BlackCadi14 Posted November 13, 2017 Share Posted November 13, 2017 Hi, Silly question, how do you keep your gallons from leaking from the gallon pump, I used a cue tip to slide in there when not in use. What do you guys do??? Link to comment Share on other sites More sharing options...
0 ZMAN024 Posted November 13, 2017 Share Posted November 13, 2017 If you back off the cap after use, and then re-tighten, it will release the siphon created by the pump. Then wipe the excess of the tip, and it shouldn't drip while not in use. BlackCadi14 1 Link to comment Share on other sites More sharing options...
0 BlackCadi14 Posted November 13, 2017 Author Share Posted November 13, 2017 I will try that, thank you Link to comment Share on other sites More sharing options...
0 TexWalker Posted November 14, 2017 Share Posted November 14, 2017 I just tip it forward a bit and let it drain off for a few seconds. Adams really needs to step up the design on the pump nozzles a bit. I feel like these are the worst designed product they sell BlackCadi14 1 Link to comment Share on other sites More sharing options...
0 shane@detailedreflections Posted November 14, 2017 Share Posted November 14, 2017 We actually don't use the pumps for the gallons except for the thicker product (VRT, Leather Conditioner, etc). We use the screw on funnels and just pour to refill prior to recapping. It works for us. BlackCadi14 1 Link to comment Share on other sites More sharing options...
0 TexWalker Posted November 14, 2017 Share Posted November 14, 2017 I like to use the pump for my revitalizer, rinse-less wash and shampoo so I can get a consistent measured amount (1oz. per pump). No point using too much product and wasting it. For my other gallons, I use the funnels, they are awesome. BlackCadi14 1 Link to comment Share on other sites More sharing options...
0 BlackCadi14 Posted November 14, 2017 Author Share Posted November 14, 2017 I like the pumps, and I just put a cue tip in the end of them to help stop the leaking. I find it easy to use when needed verus picking the gallon up. I might down the road move to a 16oz bottle for the shampoo but for now the pump works. Link to comment Share on other sites More sharing options...
0 TheWolf Posted November 16, 2017 Share Posted November 16, 2017 On 11/13/2017 at 2:34 PM, BlackCadi14 said: Hi, Silly question, how do you keep your gallons from leaking from the gallon pump, I used a cue tip to slide in there when not in use. What do you guys do??? Do this: 3/8" vinyl vacuum caps. You can get them at the Auto Parts store, or from Amazon: https://www.amazon.com/Spectre-Performance-4254-Vacuum-Assortment/dp/B000BPWSCC/ref=pd_sim_263_6?ie=UTF8&refRID=0MEFTYWQJA69T6KMSJK2 BlackCadi14, ocdrifter, Sac and 1 other 2 2 Link to comment Share on other sites More sharing options...
BlackCadi14
Hi,
