StubStang Posted April 2, 2015 Share Posted April 2, 2015 Writing my thoughts on a few different products: Long handle wheel brush: worked very well, created suds/ bubbles when used with green wheel cleaner, got rid of the dirt inside lug-nut areas also. Paint Sealant: Easy to apply, easy to remove after hazing properly. As a result, the paint looked event better than with what I normally used. New blue clay bar: After using the first generation clay bar compared to the blue one, I am convinced that the blue clay bar is more efficient than the older material. The older material had stuck to my hand and was way more time consuming (three times more time used than the blue clay bar) although the results were practically the same. Rinse and wash label buckets: easy to remember which was used for soap and rinsing. good idea! Adams is still my number one car product in my book, the results are the proof as to why!! ramflava and Rich 2 Link to comment Share on other sites More sharing options...
Ricky Bobby Posted April 2, 2015 Share Posted April 2, 2015 :thumbup: I also like the Red wheel brush (I got the short handle), I have a full unused clay bar but will get a blue one eventually. StubStang 1 Link to comment Share on other sites More sharing options...
tscan Posted April 10, 2015 Share Posted April 10, 2015 Good to hear, just picked up some blue clay myself, have never used it. Link to comment Share on other sites More sharing options...
TheBurninator Posted April 10, 2015 Share Posted April 10, 2015 The blue clay is really nice after you work it for a bit. Its a bit stiffer, but as was mentioned it doesn't stick to your hand like the old clay did. Link to comment Share on other sites More sharing options...
Rich Posted April 10, 2015 Share Posted April 10, 2015 If you don't have the caddy connector for your buckets, get it. It makes life so much simpler not having to carry two buckets at separate times. http://adamspolishes.com/shop/accessories/bucket-caddy-plate-adapter.html Ricky Bobby and StubStang 2 Link to comment Share on other sites More sharing options...
StubStang Posted April 12, 2015 Author Share Posted April 12, 2015 If you don't have the caddy connector for your buckets, get it. It makes life so much simpler not having to carry two buckets at separate times. http://adamspolishes.com/shop/accessories/bucket-caddy-plate-adapter.html honestly I don't mind carrying two buckets around, good upper body and cardio work Link to comment Share on other sites More sharing options...
Rich Posted April 12, 2015 Share Posted April 12, 2015 honestly I don't mind carrying two buckets around, good upper body and cardio work Say that when you're almost 70 like me! Link to comment Share on other sites More sharing options...
