Dan@Adams Posted January 10, 2017 Share Posted January 10, 2017 This isn't a huge new product announcement, but it's an important one that I wanted to make everyone aware of. If you haven't received an order recently, we're now shipping all 16oz spray products with an all-new spray nozzle: The new 16oz sprayers have several improvements over the old sprayer design. The old sprayers that we had worked well. Simple use - squeeze trigger and they sprayed, but as with everything, we always look to offer better products through testing and research! We have been testing these new sprayers very rigorously for over 6 months now. I do believe the cost is a little bit more than the old sprayer design per unit, but it's worth it to us to give customers a better experience when using products. This new spray nozzle sprays in a much finer, more consistent mist. The spray pattern is much better at a half-trigger pull (like how most people seem to spray products when I watch them) compared to the old sprayers, but they still work excellent at a full-pull of the trigger as well. The new sprayers also atomize our thicker liquids like H2O Guard & Gloss, Tire Shine, and Wheel Cleaner better as well, again giving a more consistent spray pattern. While the nozzle adjuster itself has the same indication symbol for stream or mist, they do still have both spray settings and two off (STOP) positions. With our old sprayers, the spray trigger could eventually fail or snap off from too many uses; however with these new sprayers, even after hundreds and hundreds of sprays of purposely trying to break the triggers in testing, they kept going strong! The new trigger also requires less effort to pull than the older sprayer, which can make a difference in fingers cramping up when spraying a lot in succession, like with Waterless Wash, Wheel Cleaner, etc. These sprayers have a more natural fit to your hand, with finger grips molded into the spray trigger. The sprayers may arrive in your shipment in two pieces. Simply take the flat portion of the stem and insert it into the bottom of the sprayer head until it snaps in place. The curved end in the above picture should go down into the bottle. The stem of the sprayer is also slightly longer than the 16oz bottle to ensure that you get as much as possible out of the bottle before having to refill. Lastly, we've done tests of hanging bottles upside-down at various angles and temperatures for a few days to see if they would leak, and the only leaks were the small drop or two at the end of the spray nozzle adjuster itself. Grab a 3-pack here if you don't want to wait to try them out until your next order arrives: http://adamspolishes.com/adam-s-16oz-replacement-sprayers.html I think after you use these new sprayers for a while you will see how much better they work. Let us know what you think by commenting below! Thanks to Joe T. and Benjamin F. for the great photos as usual! Chris@Adams, SumBeach35, SSilver07 and 2 others 5 Link to comment Share on other sites More sharing options...
SumBeach35 Posted January 10, 2017 Share Posted January 10, 2017 I used them recently with the glass cleaner and coverage was much more uniform across the glass. the length of the tube caught me off gaurd at first but it coiled down into the 16 oz. bottle just fine. Dan@Adams 1 Link to comment Share on other sites More sharing options...
buffalobob920 Posted January 10, 2017 Share Posted January 10, 2017 Also used them and they were more comfortable with the new grip on the handle more uniformed spray Spray nozzles were a big deal to me these are great now I have to replace about 100 of these (lol) Dan@Adams 1 Link to comment Share on other sites More sharing options...
SumBeach35 Posted January 10, 2017 Share Posted January 10, 2017 Also used them and they were more comfortable with the new grip on the handle more uniformed spray Spray nozzles were a big deal to me these are great now I have to replace about 100 of these (lol) Haha, i wont be replacing any, just using the ones i have over and over again Link to comment Share on other sites More sharing options...
neontrucks Posted January 11, 2017 Share Posted January 11, 2017 Thanks for the update. Always willing to improve, even if the product is slightly more. I love Adam's and their dedication to customer satisfaction. Dan@Adams 1 Link to comment Share on other sites More sharing options...
Rich Posted January 11, 2017 Share Posted January 11, 2017 Great. Some of the nozzles are hard to hold and spray with one hand. This should be an improvement. Dan@Adams 1 Link to comment Share on other sites More sharing options...
