TheWolf Posted January 9, 2019 Share Posted January 9, 2019 (edited) Introducing Adam’s New Ceramic Spray Coating! Adam’s Ceramic Spray Coating combines the enriched gloss, extreme hydrophobic properties, and effects of a ceramic coating with the application of a spray and wipe product. This 9H ceramic coating has been reengineered to be sprayed out of a bottle and wiped onto the surface, making application easier than ever before. Use discount code COATING to save 15% CLICK HERE TO SHOP Check out the video: Introducing Adam’s Ceramic Spray Coating, a game changing product in the ceramic coating world. At a registered 9H Hardness, Adam’s Ceramic Spray Coating is the easiest and fastest way to ceramic coat your vehicle and add unbelievable shine and gloss to your finish. Since ceramics have been introduced to the market, consumers and manufacturers alike have had to jump onboard and introduce the chemistry of ceramics into their product lines. Here at Adam’s Polishes, we wanted an easier way to provide our customers our newly improved ceramic paint, wheel, and trim coating options into a sprayable application. Using the most unique and user friendly chemistry on the planet, weekend hobbyists and detailing enthusiasts can add ceramic protection to the their finish, wheels, plastic components, trim, and glass in minutes. Let’s set something straight… In the car care industry, ceramic coatings and “nano” technology have become buzz words and industry standards and although sometimes effective, these are not true “ceramic” coatings. Having silica resins, or “containing SiO2” doesn’t make it a true ceramic coating. Containing ceramic technology is the minimum to passing the first audition in modern car care, but is it an actual ceramic coating? Unfortunately, no. Consider our Ceramic Boost or Ceramic Paste Wax: Both contain heavy amounts of SiO2, give extreme amounts of gloss and protection, and are extremely hydrophobic, but not actual coatings! They are designed for ceramic maintenance in between washes, or an alternative to conventional carnauba/polymer waxes. With Adam’s Ceramic Spray Coating, the proof is in the application— The first swipe of the product will reveal a quickly appearing “rainbow” effect, theres your proof! This is not a streak, smear, or defect— The rainbow effect is a mixture of gases and liquids evaporating and curing to your finish to provide the hydrophobic, acid-resistant, water spot-resistant, and UV inhibiting layer that we’re all after. As the rainbow effect begins to widen and develop, the applied product is turning to evenly hardened SiO2, or glass— hence “glass” coatings. Now, this chemistry is unique to the sprayable coating versus our current coatings as it has a longer working time, allowing it to tack up not as quickly and let you cover an entire hood, as opposed to small sections or proportions. What makes a ceramic coating, a ceramic coating? Hang tight, we’re going to get scientific with you— Ceramic coatings start with silica resins, ones that are usually cured in a furnace or extreme heat, but are modified versions to cure at room temperature (ie your garage or detail shop!). The ceramics we’re used to are the modified versions and are neatly ordered and paired molecules of Si and O that make a tetrehedron, which produces a perfect triangle contributing to its stability and strength on your paint. The Si and O molecules are so strong in fact that their bonds don’t step out unless abrasion and/or heat are introduced, hence why Ceramic Coatings only come off with time or accelerated polishing! When developing this product, we wanted to make sure this product could be used in any situation or climate. Both high humidity areas, and dry areas like our headquarters in Colorado were prominent areas of testing grounds and application, and produced exceptional results on all accords. “6-8 months? How come it doesn’t last as long as your current paint coating?” So with this new chemistry, we made it pretty easy for application… almost a little too easy! With ceramic coatings, you have a hardness that the ceramic cures to, the hardest measured test being 9H to truly be accredited by the SGS (until they find a 10H hardness pencil at least!). The hardness doesn’t mean how it long it lasts though, but the easiest way to think of this is like a stack of paper towels vs one single sheet. Paper towel doesn’t become stronger or tear-proof as you stack it, maybe a bit more absorbent, but the strength doesn’t change. With Ceramics, particularly our paint and wheel coatings, both are 9H but create different film thickness layers (how many stacks of paper towels high). Paint creates a relatively thin layer, conserving the gloss, shine, and uniqueness of your finish— whereas Wheel creates a thicker layer for heat resistant, reduced brake dust adhesion, and overall increased longevity. With Adam’s Ceramic Spray Coating, the chemistry is unique for the delivery method creating a thin layer of ceramic protection with each