Kickerz71 Posted May 25, 2017 Share Posted May 25, 2017 Received my swirl killer today, I'm super excited to give it a try. In the box I had the Allen key for the backing plate and 2 of these, image below. I didn't see in the manual what they are needed for Link to comment Share on other sites More sharing options...
Ls1transam Posted May 25, 2017 Share Posted May 25, 2017 My mini came with those. I was wondering what they were for too. Link to comment Share on other sites More sharing options...
tmevilsizor Posted May 25, 2017 Share Posted May 25, 2017 These are brushes. They eventually wear out and will need to be replaced. They make the electric motor work. When your motor stops running, you will probably just need to replace these brushes. I think the majority of buffers come with replacement brushes. Received my swirl killer today, I'm super excited to give it a try.In the box I had the Allen key for the backing plate and 2 of these, image below. I didn't see in the manual what they are needed for Dan@Adams and Kickerz71 2 Link to comment Share on other sites More sharing options...
zapdon Posted May 25, 2017 Share Posted May 25, 2017 I don't remember getting these with mine, might have to take a double take in the box. Link to comment Share on other sites More sharing options...
Kickerz71 Posted May 25, 2017 Author Share Posted May 25, 2017 I don't remember getting these with mine, might have to take a double take in the box. These were in the same bag as the Allen key Link to comment Share on other sites More sharing options...
Kickerz71 Posted May 25, 2017 Author Share Posted May 25, 2017 These are brushes. They eventually wear out and will need to be replaced. They make the electric motor work. When your motor stops running, you will probably just need to replace these brushes. I think the majority of buffers come with replacement brushes. Thanks, I assume these burn out often enough for them to include 2. Link to comment Share on other sites More sharing options...
TheWolf Posted May 25, 2017 Share Posted May 25, 2017 Thanks, I assume these burn out often enough for them to include 2. The motor uses two brushes, one for each pole. When the brushes wear out, then you would replace both. Kickerz71 1 Link to comment Share on other sites More sharing options...
jessewsmith Posted May 25, 2017 Share Posted May 25, 2017 They probably didn't include them because they wear out a lot, they probably put them in the box so if they stopped working you would just change them out and not have to wait to get a replacement. It would suck if it happened while doing a vehicle and then have to wait for them to send a replacement. Kickerz71 1 Link to comment Share on other sites More sharing options...
Kickerz71 Posted May 25, 2017 Author Share Posted May 25, 2017 Are these covered by warranty? Link to comment Share on other sites More sharing options...
PostalTwo Posted May 25, 2017 Share Posted May 25, 2017 Brushes are generally considered a wear item like brakes in a car and are not warranty. For the average enthusiasts they will not wear these out within the warranty period anyway . Link to comment Share on other sites More sharing options...
