Dknight69 Posted August 11, 2017 Share Posted August 11, 2017 How do remove it Link to comment Share on other sites More sharing options...
0 mc2hill Posted August 11, 2017 Share Posted August 11, 2017 It depends on how bad it is. Light coating should come off with 3M Adhesive Remover, or a Bug & Tar Remover, and some elbow grease. You may need to clay the area. If it is a heavy coating you may need to try a "Road Paint Remover". What ever you use, you will need reapply a sealant or wax. Here are a couple of threads on the same thing: Removing paint from lines on the road Removing road paint from wheel wells And a search for 'road paint' Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted August 11, 2017 Share Posted August 11, 2017 It depends on how bad it is. Light coating should come off with 3M Adhesive Remover, or a Bug & Tar Remover, and some elbow grease. You may need to clay the area. If it is a heavy coating you may need to try a "Road Paint Remover". What ever you use, you will need reapply a sealant or wax. Here are a couple of threads on the same thing: Removing paint from lines on the road Removing road paint from wheel wells And a search for 'road paint' Also you may want to use a plastic razor blade.......... Link to comment Share on other sites More sharing options...
0 BrianT Posted August 11, 2017 Share Posted August 11, 2017 And the faster you get it off the easier it will go! Link to comment Share on other sites More sharing options...
Dknight69
How do remove it
3 answers to this question
