before storage. Mildew will form on towels in some climates if they are even slightly damp. This is especially true of microfiber applicators and pads. The foam backing and cores is a magnet for moisture avoid using air tight containers for anything with a foam core or backing unless you are completely confident it is dry all the way through. BOILING YOUR TOWELS: Over time your microfiber may become contaminated past the point it can be completely cleaned using traditional methods. Typically this will present itself during use - drying towels will begin to feel less absorbent. Plush towels may lint slightly or smear products more than remove them. This is an indication that the fibers are 'full' either from residues deposited during use or things like fabric softener accidentally introduced during cleaning. In any event, if your towels begin to loose their performance or just don't feel as good as they did new boiling is the solution, the last resort, to bring them back. NOTE: this process applies only to towels and microfiber without foam cores or backing. Never boil pads or applicators. Fill a large cooking pot approximately 2/3rd full of water and bring to a boil Add approximately 1-2oz of distilled white vinegar per gallon of water and stir Place a few of the towels to be treated into the pot, maintaining a slow boil Stir continuously with a large spoon, avoid letting the towels rest against the bottom or sides for too long After about 60-90 seconds in the boil, remove the towels using tongs and rinse under cool water Wash using the "Regular Cleaning" guidelines outlined earlier and they should be as good as new. NOTE: Should boiling fail to bring absorbancy to a towel or the towel continues to lint then you are most likely dealing with a towel at the end of its lifespan. Retire the towel to less important tasks and replace with a new one for future use. HOW LONG WILL A TOWEL LAST? There really is no set answer to that question. Depending on how frequently they are used, how well they are cared for, and the types of products they're used with a towel can last for a very short or very long time. On average a towel should last the average user at least a year or two. Understand that no towels are good forever, they wear out eventually like any other product that sees frequent use. If you experience diminished performance after some time and try the recommended boiling method it might be time to retire that towel and replace it with a new one. Your vehicle is a big investment and towels by comparison are a relatively small price in making sure it stays looking nice. One thing is for certain - the better care you take of your microfiber towels and accessories, the better they'll do at caring for your vehicles. Beemer, TheWolf, Anfernee and 9 others 12 Link to comment Share on other sites More sharing options...
MMHayden13 Posted March 6, 2015 Share Posted March 6, 2015 This is great stuff right here! Link to comment Share on other sites More sharing options...
TheWolf Posted March 6, 2015 Share Posted March 6, 2015 Excellent write-up Dylan! One additional tip is to make sure your washing machine and dryer are clean, so no cross-contamination occurs. Before washing your MF towels, run a clean-cycle on the washer with some distilled white vinegar to break down the build-up of detergents and fabric softeners inside the machine. Since MFR&B is a stronger detergent than regular laundry soap, it will break down the build-up in the washer and mix it into your load of MF towels, unless you clean the washer first. The dryer can contain contaminants from other loads, such as rags, rugs or even worse, clothes with GLITTER!. A quick vacuum of the dryer along with a wipe-down can prevent your clean MF towels from be contaminated with stuff that can cause damage when used on your paint. LFairbanks, mc2hill and Team Adam's 3 Link to comment Share on other sites More sharing options...
mdolandese Posted March 7, 2015 Share Posted March 7, 2015 AWESOME write up SHINE DOC Great info here. Def make sure your washer is clear and clean of everything and anything before you wash your microfiber towels you never know what's still in there. Great point!!! Link to comment Share on other sites More sharing options...
Natch02 Posted March 7, 2015 Share Posted March 7, 2015 Thank you for the thread. Answered what few questions I had. Link to comment Share on other sites More sharing options...
Junior Posted March 7, 2015 Share Posted March 7, 2015 Dude is dropping science Link to comment Share on other sites More sharing options...
GXPaycheck Posted March 7, 2015 Share Posted March 7, 2015 Glad you posted this! Link to comment Share on other sites More sharing options...
Adam Posted March 7, 2015 Share Posted March 7, 2015 Strong write-up my man!!! tmevilsizor 1 Link to comment Share on other sites More sharing options...
07stanggt Posted March 11, 2015 Share Posted March 11, 2015 That some good writing right there !! Link to comment Share on other sites More sharing options...
kitt1987 Posted March 13, 2015 Share Posted March 13, 2015 Great advice, silly question is it ok to wash the glass cleaning MF towels with the other towels? Link to comment Share on other sites More sharing options...