wipe! The ease of use and low-level tackiness go hand in hand. “Can I layer this product to make it last longer?” Yes, of course, but that doesn’t mean layering this product 10 times will make it 10x longer— any application after 3 rounds will render the product redundant and still provide the same hydrophobic effects. “What can I use this on? Can I just spray the whole car with it?” Adam’s Ceramic Spray Coating provides protection to an extreme range of areas on your vehicle. Painted surfaces, Wheels, Glass, Headlights, Plastic trim, Bed liners, Tonneau covers, Canvas tops, Floor mats, Unfinished metal— All are safe to be protected. As much as we want you to spray the entire vehicle at once, we strongly recommend that you go panel by panel to ensure thorough application and as much control of overspray as possible. “How do I have to wait for it to cure?” One of the benefits of Ceramic Spray Coating is the ease of use, longer working time, and the expedited curing process. Since this product is dispensed through a sprayer, it starts curing as soon as you start to pull the trigger and the product flows onto the towel! Once it’s applied to the surface intended for treatment, let it rainbow and “flash” for 1-2 minutes, then remove with a premium microfiber towel. After the treatment is applied, you’ll want to keep it safe and element-free for about 3-4 hours. “What happens if I forget a spot or end up with a high-spot?” Adam’s Ceramic Spray Coating does have a slight self-leveling agent built into the formula for ease of use, but we know that accidents happen. If you forget a spot and you catch it in time (10-20 minutes after removal) simply reapply to that area and wipe off after 1-2 minutes. Reactivating the product will allow for easier removal. If left on for longer, we recommend Brilliant Glaze and a microfiber applicator, or machine polishing with Correcting Polish to fully remove the imperfection. FREQUENTLY ASKED QUESTIONS “How do I prep my paint for this product? How can I ensure I’ll get the maximum longevity out of it?" If your paint is bare and ready for a protective coating, you’ll want to clay your car at minimum to remove any bonded contaminants. This not only will give you that silky smooth feeling we all love and enjoy, but it will also cleanse the paint of any bonded surface contamination that will hinder the coating from bonding to the surface. Once clayed, simply use an IPA based prepping agent, or our Coating Prep, and coat the desired area once finished. For optimum results, we recommend perfecting your paint by removing any swirls, oxidation, or water spots using our Swirl Killer Polishing System. “Can Ceramic Spray Coating be applied over my current wax or sealant?” The short answer is no. For optimized results, we recommend stripping the surface before coating. Use a Fine Grade Clay Bar and Detail Spray, followed with Coating Prep. Since our waxes and sealants are great forms of protection, the coating will be partially rejected during the bonding process and hinder the duration and longevity of this coating. “What if my car is already Ceramic coated?” If your car is already coated, you’ll want to use a Fine Grade Clay bar and Detail Spray to remove any surface contamination. Then, apply a few mists of Coating Prep to remove any surface oils or residue— Finally, apply the coating by spraying it into your microfiber towel and treating the surface desired. 1-2 Minute Flash Time, 4 Hour No-Touch-Time. “How come Ceramic Spray Coating doesn’t last as long as your current Ceramic Paint Coating?” With this new chemistry, we made application extremely easy. When it comes to ceramic coatings, you have a hardness that the ceramic cures to, the hardest measured test being 9H to truly be accredited. The hardness doesn’t mean how long it lasts though, but the easiest way to think of this is like a ream of paper vs one single sheet. Paper doesn’t become stronger as you stack it. Ceramics coatings, particularly our paint and wheel coatings, are both 9H but create different film thickness (how many stacks of paper high). Ceramic Paint Coating creates a relatively thin layer, conserving the gloss, shine, and uniqueness of your finish— whereas Ceramic Wheel Coating creates a thicker layer for heat resistant, reduced brake dust adhesion, and overall increased longevity. With Adam’s Ceramic Spray Coating, the chemistry is unique for the delivery method creating a thin layer of ceramic protection with each wipe! “If it’s 9H, why isn’t it the same as Ceramic Paint Coating?” With ceramic coatings, once you apply the ceramic to the surface the ceramic starts to flash and cure, building up a layer of protection. Once it is dry or cured, the hardness it cures to is 9H. Think of it as a sheet of paper, versus an entire ream— The sheet of paper would be the 9H hardness, and how thick the ream of paper is would be how thick the ceramic develops and cures to. “Can I layer this product to make it last longer?” Yes, of course, but that doesn’t mean