Gflash024
Clear coat burn
6 answers to this question
15 minutes ago, Gflash024 said:
Will Adams polishes burn through clear coat?
Any abrasive polish has the potential to burn thru the clear coat, especially when paired with an aggressive pad.  If you follow the guide of using the least aggressive method first, and pay attention to your work, you should not have a problem.  Be mindful of panel edges and non-flat areas - those will have the least amount of clear coat.
Adam's Revive Polish is not an abrasive polish, but a chemical polish.
Edited by mc2hill
Share this post
Link to post
Do you have any examples of the abrasive polishes?
I assume these are the correcting compounds etc.
Share this post
Link to post
1 hour ago, TexWalker said:
All of the Adam’s polishes besides the revive are technically abrasive polishes. Though none will hurt the paint as long as you use the right tool halfway competently
The competently part of the equation is the big one. And with that competence comes knowledge. Understand how the polishes work. What can and can’t be polished out of the paint. And what tools to use and when.
Put heavy compound on a powerful machine and let it sit there or work an edge too long, and you will go through the clear.
I realize it’s not practical for many people, but this is a great reason why we measure before we take a machine to any vehicle. The gauge doesn’t lie.
Share this post
Link to post
Exactly, Shane. And to his point, someone with the finishing polish on the white pad with a PC sitting still for a minute won’t remove swirl marks. So, GFlash, to answer your question:
• Don’t be dumb
• Use a machine you’re comfortable with
• Always start with the least aggressive polish first to gauge how much work you need to actually do
• Keep the machine moving
• Check your work frequently
Edited by TexWalker
Share this post
Link to post
• Don’t be dumb
Pretty sound advice actually!
Share this post
Link to post
