paulsags Posted April 18, 2016 Share Posted April 18, 2016 New Member question here - I have been using detail spray after every wash while I dry the car. When (why) would I use the H2O G&G? In place of the detail spray? Thanks! Stakreysob 1 Link to comment Share on other sites More sharing options...
0 AvsBest Posted April 18, 2016 Share Posted April 18, 2016 (edited) H2O is a spray on sealant which also has high gloss hence the name. It protects your paint for 2 month or so on average. Detail Spray has no protection in it, it has several use like preventing water spots after a wash and before your dry or used as a lubricant with the clay bar. It is the equivalent of what some call "a quick detailer". You use both products at the same step in your wash sequence, but they are completely different. Some use detail spray like you do every wash but the H2O should only be used every few washes when the protection is wearing of Edited April 18, 2016 by AvsBest Link to comment Share on other sites More sharing options...
0 chops1sc Posted April 18, 2016 Share Posted April 18, 2016 When I use DS I do a pooling rinse then spray it down and dry with the Great White. When I use H20 G&G I skip the pooling rinse and do the wet method. I don't follow that up with DS for whatever reason, lol! Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted April 18, 2016 Share Posted April 18, 2016 Detail Spray is like an everyday quick detailer and gloss enhancer, a "final wipe" spray if you would. H2O is basically like a water activated, spray on and apply, less durable version of Paint Sealant - meant to be convenient to where you are actually adding sealant protection after a wash. If you applied H2O once every 2 months after a wash you would always have protection on your car. Whereas if you are just using Detail Spray and never sealing or waxing you aren't adding protection. Make sense? The guys above are all right btw as well - Always use Detail Spray when drying in order to add lubrication while drying (if you aren't applying sealant with GG) Link to comment Share on other sites More sharing options...
0 paulsags Posted April 18, 2016 Author Share Posted April 18, 2016 thank you very much - this was a big help!! Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted April 18, 2016 Share Posted April 18, 2016 Great question.....I use DS to dry with everytime I wash except once a month (providing you wash once a week) then I use H2O G&G. Link to comment Share on other sites More sharing options...
0 flyboy9994 Posted April 19, 2016 Share Posted April 19, 2016 I still use detail spray even when I use H2O. Used as the final step after H2O, it takes care of any streaks etc. I might have left behind with the H2O. Plus I just love to use the stuff anyway! Link to comment Share on other sites More sharing options...
0 j-r35 Posted April 24, 2016 Share Posted April 24, 2016 Man haven't even used my h20 gg yet. Might try it after a wash. So just spray after a wash and use a double soft to wipe off for the wet method? Also is it ok to use after i waxed a car a week ago? No hazing effect? Link to comment Share on other sites More sharing options...
0 AvsBest Posted April 24, 2016 Share Posted April 24, 2016 It won't haze. Wash without rinsing at the end. When car still wet, spray once or twice on a panel. Use damp double soft to spray evenly Use dry double soft to remove and dry at the same time. Instructions are on the bottle if you forget Link to comment Share on other sites More sharing options...
paulsags
8 answers to this question
