Pressure Washer Help
SS LeadFoot
I am looking to get a pressure washer and set my budget at about $120. I was searching and I found this. I was also thinking of getting something to deep clean the carpets a little later. I see a lot of videos online about how people get all this dirt out of seats. I was orignially thinking of this
https://www.amazon.com/Sun-Joe-SPX3001-Electric-Pressure/dp/B00LX8Z03K/ref=sr_1_5?ie=UTF8&qid=1537709601&sr=8-5&keywords=electric+pressure+washer&refinements=p_89%3ASnow+Joe|Sun+Joe
But then I found this.
https://www.amazon.com/Joe-SPX7000E-1750-Max-Electric-Pressure/dp/B077SFC5MM/ref=sr_1_14?ie=UTF8&qid=1537709041&sr=8-14&keywords=electric+pressure+washer&refinements=p_89%3ASnow+Joe|Sun+Joe
I know the pressure washer part will work good with the adams foam cannon which I already have and the main reason I am getting a pressure washer. My question is how will the wet/dry vac part work? I would ue that for the car and the house. Wondering if it will clean the carpet really good or shold I just get two separate machines?
Thanks for any advice.
On 9/24/2018 at 9:11 PM, SS LeadFoot said:
Thanks editguy. How long have you had your spx3001? Have you had any problems? Do you use it for house stuff also?
I've only had it a few weeks now but I really like it. Used it with my foam cannon on two cars and power washed the crud off of one of my walkways. My only real complaint with the SPX3001 is if you buy the heavy duty extension hose you can not roll it up on the built in hose reel. The connector it too big to fit around the reel. So you have to disconnect the hose extension every time you are done for the day. Not a big deal but worth noting. If you are going to be using it to clean concrete/pavement buy this accessory as well https://www.amazon.com/Sun-Joe-SPX-TSN-34S-Quick-Connect-Nozzle/dp/B01ICC6QF0/ref=pd_bxgy_86_2?_encoding=UTF8&pd_rd_i=B01ICC6QF0&pd_rd_r=6574cea4-c286-11e8-b8af-f95a7d78e913&pd_rd_w=suYvm&pd_rd_wg=kv5bo&pf_rd_i=desktop-dp-sims&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=6725dbd6-9917-451d-beba-16af7874e407&pf_rd_r=PQQ16HDGNXJX4MJA7WKJ&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&psc=1&refRID=PQQ16HDGNXJX4MJA7WKJ
