Specialm5 Posted September 14, 2017 Share Posted September 14, 2017 How do you remove dog hair from your upholstery and carpet, any good tricks? Link to comment Share on other sites More sharing options...
0 Rich Posted September 14, 2017 Share Posted September 14, 2017 One of those sticky rollers works great. Or if you don't have that, wrap duct tape around your hand, sticky side out, and rub it over your seats. Vacuum cleaners with pet hair attachments work good too. mc2hill and 8675309'SS 2 Link to comment Share on other sites More sharing options...
0 Chonke Posted September 14, 2017 Share Posted September 14, 2017 I spray down the carpet with carpet and upholstery cleaner, and then lightly brush it with a horsehair brush. Then once the hairs broken free, i vacuum with a shop vac. Nitelord 1 Link to comment Share on other sites More sharing options...
0 Thorsager Posted September 14, 2017 Share Posted September 14, 2017 I use a pumice stone if it is real bad.I also have a tool that looks like a comb with several rows of rubber fingers. mc2hill, 8675309'SS, tmccoy2236 and 2 others 5 Link to comment Share on other sites More sharing options...
0 tmccoy2236 Posted September 14, 2017 Share Posted September 14, 2017 I use a pumice stone if it is real bad.I also have a tool that looks like a comb with several rows of rubber fingers. +1 - I use the exact same products. Both work well. ocdrifter and Checo 2 Link to comment Share on other sites More sharing options...
0 FrozenWS6 Posted September 14, 2017 Share Posted September 14, 2017 I will vaccume it first then use my Steamer to get the rest. I'm also thinking my Steamer attachment is getting the majority but the heat seems to help also. I wish I had a picture of the last dog hair car I did. It was bad. Link to comment Share on other sites More sharing options...
0 Mbrazelton Posted September 14, 2017 Share Posted September 14, 2017 I did one a couple weekends ago, that was bad. I sprayed it down with Carpet and Upholstery cleaner then vacuumed, then used my interior brush to pull more up. Link to comment Share on other sites More sharing options...
0 GXPaycheck Posted September 14, 2017 Share Posted September 14, 2017 My first thought was shave the dog. Nickfire20 1 Link to comment Share on other sites More sharing options...
0 vobro Posted September 15, 2017 Share Posted September 15, 2017 I have 2 huskies that shed like you wouldn't believe, even if they haven't been in the SUV in a while I'll still track it in there. I don't know what car you have but all carpet/upholstery aren't created equal, some hold the hair better then other. The best solution I've found is the rubber static type brush, the pumice stone works great also but is harsher on my carpet. If you have this issue often I'd get the rubber brush, if the hair is really bad I'll blow it out as best as I can then brush/vacuum. The best vacuum attachment is the Dyson 4" tool with the revolving brushes. Coderedpl 1 Link to comment Share on other sites More sharing options...
0 LFairbanks Posted September 15, 2017 Share Posted September 15, 2017 I have 4 GSD and have never had a problem removing dog hair. I use an attachment similar to the one in the link, minus the light. Hold it to a 45 degree angle to the carpet and sweep it side to side (left to right). Works every time. http://www.homedepot.com/p/RIDGID-1-7-8-in-LED-Lighted-Car-Nozzle-Accessory-for-Select-RIDGID-Wet-Dry-Vacs-VT1739/204960486 Link to comment Share on other sites More sharing options...
0 Audog Posted September 15, 2017 Share Posted September 15, 2017 I adapted one of those rubber brushes to an old shop vac nozzle so brush and vac at same time. Seems to work on my Golden Retriever hair. Checo 1 Link to comment Share on other sites More sharing options...
0 Bekker2 Posted November 16, 2017 Share Posted November 16, 2017 Yeah, old good duct tape. Although the problem occurs after all the all the hairs tramped into the carpet. And robovac prevent this and clean all the hairs. And there'a ton of them. Check the guide http://tenrows.com/robot-vacuum/ Link to comment Share on other sites More sharing options...
0 07stanggt Posted November 16, 2017 Share Posted November 16, 2017 I hear good things about this.... Checo 1 Link to comment Share on other sites More sharing options...
0 blcksilv08 Posted November 16, 2017 Share Posted November 16, 2017 I have good luck with pumice Stone and a dog hair removal brush followed close behind by a vacuum. 07stanggt and Checo 2 Link to comment Share on other sites More sharing options...
0 Hulio45 Posted January 18, 2018 Share Posted January 18, 2018 Hi! I'm also searching for a vac for a dogs hair on the shaggy carpet now. I found some articles about this category of cleaners and now i'm choosing between Bissel and Shark. Any experienced advices? To understand what i'm talking about read more Link to comment Share on other sites More sharing options...
0 Traizer Posted January 25, 2018 Share Posted January 25, 2018 I saw a guy that cut off the head of a toilet brush, put it in his drill and used it to get a bunch out in a hurry. It's on my list of things to try Link to comment Share on other sites More sharing options...
Specialm5
15 answers to this question
