haysej Posted January 17, 2018 Share Posted January 17, 2018 I just got a foam cannon. Yay! I'm looking for the best pressure washer to use now. Ideally it would be something that doesn't take up much garage space. Any advice on the best small form factor pressure washers that will work good with the cannon? Thanks! CorndogJoe Link to comment Share on other sites More sharing options...
0 funkymonkey1111 Posted January 17, 2018 Share Posted January 17, 2018 Your first decision should be electric or gas. Frankly, for creating foam it seems to be a junk-measuring contest. I have a dinky electric ryobi that foams just fine. Or, if you want a high end electric, check out Kranzle. Some will chime in that gas is the only way--but you mention garage space. The small electrics can actually be stored on a shelf, not taking up floor space. If you don't need a power washer for cleaning other things (driveways, fences, decks) the electric should work fine for your application. Link to comment Share on other sites More sharing options...
0 Red Rambler Posted January 17, 2018 Share Posted January 17, 2018 (edited) I have the below pressure washer: 3200 PSI. Simpson Pressure Washer I was given the below info on pressure for using the Foam Cannon: "max rating of 3190psi for our Red Foam Cannon " I use my pressure washer for pressure washing my house as well as under my vehicles as needed. I would suggest getting a smaller one that is in line with the pressure rating of the foam gun. In this case a larger pressure washer with max PSI is not the best. Edited January 17, 2018 by Red Rambler Link to comment Share on other sites More sharing options...
0 Tony_G Posted January 20, 2018 Share Posted January 20, 2018 Im in the same boat! just ordered my foam cannon now its time to consider pressure washers. I definitely want to get a gas powered one but that's all I know so far lol Link to comment Share on other sites More sharing options...
0 Naylor649 Posted January 26, 2018 Share Posted January 26, 2018 Get a decent electric one. You don’t need 3K plus to wash a car. High end range Kranzle as stated before. Low end get a sun joe. Also as stated if you decide on a gas one for more uses(cleaning concrete) get a inline pressure gage to knock that psi down to about 1600-1800 and throw a 40 degree nozzle on it. For the crazy thick foam you will want a gas one though. Or get a electric and change the orifice out in your foam cannon. Hope this helps. Link to comment Share on other sites More sharing options...
0 Dwhite0960 Posted January 26, 2018 Share Posted January 26, 2018 I used a super cheap 60 buck greenworks one from lowes, it foamed the car like I wanted. However now it and the cannon collect dust as it's been over a year since I played in sudsy mess. I am a huge rinseless fan and haven't had a reason to use soap. I will use the pw to blast off large debris still if they are present. No need to spend huge bucks on a pw for the reason of car washing Link to comment Share on other sites More sharing options...
0 Tony_G Posted January 27, 2018 Share Posted January 27, 2018 20 hours ago, Naylor649 said: Get a decent electric one. You don’t need 3K plus to wash a car. High end range Kranzle as stated before. Low end get a sun joe. Also as stated if you decide on a gas one for more uses(cleaning concrete) get a inline pressure gage to knock that psi down to about 1600-1800 and throw a 40 degree nozzle on it. For the crazy thick foam you will want a gas one though. Or get a electric and change the orifice out in your foam cannon. Hope this helps. Thanks for the input. Im definitely wanting to get a gas one so I am able to use the PW for other uses around the house. Ive seen a few youtube videos of people using one around 2800psi and they really seem to work great at this PSI. I will definitely consider the inline pressure gauge though. Link to comment Share on other sites More sharing options...
0 Naylor649 Posted January 27, 2018 Share Posted January 27, 2018 1 hour ago, Tony_G said: Thanks for the input. Im definitely wanting to get a gas one so I am able to use the PW for other uses around the house. Ive seen a few youtube videos of people using one around 2800psi and they really seem to work great at this PSI. I will definitely consider the inline pressure gauge though. Just be careful. The pressure washer is used to “knock down” dirt and grime. Not cut off. That’s what your wash mitt and soap is for. Newer car would be ok but older that clear coat gets a little bit more fragile. Just my .02. Link to comment Share on other sites More sharing options...
0 EPHIOS Posted January 28, 2018 Share Posted January 28, 2018 You can get pretty decent foam from an electric pressure washer like the Ryobi 2000 PSI from Home Depot/Lowes. Let me suggest you to change the orifice of Adams Foam Cannon from 1.25 to 1.1, it will greatly improve the output. Link to comment Share on other sites More sharing options...
0 MisanoRS4 Posted March 30, 2018 Share Posted March 30, 2018 On 1/27/2018 at 11:41 PM, EPHIOS said: You can get pretty decent foam from an electric pressure washer like the Ryobi 2000 PSI from Home Depot/Lowes. Let me suggest you to change the orifice of Adams Foam Cannon from 1.25 to 1.1, it will greatly improve the output. How do you all change out the orifice?? I am having issues with my cannon as well. Link to comment Share on other sites More sharing options...
0 SVillalon Posted March 30, 2018 Share Posted March 30, 2018 (edited) On 3/29/2018 at 6:42 PM, MisanoRS4 said: How do you all change out the orifice?? I am having issues with my cannon as well. open the thing "sorry don't know the specifics" the quickdisconnect and with a flat head screwdriver take out the orifice and put in the new one. Will use the new 1.1 orifice tomorrow to check the foam out. 1700psi electric 1.2 GPM Edit: used UltraFoam Shampoo and was amazed with the results. same everything except changed the foam cannon orifice with 3-4 oz of product. towards the end of the canister it seemed to go back to runny instead of shaving cream tendency. good though,. Edited March 31, 2018 by SVillalon Link to comment Share on other sites More sharing options...
0 Bryman312 Posted April 29, 2018 Share Posted April 29, 2018 where do you get the 1.1 orifice? im thinking baout ordering the foam cannon tomorrow...........that way ill HAVE to get a pressure washer....LOL Link to comment Share on other sites More sharing options...
haysej
Thanks!
CorndogJoe
11 answers to this question
