MrRaspberryJam Posted July 20, 2017 Share Posted July 20, 2017 Been trying to work out these marks for awhile now after getting my headlight kit and for some reason they're just not coming out. Granted they are a lot better compared to when I started but this is the best I can get. Any ideas? Thanks Link to comment Share on other sites More sharing options...
0 Nathan Posted July 20, 2017 Share Posted July 20, 2017 Do they catch your fingernail when you run it across? Link to comment Share on other sites More sharing options...
0 falcaineer Posted July 20, 2017 Share Posted July 20, 2017 Are they rock chips? And/or on your headlights? Hard to tell from the close-up on the first and angle of the second. Nathan 1 Link to comment Share on other sites More sharing options...
0 Chonke Posted July 20, 2017 Share Posted July 20, 2017 Kinda looks like its a paint scratch deep into the primer. If so, then compounding or polishing wont work. There was a similar thread earlier, and it looks like a paint repair pen is the only easy choice besides a shop. Link to comment Share on other sites More sharing options...
0 Nathan Posted July 20, 2017 Share Posted July 20, 2017 Like others said, probaby deep scratch, use a touch up paint pen from the dealer, apply with paint touch up sticks, 2 coats clear coat. Next, wet sand with 3000, polish out wetsanding marks, finally protect it again. Let it dry between coats and before wet sanding. Link to comment Share on other sites More sharing options...
0 Dan@Adams Posted July 20, 2017 Share Posted July 20, 2017 Those look like paint gouges down to the bare plastic underneath. I'm assuming that is a front bumper from the picture? Unfortunately those will need to be filled in with touch-up paint. I would try to fill them with multiple thin layers, allow to cure, then if you're comfortable with it, wet-sand them down, and then polish back out. Wet-sanding can be tricky and damaging if you sand down too far. Having the area sanded, re-primed, re-painted/blended by a body-shop would be the best solution to making it look new again. Nathan, tmevilsizor, Rich and 2 others 5 Link to comment Share on other sites More sharing options...
0 Kingsford Posted July 20, 2017 Share Posted July 20, 2017 Dr ColorChip and do what Dan said if you aren't going to go the repaint way. Link to comment Share on other sites More sharing options...
0 ledger64 Posted July 20, 2017 Share Posted July 20, 2017 (edited) Those look like paint gouges down to the bare plastic underneath. I'm assuming that is a front bumper from the picture? Unfortunately those will need to be filled in with touch-up paint. I would try to fill them with multiple thin layers, allow to cure, then if you're comfortable with it, wet-sand them down, and then polish back out. Wet-sanding can be tricky and damaging if you sand down too far. Having the area sanded, re-primed, re-painted/blended by a body-shop would be the best solution to making it look new again. Dr ColorChip and do what Dan said if you aren't going to go the repaint way. agreed 100%. or learn to live with them. Edited July 20, 2017 by ledger64 Kingsford 1 Link to comment Share on other sites More sharing options...
0 MrRaspberryJam Posted July 20, 2017 Author Share Posted July 20, 2017 All great Input guys thank you!!! These marks happen to be on the rear end right under the deck lid. I kinda figured I would have to fill it in with paint but was hoping it didn't get to that point. I'll have to order a paint pen from my dealer Link to comment Share on other sites More sharing options...
0 Kingsford Posted July 20, 2017 Share Posted July 20, 2017 I'll have to order a paint pen from my dealer Dr. Colorchip kit will probably be cheaper. Link to comment Share on other sites More sharing options...
0 GXPaycheck Posted July 20, 2017 Share Posted July 20, 2017 Dr. Colorchip kit will probably be cheaper. Or Langka. Link to comment Share on other sites More sharing options...
0 Kingsford Posted July 20, 2017 Share Posted July 20, 2017 Or Langka. Langka is more expensive, doesn't come with the paint and can be more difficult to use. I've used both and prefer Dr ColorChip WAY above Langka. Link to comment Share on other sites More sharing options...
0 BrianT Posted July 20, 2017 Share Posted July 20, 2017 Looks like you got the screws from the front plate. Good luck with the fix! Link to comment Share on other sites More sharing options...
MrRaspberryJam
Thanks
12 answers to this question
