Booker11 Posted December 24, 2016 Share Posted December 24, 2016 I have a electric pressure washer(Simoniz Platinum 2000 psi 1.5 gpm) Will the Adam's foam cannon perform just as well as the MTM foam cannon(14.0349) rated for electric low pressure washers? Link to comment Share on other sites More sharing options...
0 Dan@Adams Posted December 29, 2016 Share Posted December 29, 2016 Hi Rob, Thanks for contacting us, and I do apologize that no one saw this message earlier! Our Foam Cannon should work excellent with a pressure water with those specs. You may need a separate fitting or adapter to make it work with that one if the pressure washer does not already have a quick connect fitting on the pressure washer wand. Give it a try and if you are not fully satisfied with the results, we have our 110% satisfaction guarantee that you can use Link to comment Share on other sites More sharing options...
Booker11
1 answer to this question