PHOKUS Posted January 11, 2017 Share Posted January 11, 2017 I applaud this move. The outgoing spray nozzles are large, bulky, fragile, and performed quite poorly with regards to atomization and consistency. Thanks Adams! Dan@Adams 1 Link to comment Share on other sites More sharing options...
butters Posted January 11, 2017 Share Posted January 11, 2017 I'll have to swap the sprayer that came with my rubber cleaner onto my often-used detail spray bottle to try this out, looks and sounds like a solid improvement. Any tips on how to tell if the setting is mist or stream, aside from testing with a squirt? I suppose after the first go at it, I'll mark the adjuster somehow. Dan@Adams 1 Link to comment Share on other sites More sharing options...
Rb1274 Posted January 11, 2017 Share Posted January 11, 2017 How is it Adams can make anything look sexy... those are some dam sexy spray nozzles! Dan@Adams 1 Link to comment Share on other sites More sharing options...
Dan@Adams Posted January 11, 2017 Author Share Posted January 11, 2017 I applaud this move. The outgoing spray nozzles are large, bulky, fragile, and performed quite poorly with regards to atomization and consistency. Thanks Adams! The new ones are a little wider, so I guess they're still bulky, but they sit a few millimeters shorter when on the bottle compared to the old sprayer. These new ones just feel better to me. The plastic can make a little noise when handling them, but performance overall feels better to me in every aspect. I'll have to swap the sprayer that came with my rubber cleaner onto my often-used detail spray bottle to try this out, looks and sounds like a solid improvement. Any tips on how to tell if the setting is mist or stream, aside from testing with a squirt? I suppose after the first go at it, I'll mark the adjuster somehow. If you have the new unused sprayer, all of the ones I've seen so far are sent out in the "STOP" position. If you screw it onto the bottle and you're holding the bottle out in front of you like you would to spray it, turning the nozzle 90 degrees to the left (counter-clockwise) will put it on the MIST setting, and turning it 90 degrees to the right (clockwise) will put it to the STREAM setting. Alternatively, if you're looking directly at the end of the sprayer, like this picture below, turning to the right (clockwise) will be the MIST setting, and turning to the left (counter-clockwise) will be the STREAM setting: I'm not saying every sprayer will absolutely be sent out this way, since we receive them from a manufacturing company, but the above has been my experience so far How is it Adams can make anything look sexy... those are some dam sexy spray nozzles! Joe and Benjamin both have a great eye for photography no doubt! To me, these sprayers look almost modern and retro looking at the same time, just like the new company logo design we switched to last year! Link to comment Share on other sites More sharing options...
Kingsford Posted January 11, 2017 Share Posted January 11, 2017 If these are the same Nozzles I have, I love them. Been using them for about a month or two now with Detail Spray and HGG. Nice pattern, comfortable on the hand, and they seem sturdy. Dan@Adams 1 Link to comment Share on other sites More sharing options...
Dan@Adams Posted January 11, 2017 Author Share Posted January 11, 2017 If these are the same Nozzles I have, I love them. Been using them for about a month or two now with Detail Spray and HGG. Nice pattern, comfortable on the hand, and they seem sturdy. They sure are, these are the same as the ones I sent you back then for troubleshooting and testing! Kingsford 1 Link to comment Share on other sites More sharing options...
chops1sc Posted January 11, 2017 Share Posted January 11, 2017 The new ones are a little wider, so I guess they're still bulky, but they sit a few millimeters shorter when on the bottle compared to the old sprayer. These new ones just feel better to me. The plastic can make a little noise when handling them, but performance overall feels better to me in every aspect. If you have the new unused sprayer, all of the ones I've seen so far are sent out in the "STOP" position. If you screw it onto the bottle and you're holding the bottle out in front of you like you would to spray it, turning the nozzle 90 degrees to the left (counter-clockwise) will put it on the MIST setting, and turning it 90 degrees to the right (clockwise) will put it to the STREAM setting. Alternatively, if you're looking directly at the end of the sprayer, like this picture below, turning to the right (clockwise) will be the MIST setting, and turning to the left (counter-clockwise) will be the STREAM setting: I'm not saying every sprayer will absolutely be sent out this way, since we receive them from a manufacturing company, but the above has been my experience so far Joe and Benjamin both have a great eye for photography no doubt! To me, these sprayers look almost modern and retro looking at the same time, just like the new company logo design we switched to last year! Looking at this picture, you can see a spray pattern on the nozzle. Do they not have this on them? Link to comment Share on other sites More sharing options...
