Ok so I have a few questions and want some open discussion on pros/cons of a Ceramic Coating, not necessarily a specific brands though I'm 99% sure I'd go with Adam's new 9H Paint Coating.
First off, what happens if your car gets damaged, let's say rear ended or whatever and body work needs to be done. Will the bodyshop sanding blow right through the coating? I've heard that some cars can have finish problems as Ceramic Coatings are so hard and the heat from sanding can drive it deeper into the metal/primer and the paint can have fish eye problems. Does this mean any body panels will need to be polished/compounded first to remove the Ceramic Coating before hand?
Secondly, what happens when the coating's hydrophobic properties wears off in lets say 2.5 years and strong washes/decon and Ceramic Boost doesn't revive it anymore. Can you move right to a strip wash/clay/decon/light polish and Re-Coat? Or will you have to FULLY polish and make sure there is NO Ceramic Coating left on the paint?
Third, let's say I sell my coated truck in 2 years with the coating still going strong, do I owe the owner the decency to give him a quick run down on maintenance and what may happen in the next year or so? What happens when a non-detailer or clean vehicle focused person buys a coated vehicle when the coating is failing? Because the coating isn't really gone, you just can't see the benefits anymore.
And what maintenance does a coating need? I'd expect regular washes with Strip Wash or another aggressive soap like Carpro Reset that's designed to clean the nanoparticles and restore the beading. Then a light clay/decon 1-2 times per year? Is that all?
LSX Maestro
Thanks
10 answers to this question