PT3 Posted March 13, 2015 Share Posted March 13, 2015 (edited) This guy is awesome! I'm placing an order for the Revitalizer now. I didn't realize how crucial it was! Edited March 13, 2015 by PhilT3 2014 BMW M5 Link to comment Share on other sites More sharing options...
Ricky Bobby Posted March 13, 2015 Share Posted March 13, 2015 Absolutely Phil its like protecting your MF investment. Use it as a pre-treater and as a standalone detergent in the wash. Hell its probably strong enough to do some heavy duty tire cleaning LOL Link to comment Share on other sites More sharing options...
PT3 Posted March 14, 2015 Share Posted March 14, 2015 Absolutely Phil its like protecting your MF investment. Use it as a pre-treater and as a standalone detergent in the wash. Hell its probably strong enough to do some heavy duty tire cleaning LOL Thanks Jason! Link to comment Share on other sites More sharing options...
rcibotti5986 Posted August 12, 2015 Share Posted August 12, 2015 Great read...and time to add some microfiber revitalizer to my list Link to comment Share on other sites More sharing options...
derek1387 Posted November 1, 2015 Share Posted November 1, 2015 Is it OK to wash towels together that were used with different products? Like wash a towel that was used with Interior Detailer along side a towel that was used with window cleaner, and a towel that was used with Detail Spray? Or do they all need to be separate? Link to comment Share on other sites More sharing options...
TheWolf Posted November 1, 2015 Share Posted November 1, 2015 Is it OK to wash towels together that were used with different products? Like wash a towel that was used with Interior Detailer along side a towel that was used with window cleaner, and a towel that was used with Detail Spray? Or do they all need to be separate? You can wash them together. I only separate the towels by use, to wash the towels for paint by themselves and then the dirtiest ones from wheels and jambs in the next load. derek1387 1 Link to comment Share on other sites More sharing options...
derek1387 Posted November 2, 2015 Share Posted November 2, 2015 Thanks. This forum has been incredibly helpful so far and I appreciate everything! Even though I keep spending more money... TheWolf 1 Link to comment Share on other sites More sharing options...
red94chev Posted November 2, 2015 Share Posted November 2, 2015 Having a little issue here that's been going on for a while. I washed a load this weekend mostly double softs and various color edgeless towels, some single softs, and a few glass towels. These towels were fairly clean, mainly detail spray wipedowns and H2OGG applications. (Most of these towels have been used less than 5 times, no really dirty jobs, fairly fresh) Ran a cleaning cycle in the washer with 2 oz distilled vinegar. Then washed all the towels together with about 1.5 oz of Microfiber Revitalizer and 1.5 oz of vinegar. I pull them out and they look nice and clean. Then i throw them in the dryer on the light heat cycle, no fabric softener or anything. Then I washed the truck, dried truck with large grey plush towel (another company), all is fine. Pull out an orange edgeless towel to match my new pumpkin detail spray, and its leaving a noticeable trail of lint behind it. Now all these towels are in great condition and washed the same every time but I've been getting this lint for a few washes now. I don't believe that the towels are going bad. Is it possible that they are picking up lint from the dryer? (I don't clean it out or anything, just empty the lint tray with the screen) I'm planning on doing a wash soon and hanging them to dry that way to see what happens but what are your thoughts? Link to comment Share on other sites More sharing options...
LT1xL82 Posted November 2, 2015 Share Posted November 2, 2015 ...Even though I keep spending more money... I experience the same thing. Not that I am paranoid or anything, but I'm pretty sure this forum is a front for team Adam's to send secret buy signals to the chip that the government placed in my head when I was peacefully sleeping after using Pumpkin Spice Detail Spray. Dan@Adams 1 Link to comment Share on other sites More sharing options...
MaStA Posted November 3, 2015 Share Posted November 3, 2015 I keep buying, buying, buying as well...sales here and there I keep stocking up. I'm working on filling up a full tub worth of polishing pads. Dan@Adams 1 Link to comment Share on other sites More sharing options...
