spx1000 Posted May 2, 2015 Share Posted May 2, 2015 Hi Guy's, I know this is an open question but how many Trucks can you do out of one Bottle? Not sure if I need one or two.... Thanks Link to comment Share on other sites More sharing options...
0 Thorsager Posted May 2, 2015 Share Posted May 2, 2015 My last bottle I was able to get at least 10 vehicles. That was mainly cars though. I am also sure I use too much! A thin layer is all you need. Link to comment Share on other sites More sharing options...
0 spx1000 Posted May 2, 2015 Author Share Posted May 2, 2015 Great and Thanks!!! Link to comment Share on other sites More sharing options...
0 2Fords Posted May 2, 2015 Share Posted May 2, 2015 I've done my F250 4 times ,an F150,a Tundra ,Mustang twice,my son has done his Eclipse twice and I have about a half of bottle left. Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted May 2, 2015 Share Posted May 2, 2015 Yea it goes a long way.....less is more when it comes to LPS. Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted May 2, 2015 Share Posted May 2, 2015 Honestly even on a Suburban I don't see more than half an ounce being used, we're talking a few dots of product per panel at most. Little goes a long way, thin is in, spread it thin! Link to comment Share on other sites More sharing options...
0 spx1000 Posted May 4, 2015 Author Share Posted May 4, 2015 Thanks Guys!!!! Didn't know if I should order one or two Link to comment Share on other sites More sharing options...
0 LFairbanks Posted May 4, 2015 Share Posted May 4, 2015 (edited) Order one. You will be surprised as to how long it will last. It isn't a product that you will apply every couple weeks. I personally just apply it in the spring and in the fall. And maybe one more time in between. And just wax in between sealant applications when I feel it is necessary. I have 3 vehicles one of them being a crew cab Duramax and have had the bottle for couple years. Still have probably 2/3 to 3/4 of a bottle left. Edited May 4, 2015 by LFairbanks Link to comment Share on other sites More sharing options...
0 BitterGreg Posted May 4, 2015 Share Posted May 4, 2015 What is the cure time between coats? 30 mins? Also during the winter I use paint sealant, and will start topping with Collinite 845 for added durability. Should one or both have multiple coats, and if so does the color of the car matter? Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted May 4, 2015 Share Posted May 4, 2015 ^I'd give at least 30 mins cure time personally, if not an hour. If you are topping with Collinite 845 in winter just use that as a topper for winter maintenance, I.E. don't do coat of LPS and one of 845, then another coat of LPS, etc. However, 2 thin coats of LPS should get you through winter no problem at all, no 845 necessary. Link to comment Share on other sites More sharing options...
0 Team Adam's Posted May 4, 2015 Share Posted May 4, 2015 Hi Guy's, I know this is an open question but how many Trucks can you do out of one Bottle? Not sure if I need one or two.... Thanks I'd say you'd be fine with one... odds are anyways, by the time you need more you'll need to restock something else (applicators, towels, detail spray, or something) The advice of 'order your detail products like you buy your groceries' applies - never buy more than you think you need for a season the same way you don't grab a gallon of milk if you only drink a glass or 2 a week. Make sense? spx1000 1 Link to comment Share on other sites More sharing options...
0 Team Adam's Posted May 4, 2015 Share Posted May 4, 2015 What is the cure time between coats? 30 mins? Also during the winter I use paint sealant, and will start topping with Collinite 845 for added durability. Should one or both have multiple coats, and if so does the color of the car matter? 30 minutes recommended, but in the hot/dry months I've layered immediately with no ill effects. Never hurts to give it a few extra minutes if you can spare it though. In terms of color - doesn't really matter. Most of the 'look' comes from your prep (decon and polishing) and the LSP choice(s) will only enhance whats already there. Obviously white will never look 'deep' so applying wax in hopes of getting a deep/wet look on white or silver is like throwing your cat in the air in the hopes it sprouts wings and starts to fly. AZGTO, Ricky Bobby, spx1000 and 1 other 4 Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted May 4, 2015 Share Posted May 4, 2015 ^When polishing and sealing white paint I notice that if my eyes burn from the blindingly bright finish that the sealant leaves, that I did something right. Link to comment Share on other sites More sharing options...
0 spx1000 Posted May 4, 2015 Author Share Posted May 4, 2015 You Guy's are Great!!!!! Link to comment Share on other sites More sharing options...
0 goheels Posted May 4, 2015 Share Posted May 4, 2015 I'd say you'd be fine with one... odds are anyways, by the time you need more you'll need to restock something else (applicators, towels, detail spray, or something) The advice of 'order your detail products like you buy your groceries' applies - never buy more than you think you need for a season the same way you don't grab a gallon of milk if you only drink a glass or 2 a week. Make sense? I would also add that it my experience, by the time you need a second bottle of sealant (lasts several years in my case) Adam's may have a newer/improved formulation out. Link to comment Share on other sites More sharing options...
0 BitterGreg Posted May 4, 2015 Share Posted May 4, 2015 is like throwing your cat in the air in the hopes it sprouts wings and starts to fly. Ya but no matter how many times I try, he always lands on his feet. Link to comment Share on other sites More sharing options...
0 Team Adam's Posted May 4, 2015 Share Posted May 4, 2015 Ya but no matter how many times I try, he always lands on his feet. LOL Link to comment Share on other sites More sharing options...
0 Team Adam's Posted May 4, 2015 Share Posted May 4, 2015 I would also add that it my experience, by the time you need a second bottle of sealant (lasts several years in my case) Adam's may have a newer/improved formulation out. To that point, one additional recommendation I'd make - Get the LPS for your primary protection, also add a bottle of HGG to the process and use that to boost and layer more protection on after every few washes. Ricky Bobby 1 Link to comment Share on other sites More sharing options...
0 avvblanc01 Posted May 21, 2015 Share Posted May 21, 2015 I use the liquid paint sealant pretty much solely on trucks and SUV's since thats what I have. It lasts me a good long time, especially since the liquid paint sealant is something that you only apply every few months. My last bottle did my long bed f150 3 times, an explorer twice, a dodge ram 2500 once, a corolla once, and a tesla once and I still have a little bit left! my favorite adam's product by far! Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted May 22, 2015 Share Posted May 22, 2015 I did my 2003 X5, including glass, with my old liquid sealant 2 weeks ago and used approx 1/2 to 3/4 an ounce. Smaller cars prob 1/4 to 1/2 ounce. So I'd say at a minimum if you are using 3/4 ouce, you'll get about 24 vehicles out of one bottle. It doesn't take much product to spread a thin layer. Link to comment Share on other sites More sharing options...
spx1000
19 answers to this question
