aj's sierra
Worx Hydroshot and foam cannon?
So I recently moved to an apartment where I don't have access to a hose. I already have sealed buckets that I prep before going to the self service, but I'm wanting something more convenient. I just ordered the hydroshot and already have a foam cannon, was just curious if anyone has tried these together and if so how it did. Also I have an ik foaming sprayer, it gets the job done but I'd much rather use the foam cannon.
Share this post
Link to post
10 answers to this question
I have rinseless and love it. I was just wanting this for when it's a little too dirty for that. But I'm in Morgantown cheers beers and eers.
Share this post
Link to post
First, welcome!
If you havent looked into them, Adam's Waterless Wash and Rinseless Wash are perfect for your situation. Don't forget the towels! You can also dilute RW 16:1 for a waterless wash-like solution at a much more economical price point. But it doesn't smell as good as the WW, IMO.
Where you at in WV? I was born and raised there. Be sure to post an intro in the new member forum so we can all welcome you properly! Especially Mountaineers!!
Share this post
Link to post
25 minutes ago, falcaineer said:
First, welcome!
I have rinseless and love it. I was just wanting this for when it's a little too dirty for that. But I'm in Morgantown cheers beers and eers!
Share this post
Link to post
LLLLEETTTTTTTT'SSSSSSS GOOOOOOOOOOOOOOOOOOO............
Share this post
Link to post
I have a Hydroshot waiting for me at home. Looking forward to trying it. Need to get the 2 liter bottle adapter. I too was wondering if a foam cannon would fit.
Share this post
Link to post
I have the Hydroshot, the quick connect on the end of mine looks like it is "Keyed" not totally round, so without owning a foam cannon, I'm not sure it will fit.  Also, it is only rated at 300psi i think, so might not be strong enough.  I bought a second battery for mine as one battery can barely make two passes of my Avalanche, 2x5gal buckets.
My winter wash with it consists of:
Creating a mixture of soapy water in a spray bottle and after getting it first wet and knocking off the heavy salt in winter, spray it down with the soapy water, let dwell then rinse with multiple buckets of water.  Depending if the weather looks good in the future or if we are going somewhere special, I'll do a rinseless in the garage and HGG top off  of the sealant.
27356060_946102695548982_423401759271493
Share this post
Link to post
I don't think you will have enough psi for the foam cannon, but I have kicked around the idea of using the Hyroshot for my presoak using Rinseless in the winter time.
Share this post
Link to post
If you're talking about the hydroshot's own foam cannon attachment then it does foam.  I have the combo and it's comparable to a foam gun but not the actual 1800+ psi pressure washer foam cannon type of foam.
Share this post
Link to post