Dan@Adams Posted November 3, 2015 Share Posted November 3, 2015 Having a little issue here that's been going on for a while. I washed a load this weekend mostly double softs and various color edgeless towels, some single softs, and a few glass towels. These towels were fairly clean, mainly detail spray wipedowns and H2OGG applications. (Most of these towels have been used less than 5 times, no really dirty jobs, fairly fresh) Ran a cleaning cycle in the washer with 2 oz distilled vinegar. Then washed all the towels together with about 1.5 oz of Microfiber Revitalizer and 1.5 oz of vinegar. I pull them out and they look nice and clean. Then i throw them in the dryer on the light heat cycle, no fabric softener or anything. Then I washed the truck, dried truck with large grey plush towel (another company), all is fine. Pull out an orange edgeless towel to match my new pumpkin detail spray, and its leaving a noticeable trail of lint behind it. Now all these towels are in great condition and washed the same every time but I've been getting this lint for a few washes now. I don't believe that the towels are going bad. Is it possible that they are picking up lint from the dryer? (I don't clean it out or anything, just empty the lint tray with the screen) I'm planning on doing a wash soon and hanging them to dry that way to see what happens but what are your thoughts? Hi Jake, if the towels are linting a significant amount, it is possible that one of the towels was contaminated and then affected more towels when you washed them. You could try thoroughly cleaning out the drum of your washing machine and dryer and then going through another wash cycle, but if that doesn't work you may have to resort to boiling the problematic towels as described in the write-up above to resolve the issue. The only towels I've ever really had minor linting issues with are some of my Glass Towels that are 4+ years old now (the old green ones), and I wash various Adam's towels together, using only Microfiber Revitalizer and Brightener in my HE washing machine. I will point BRZN (Dave) over to this thread in the morning to see if he has any other thoughts or input - he has taught me a lot about proper microfiber care over the years red94chev 1 Link to comment Share on other sites More sharing options...
TheWolf Posted November 3, 2015 Share Posted November 3, 2015 Ran a cleaning cycle in the washer with 2 oz distilled vinegar. Then washed all the towels together with about 1.5 oz of Microfiber Revitalizer and 1.5 oz of vinegar. I pull them out and they look nice and clean. Then i throw them in the dryer on the light heat cycle, no fabric softener or anything. Jake, are you using the MRB at the same time as the vinegar in the wash cycle? Typically, the MRB would put into the detergent cup, which then gets used in the wash cycle, and then the vinegar would go into the cup label "Fabric Softener" and get used in the rinse cycle If you put them into the wash at the same time, the vinegar will work against the MRB. Vinegar in the rinse cycle by itself serves to help remove the detergent from the towels, and can also help remove any minerals that are leftover from your water. red94chev 1 Link to comment Share on other sites More sharing options...
red94chev Posted November 3, 2015 Share Posted November 3, 2015 Jake, are you using the MRB at the same time as the vinegar in the wash cycle? Typically, the MRB would put into the detergent cup, which then gets used in the wash cycle, and then the vinegar would go into the cup label "Fabric Softener" and get used in the rinse cycle If you put them into the wash at the same time, the vinegar will work against the MRB. Vinegar in the rinse cycle by itself serves to help remove the detergent from the towels, and can also help remove any minerals that are leftover from your water. Yes, I have been using them mixed together in the wash cycle. I think I will rewash them like you say and see what happens. TheWolf 1 Link to comment Share on other sites More sharing options...
red94chev Posted November 3, 2015 Share Posted November 3, 2015 Hi Jake, if the towels are linting a significant amount, it is possible that one of the towels was contaminated and then affected more towels when you washed them. You could try thoroughly cleaning out the drum of your washing machine and dryer and then going through another wash cycle, but if that doesn't work you may have to resort to boiling the problematic towels as described in the write-up above to resolve the issue. The only towels I've ever really had minor linting issues with are some of my Glass Towels that are 4+ years old now (the old green ones), and I wash various Adam's towels together, using only Microfiber Revitalizer and Brightener in my HE washing machine. I will point BRZN (Dave) over to this thread in the morning to see if he has any other thoughts or input - he has taught me a lot about proper microfiber care over the years A good cleaning of the drum is probably a good idea, this thing has had quite a workout over the years. Link to comment Share on other sites More sharing options...
MaStA Posted November 3, 2015 Share Posted November 3, 2015 Is it a front loader or top loader? In the front loading machines there are tablets you can use to clean the drum. I use one called Affresh in mine and it works quite well. Link to comment Share on other sites More sharing options...