layering this product 10 times will make it 10x longer. More than 3 applications will render the product redundant and still provide the same hydrophobic effects. “What surfaces can I use Ceramic Spray Coating on?” Adam’s Ceramic Spray Coating provides protection to an extreme range of areas on your vehicle. Paint, Wheels, Glass, Headlights, Plastic trim, Bed liners, Tonneau covers, Canvas tops, Floor mats, Unfinished metal— All can be protected with Ceramic Spray Coating. We strongly recommend that you apply the product panel by panel to ensure thorough application and as much control of overspray as possible. “How long do I have to wait for Ceramic Paint Coating to cure?” Since this product is dispensed through a sprayer, it starts curing as soon as you start to pull the trigger and the product flows onto the towel! Once it’s applied to the surface intended for treatment, let it rainbow and “flash” for 1-2 minutes, then remove with a microfiber towel. After the treatment is applied, you’ll want to keep it safe and element-free for about 3-4 hours. “Can I reuse my Microfiber towels after being used with Ceramic Spray Coating?” Treat your towels as you would with any other coating. With Ceramic Spray Coating, you have bought yourself some extra time since it's so thin, but that doesn’t mean it doesn’t crystalize and harden over time. If you apply the coating and then toss the towels in the washing machine, you’ll remove most of the residual coating in the towel. The longer you expose your towels to oxygen, the more susceptible it is for crystallization. If you coat your car, then leave the towel overnight perhaps, then you might have a tougher time removing the coating from the microfibers. “If I have Ceramic Paint Coating on my car, and want to top it with Ceramic Spray Coating, Ceramic Paste Wax & Ceramic Boost, how do I layer them?” Ceramic Paint Coating should always be applied first since it’s the thickest layer. Ceramic Spray Coating should then be applied additionally and allowed to cure for 4 hours. If desired, you’ll want to top it with Ceramic Paste Wax first, then Ceramic Boost if you’re wanting the maximum shine we are currently able to offer! “What happens if I forget to remove a spot or end up with a high-spot?” Adam’s Ceramic Spray Coating does have a slight self-leveling agent built into the formula for ease of use, but we know that accidents happen. If you forget a spot and you catch it in time (10-20 minutes after removal) simply apply to that area and wipe off after 1-2 minutes. Reactivating the product will allow for easier removal. If left on for longer, we recommend Brilliant Glaze and a microfiber applicator, or machine polishing with Correcting Polish to fully remove the imperfection. “Can I use this on Matte/ Satin Paint or Vinyl Wraps? Will it make it glossy?” You can use this on Matte and Satin finishes. It will add increasingly better depth and sheen to the surface, but will not make it shiny! As this coating will flash on a clear coat, window, or gloss surface, you will not get flashing but still need to level off the coating as it will look streaky and smudgy in appearance upon application. “Can I use this on my interior?” No. This product is recommended for use on exterior surfaces and because of the strong odor, we do not recommend use for this on any interior surfaces. Edited January 14, 2019 by TheWolf Added FAQs and How-To video HurstGN, Nickfire20 and BrianT 2 1 Link to comment Share on other sites More sharing options...
LuckyKorean Posted January 9, 2019 Share Posted January 9, 2019 Posted this right before other got locked, hope it’s ok if I repost here. Just saw the video and product page. It can be applied on glass and almost everywhere. Spray application.. I wonder if this sort of renders Glass sealant and HGG pointless in a way, maybe even VRT? Kind of wish it came out earlier so I could try one spray on all instead of separate product for everywhere. Price is comparable to getting GS, HGG and VRTtogether but this new spray can outlast all of them in single application, single product. Or maybe since it’s a ceramic coating in spray form, we can layer another product on top, guessing Ceramic boost though or Ceramic paste wax? I’ll definitely give it a shot but not till I finish the products I have now. I feel like the small bottle of Glass sealant lasts for awhile. But HGG 16 oz bottle is looking like 4-5 times at most. Less if bigger SUV. This new spray says 6-8 cars and lasts 6-8 months if that’s true, then it sounds worth it. Coating 3-4 cars(families) twice a year for $70-80 Link to comment Share on other sites More sharing options...
BrillntRed06 Posted January 9, 2019 Share Posted January 9, 2019 Would it be better to apply this after a clay bar and paint sealant? And the website states it has to be left element free for 3-4 hours. What's element free as my lifted truck has to left outside since it doesn't fit in any garage. Link to comment Share on other sites More sharing options...
