Under-Hood Insulator Cleaning
tmevilsizor
I am having an issue with *gently* cleaning the Under-Hood Insulator (attached to bottom side of hood). I have tried a few different spray on solutions, but to no avail. I know how easy it is to ruin this area, so I want to avoid using any scrubbing or agitation.
I'm assuming that it is still road salt from the winter that is causing the white staining. I have heard stories of guys removing the liner and painting it black with high-temp spray paint. I DON'T want to do this. I performed an engine cleaning and it looks amazing except for the under-hood insulator fabric.
Are there any tricks of the trade you guys/gals have come up with to remove this residue WITHOUT any scrubbing?
FYI. I've tried the carpet and upholstery cleaner and APC at different times but no effect.
5 answers to this question
1 hour ago, mc2hill said:
I have used a foaming tire cleaner with decent results.  Maybe a foaming carpet cleaner would work too.
Do you apply directly onto the insulator or do you spray the foam into a microfiber and rub in? Any foaming tire cleaner should work?
Foaming Tire Cleaner or Foaming Tire Shine?
Edited by tmevilsizor
1 hour ago, ZMAN024 said:
Once you get it clean, I would suggest applying the new (yet-to-be-released) Fabric Protector top help repel the salt stains in the future.
Yes!! I saw the teaser! I'm not sure how well the FP would stick though if I used a foaming tire cleaner/shine as a base layer.
I spray on the insulator and let the foaming action lift the 'stuff' out of the liner.  Then wipe lightly with a towel (probably a terry towel or very used microfiber).
