MTM Foam Cannon
  • 3 weeks later...
2 hours ago, imatt27 said:
Will this connect to any Pressure washer? Or do you need the handle part as well? I have a sunjoe.
It will attach to any pressure washer that has the quick connect function.  My father has a Sunjoe and it does work with his.
you should have a gun that came with your sunjoe.as long as theres a quick connect at the end you’ll be good to go. i bought the quicl connects from MTM.
