Southern Car Parts Posted May 23, 2017 Share Posted May 23, 2017 I just picked up a 2009 GMC Envoy and the exterior plastic is all faded. What has everyone had the best luck with. I dont want any that leaves oily residue. Thanks for the advice Paul Morris Marketing/Sales 1-888-631-1433 ext. 101 www.southerncarparts.com Link to comment Share on other sites More sharing options...
0 shane@detailedreflections Posted May 23, 2017 Share Posted May 23, 2017 Clean it with Tire & Rubber Cleaner to remove any oxidation. From there you can either ceramic coat it for long lasting restoration of color and protection. Or you can use VRT to remoisturize it. It'll probably take a few coats to make it look even. And even then you'll probably still have to reapply it frequently. That will give you the look you're looking for. Ceramic is probably your best option for the least maintenance and residue. But know that preparation is EVERYTHING. Dan@Adams 1 Link to comment Share on other sites More sharing options...
0 Dan@Adams Posted May 23, 2017 Share Posted May 23, 2017 Hi Paul, our VRT will keep your exterior plastic trim dark and conditioned, and will not leave a greasy or oily film behind. A more permanent solution would be our Ceramic Trim Coating Kit, which forms a semi-permanent bond on the textured plastic areas that will last upwards of 2 years. vm1971 1 Link to comment Share on other sites More sharing options...
0 frosty350 Posted May 23, 2017 Share Posted May 23, 2017 I agree with the comments above I have a 2011 Yukon and I use the VRT on all the black plastics and it looks good, black and non greasy. But last weekend I cleaned the plastics with Tire & Rubber cleaner and then applied VRT and they look even darker and it seems to last longer. Nickfire20 1 Link to comment Share on other sites More sharing options...
0 ocdrifter Posted May 23, 2017 Share Posted May 23, 2017 I also concur with the comments above, I use the VRT, it give me something to do, during my therapy sessions. Link to comment Share on other sites More sharing options...
0 LT1xL82 Posted May 23, 2017 Share Posted May 23, 2017 VRT works well...as does H2O G&G. Link to comment Share on other sites More sharing options...
0 Mariner Posted May 23, 2017 Share Posted May 23, 2017 I used the Trim Coating on my lower rocker trim and mudflaps and looks great, so that gets my vote. LT1xL82 1 Link to comment Share on other sites More sharing options...
0 vm1971 Posted May 24, 2017 Share Posted May 24, 2017 Hi Paul, our VRT will keep your exterior plastic trim dark and conditioned, and will not leave a greasy or oily film behind. A more permanent solution would be our Ceramic Trim Coating Kit, which forms a semi-permanent bond on the textured plastic areas that will last upwards of 2 years. EXACTLY as stated above. Most certainly! even VRT has done miracles on the worst faded black trim ive ever seen (an OLD corolla, a beaten up VUE)... but yes, the coating method will keep it tidy for MUCH longer! Link to comment Share on other sites More sharing options...
0 Southern Car Parts Posted May 24, 2017 Author Share Posted May 24, 2017 Thanks guys Ill give it a try Paul Morris Marketing/Sales 1-888-631-1433 ext. 101 www.southerncarparts.com vm1971 1 Link to comment Share on other sites More sharing options...
0 vm1971 Posted May 24, 2017 Share Posted May 24, 2017 Thanks guys Ill give it a try Paul Morris Marketing/Sales 1-888-631-1433 ext. 101 www.southerncarparts.com VRT has amazed friends and clients all by itself.. but again.. .coatings... #1 Link to comment Share on other sites More sharing options...
0 bjoeaull Posted May 25, 2017 Share Posted May 25, 2017 We recently purchased an 06 black Envoy Denali for my kitchen manager to drive. Before I gave it to her I detailed it, I used the ceramic trim coating on all plastic to revive some of the slight fading. It worked great, and looks fantastic. That was a couple months ago and today it was raining and when I walked passed it, the trim was beading like crazy! vm1971 1 Link to comment Share on other sites More sharing options...
Southern Car Parts
Paul Morris
Marketing/Sales
10 answers to this question
