Rinseless wash questions
j-r35
So finally decided to order this and had a couple of questions.
1.Just recently washed my car (last week) and was going to use this then clay, polish, and seal.  Is it safe to go this route or am I better off doing another 2 bucket wash?
2.So can I use this to replace my waterless wash?  Any benefits on using rinse less for a waterless wash?
2 answers to this question
1.  A wash is a wash.  You can use WW, RW, or a 2 bucket.  Just use what is appropriate, if dirt is heavy, you may not want to go waterless and should consider rinseless or 2 bucket.
2. Yes, dilute 1 oz of rinseless with 16 oz of water and you essentially have WW.  Rinseless diluted into WW will give you some very minor protection and gloss where as actual WW leaves nothing behind.
An additional benefit of diluting Rinseless to make Waterless Wash is that you can change how strong your formula is. With Waterless, its only as concentrated as it comes in the bottle, while Rinseless gives you the ability to change it up depending on your current needs.
