H2O Guard and Gloss
Mbrazelton
4 answers to this question
There's a wet and dry method to applying the HGG. Dry application is what you're basically asking about. You start with a dry car, wet a towel, spray the HGG into the towel, and wipe directly onto the car. It works, but you may find you'll use a lot more product.
P.S. Welcome to the addiction! Be sure to go introduce yourself in the new member forum.
Edited by falcaineer
It might not be the fastest because then you have to dry the car twice, but you could always wet the car down again at home with a garden sprayer filled with just water, although when using h20 g&g I find it really doesn't take that long when the car is wet.
Edited by Nathan
Agreed with both Rich and Nathan. I should probably clarify a bit, though, since they offer good advice. The dry application method will work if you don't want to bother getting the car wet again, regardless of how (sprayer, hose, licking the car :wacko:). It you want to get it wet again first, Rich and Nathan are spot on. Either way, you'll need another dry towel to dry after applying the HGG.
