buffalobob920 Posted June 10, 2018 Share Posted June 10, 2018 Hi a question about Adams iron Remover want to know if it’s safe for ceramic coated cars and also is it safe to use on paint protected film coated cars (expel) thanks Link to comment Share on other sites More sharing options...
0 2012srt8 Posted June 10, 2018 Share Posted June 10, 2018 used it last night on my coated truck. worked great. not sure on on the expel though. Link to comment Share on other sites More sharing options...
0 buffalobob920 Posted June 10, 2018 Author Share Posted June 10, 2018 Q 9 minutes ago, 2012srt8 said: used it last night on my coated truck. worked great. not sure on on the expel though. It didn’t remove any of the coating Link to comment Share on other sites More sharing options...
0 galaxy Posted June 10, 2018 Share Posted June 10, 2018 I haven't had a need to re-do the iron remover on any of my coated cars, so I'm not sure. I'm skeptical though. I'm no chemist, but I find it difficult to wrap my head around how a product can remove iron particles imbedded in the surface (be it the coating, paint, whatever) and not have an impact on that sacrificial outer layer of protection. I know this...I will not randomly try or use iron remover simply as part of a spring cleaning or normal maintenance routine. On my coated cars, I won't use it unless I visually see a need for it. My (coated) cars are both white, so the iron deposits typically show up pretty darn good when present. Link to comment Share on other sites More sharing options...
0 2012srt8 Posted June 10, 2018 Share Posted June 10, 2018 2 hours ago, buffalobob920 said: Q It didn’t remove any of the coating nope.no chemical will remove coatings I had the little orange spots on mine and now there gone.beats using the clay bar Link to comment Share on other sites More sharing options...
0 shane@detailedreflections Posted June 11, 2018 Share Posted June 11, 2018 On 6/10/2018 at 12:39 PM, galaxy said: I haven't had a need to re-do the iron remover on any of my coated cars, so I'm not sure. I'm skeptical though. I'm no chemist, but I find it difficult to wrap my head around how a product can remove iron particles imbedded in the surface (be it the coating, paint, whatever) and not have an impact on that sacrificial outer layer of protection. I know this...I will not randomly try or use iron remover simply as part of a spring cleaning or normal maintenance routine. On my coated cars, I won't use it unless I visually see a need for it. My (coated) cars are both white, so the iron deposits typically show up pretty darn good when present. We routinely suggest that clients do an iron decon once or twice a year for their finish. Your theory is similar to saying "how does it remove iron without removing the clear coat of the paint?" A coating is merely a surface finish. Particulate can certainly embed itself there and it may not be seen. Iron decon on most vehicle produces far more purple reactions than just visible orange flakes coming out. Many coating manufacturers recommend an iron/clay decon as routine maintenance for ceramic coated vehicle. Fear not on the iron remover and your coatings! On 6/10/2018 at 12:15 PM, buffalobob920 said: Hi a question about Adams iron Remover want to know if it’s safe for ceramic coated cars and also is it safe to use on paint protected film coated cars (expel) thanks You're good to go for those surfaces! Link to comment Share on other sites More sharing options...
buffalobob920
5 answers to this question