Dan@Adams Posted January 11, 2017 Author Share Posted January 11, 2017 Looking at this picture, you can see a spray pattern on the nozzle. Do they not have this on them? Yes, but they have this symbol twice, for both the mist and stream setting, so there isn't a quick way to distinguish between the two settings other testing out with one spray. I very quickly got into the habit of "turn left for mist" when I put them on the bottle, and then turning right to go back to the STOP position. This way I'll never accidentally use a stream setting when I don't want to. Link to comment Share on other sites More sharing options...
falcaineer Posted January 13, 2017 Share Posted January 13, 2017 (edited) I got a few of these recently and look forward to trying them out. Adams can always be counted on to look for improvements! Thanks team! Edited January 13, 2017 by falcaineer Dan@Adams 1 Link to comment Share on other sites More sharing options...
Rb1274 Posted January 13, 2017 Share Posted January 13, 2017 Finally got all of the squeeze nozzles the same now I have to order more of the new nozzles. Hate when things are different. Dan@Adams 1 Link to comment Share on other sites More sharing options...
quebert Posted February 4, 2017 Share Posted February 4, 2017 Just ordered 4 Adam's things from detailing.com yesterday, then I see see thread an hour after. Hope the bottles come with these new sprayers, they look really nice/ Link to comment Share on other sites More sharing options...
fshelton79 Posted February 4, 2017 Share Posted February 4, 2017 I didn't realize they were longer on purpose and have been trimming the tube. ???? Link to comment Share on other sites More sharing options...
Focus_Red Posted February 20, 2017 Share Posted February 20, 2017 I received two of these nozzles with the new details spray and honestly was disappointed. I love the fine even mist spray, however when I release the trigger after spraying, 4-5 drops drip out the nozzle. Every time. It's quite annoying, especially when I simply want a quick spray. I tested the same detail spray bottle with an old extra sprayer and it didn't do this. No idea why. Also I wish you could tell if it was a spray or a stream like the old sprayers. The same pattern on both stream and spray makes it kind of annoying. Link to comment Share on other sites More sharing options...
LuckyKorean Posted January 23, 2019 Share Posted January 23, 2019 @Dan@Adams Sorry if I’m bumping old thread but what happened to these sprayers? They look lot better aesthetically since the Adam’s “A” is curved lol. I haven’t gotten any of them in recent orders. Link to comment Share on other sites More sharing options...
falcaineer Posted January 23, 2019 Share Posted January 23, 2019 1 minute ago, LuckyKorean said: @Dan@Adams Sorry if I’m bumping old thread but what happened to these sprayers? They look lot better aesthetically since the Adam’s “A” is curved lol. I haven’t gotten any of them in recent orders. They leaked, so Adam's went back to the original boxy ones. LuckyKorean and DaleH 2 Link to comment Share on other sites More sharing options...
catman600 Posted January 23, 2019 Share Posted January 23, 2019 I remember way back when that I had gotten several and they leaked. I use the boxy style ones and pass along the rounded ones I have, not a fan of them. Link to comment Share on other sites More sharing options...
Dan@Adams Posted January 28, 2019 Author Share Posted January 28, 2019 Yes, unfortunately these sprayers gave a very nice misting pattern, but the quality control on some batches that we received were not up to our standards, so we reverted back to the previous sprayer design. Lately I've been using the Pressurized Multi-Sprayer and the Pressurized 1.5 Foam Sprayer for quite a good bit of my exterior products like Waterless Wash, Detail Spray, and Iron Remover for the Multi-Sprayer, and Wheel Cleaner, Tire & Rubber Cleaner, and Eco APC for the Foaming Sprayer. They make for an easier detail session for me! Link to comment Share on other sites More sharing options...
