philhibner Posted May 22, 2017 Share Posted May 22, 2017 Anyone experience negative results using clay on a coated surface? Hit a patch of bugs last night and wanted to know if it would cause any harm. Link to comment Share on other sites More sharing options...
0 PostalTwo Posted May 22, 2017 Share Posted May 22, 2017 I can't imagine clay harming a coating. Link to comment Share on other sites More sharing options...
0 Nathan Posted May 22, 2017 Share Posted May 22, 2017 (edited) You can clay over a ceramic coating, the coatings bond much better to the paint, they can only be removed over time by wearing off or by polishing them off. But I recommend presoaking the bugs with WW instead. Edited May 24, 2017 by Nathan Link to comment Share on other sites More sharing options...
0 shane@detailedreflections Posted May 22, 2017 Share Posted May 22, 2017 Use A LOT of lubricant though. Coatings are not immune to marring. They won't come off, but they can be damaged. Nathan and tmevilsizor 2 Link to comment Share on other sites More sharing options...
0 ledger64 Posted May 22, 2017 Share Posted May 22, 2017 claying would in my mind be a last ditch effort. What else have you tried LT1xL82 1 Link to comment Share on other sites More sharing options...
0 tmevilsizor Posted May 22, 2017 Share Posted May 22, 2017 Phil, You shouldn't need to clay your paint with a coating on it. Honestly, a little waterless wash should remove them. If they are still stuck on, simply spray some WW and allow it to soften the bugs. I have found the above method to be successful. I see you're from Midwest Ohio. I'm from Urbana/Springfield area myself. I work in Dublin. Anyone experience negative results using clay on a coated surface? Hit a patch of bugs last night and wanted to know if it would cause any harm. LT1xL82 and philhibner 2 Link to comment Share on other sites More sharing options...
0 Hupp2it Posted May 22, 2017 Share Posted May 22, 2017 Use A LOT of lubricant though. Coatings are not immune to marring. They won't come off, but they can be damaged. Yeah, this happened to me at the track. Flying clag scuffed the hood hard enough to mess up the coating. Revive couldn't get it out so it's gonna stay until I re-apply the coating after HPDE fun. Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted May 22, 2017 Share Posted May 22, 2017 I agree you shouldn't need to clay the bugs, the coating makes your paint so slick WW should remove them. Link to comment Share on other sites More sharing options...
0 philhibner Posted May 23, 2017 Author Share Posted May 23, 2017 Phil, You shouldn't need to clay your paint with a coating on it. Honestly, a little waterless wash should remove them. If they are still stuck on, simply spray some WW and allow it to soften the bugs. I have found the above method to be successful. I see you're from Midwest Ohio. I'm from Urbana/Springfield area myself. I work in Dublin. I live north of Dayton about an hour! I agree you shouldn't need to clay the bugs, the coating makes your paint so slick WW should remove them. I hadn't tried to remove them yet. In the past, claying worked the best, so I wanted to confirm before I tried. I ended up using the method you guys suggested and it worked like a charm. Love this coating stuff! tmevilsizor 1 Link to comment Share on other sites More sharing options...
0 mc2hill Posted May 23, 2017 Share Posted May 23, 2017 I am with the 'do not use clay to remove them' group. The coating is bonded to the surface, and can only be removed with mechanical abrasion, so apply a strong chemical (APC, WC, a bug-remover, etc.) to the bugs, if the other methods don't work. With PS or wax, a bug-remover would take off the protection, but you do not have that worry with a coating. Link to comment Share on other sites More sharing options...
philhibner
9 answers to this question
