zw470 Posted July 20, 2017 Share Posted July 20, 2017 Grrrrrr I was in a rush the other day and had to leave the house about an hour after I applied Tire Shine. I thought it was dry the whole way. It was not Link to comment Share on other sites More sharing options...
0 bjoeaull Posted July 20, 2017 Share Posted July 20, 2017 i think sometimes a little sits at the edge of the tread and doesn't dry as quick. The sidekick helps with this. Link to comment Share on other sites More sharing options...
0 Ls1transam Posted July 21, 2017 Share Posted July 21, 2017 This is why I no longer use Tire Shine. VRT only for me. CadillaChick and ledger64 2 Link to comment Share on other sites More sharing options...
0 ledger64 Posted July 21, 2017 Share Posted July 21, 2017 always has been and always will be VRT for me Link to comment Share on other sites More sharing options...
0 Nathan Posted July 21, 2017 Share Posted July 21, 2017 I avoid that by first wiping with the hex tire applicator around the tire, and then up and down the tire along the groves. Seems to work good. BRZN 1 Link to comment Share on other sites More sharing options...
0 philhibner Posted July 21, 2017 Share Posted July 21, 2017 I spray the tire shine directly onto the hex applicator then apply it to the tire with the applicator. Gives it a nice even coat, without slinging issues. BRZN 1 Link to comment Share on other sites More sharing options...
0 Chonke Posted July 21, 2017 Share Posted July 21, 2017 I spray the tire shine directly onto the hex applicator then apply it to the tire with the applicator. Gives it a nice even coat, without slinging issues. I was going to ask the OP that question. Spraying on the applicator also avoids getting any overspray on the rim or paint. I also noticed you dont need much product to get a nice look. If all else fails, try those cheap microfiber towel packs from big box stores and use them exclusively for you tires. Itll be more flexible than the foam applicator, and cheap enough to throw away after a few uses philhibner 1 Link to comment Share on other sites More sharing options...
0 Nathan Posted July 21, 2017 Share Posted July 21, 2017 I was going to ask the OP that question. Spraying on the applicator also avoids getting any overspray on the rim or paint. I also noticed you dont need much product to get a nice look. If all else fails, try those cheap microfiber towel packs from big box stores and use them exclusively for you tires. Itll be more flexible than the foam applicator, and cheap enough to throw away after a few uses If you spray toward the line on the outside of the tire with a full trigger spray it works without making product go all over the wheels! Link to comment Share on other sites More sharing options...
0 Chonke Posted July 21, 2017 Share Posted July 21, 2017 If you spray toward the line on the outside of the tire with a full trigger spray it works without making product go all over the wheels! The panels are too close to the tire, itll get on the paint. Maybe on the truck that might work but I feel like all the product going into the wheel well is being wasted. Spraying the applicator has worked best for me. Nickfire20 and philhibner 2 Link to comment Share on other sites More sharing options...
0 zw470 Posted July 23, 2017 Author Share Posted July 23, 2017 In my experience, when applied with the hex-grip Tire Shine doesn't add any more "shine" than SVRT, it just smells tastier LOL. I save the SVRT for the Mustang, and only use the Tire Shine on my wife's car but with how often I get to wash it this bottle will probably last another 2 years. Link to comment Share on other sites More sharing options...
zw470
Grrrrrr
9 answers to this question