Parad0x Posted January 9, 2019 Share Posted January 9, 2019 29 minutes ago, BrillntRed06 said: Would it be better to apply this after a clay bar and paint sealant? And the website states it has to be left element free for 3-4 hours. What's element free as my lifted truck has to left outside since it doesn't fit in any garage. I take element free to mean no rain, snow, mud, splashing it with a hose to see the hydrophobic effect right away, etc etc. So besides watching out the previously mentioned, if your area gets dew that forms on your car, even that light dew that comes in the evening after warm temps drop cold, don’t do this application later in the day as well. Pretty standard requirement for most coatings afaik. Link to comment Share on other sites More sharing options...
Rich Posted January 10, 2019 Share Posted January 10, 2019 Got mine ordered. I'm anxious to use it. Link to comment Share on other sites More sharing options...
camaro2ssblack Posted January 10, 2019 Share Posted January 10, 2019 55 minutes ago, BrillntRed06 said: Would it be better to apply this after a clay bar and paint sealant? And the website states it has to be left element free for 3-4 hours. What's element free as my lifted truck has to left outside since it doesn't fit in any garage. Do not apply a coating over any other LSP (such as a paint sealant). It needs a perfectly clean surface to bond correctly. Ideally you would clay, polish and then remove all polishing oils before applying the coating. Polishing is an optional step. Link to comment Share on other sites More sharing options...
RickP Posted January 10, 2019 Share Posted January 10, 2019 Ordering mine tonight, got a buddy going to order too we’re already geeking out. Curious how it will affect the microfiber towels you use and if it will work well on leather. Our leather seats in our explorer are very light so looking for a way to protect them. Link to comment Share on other sites More sharing options...
mc2hill Posted January 10, 2019 Share Posted January 10, 2019 Looks like it would be a good choice for wheels! Thorsager, BrianT and 8675309'SS 3 Link to comment Share on other sites More sharing options...
Firebuff17 Posted January 10, 2019 Share Posted January 10, 2019 This looks amazing and I might be trying it at some point. I read the product page in Adams website, and I watched the video but that led me to have some questions. I understand the bare paint and that this could be used in everything on the exterior but what about using trim restorer first? They also said to use your favorite towel, looked like in the video they were using double softs, once complete how do we clean the towels? Link to comment Share on other sites More sharing options...
BrianT Posted January 10, 2019 Share Posted January 10, 2019 That's ny question as well, are we able to clean the towels or are they use and throw away? Link to comment Share on other sites More sharing options...
TheWolf Posted January 10, 2019 Author Share Posted January 10, 2019 Some good questions above. I have not tried this new product yet, so I cannot help with answers, but Kyle will be posting the instructions here soon. Link to comment Share on other sites More sharing options...
Rich Posted January 10, 2019 Share Posted January 10, 2019 Wondering if there's a temperature low limit for applying. Yesterday it was 60 here............woke up this morning to a blizzard. Wind chills tonight down to -3 and it's not going to warm up any time soon. But on the next warm day we get, I will probably want to use it. Anywhere between 50 and 60* is considered warm this time of year. Nickfire20 1 Link to comment Share on other sites More sharing options...
galaxy Posted January 10, 2019 Share Posted January 10, 2019 (edited) I'm gonna get mine and go this route too. My vehicles are already coated, so here's my plan. Come warmer weather, maybe an iron remover (we'll see...these cars don't live a rough life, LOL), a quick, light clay bar (after checking the surface), and then Coating Surface Prep for sure. Then this, then top with my ceramic wax the following day. Thoughts??? Curious if there's any shine/depth difference when compared to regular coating?! I would venture to guess your towels will be trash after this product since it's a true coating vice a maintenance product (e.g. Boost). Edited January 10, 2019 by galaxy Link to comment Share on other sites More sharing options...
vdub Posted January 10, 2019 Share Posted January 10, 2019 20 hours ago, BrianT said: That's ny question as well, are we able to clean the towels or are they use and throw away? yeah i talked to them today and asked them about the towels, you would have to throw away your towel. Firebuff17 1 Link to comment Share on other sites More sharing options...
Smokeater806 Posted January 11, 2019 Share Posted January 11, 2019 I wonder if you can top this product with anything, spray wax, detail spray, Guard & Gloss ect? Link to comment Share on other sites More sharing options...
tlbullet Posted January 11, 2019 Share Posted January 11, 2019 17 minutes ago, Smokeater806 said: I wonder if you can top this product with anything, spray wax, detail spray, Guard & Gloss ect? Im sure its recommended that you stay with the CB, CW and DS as to not reduce the hydrophobic properties. Link to comment Share on other sites More sharing options...
zw470 Posted January 11, 2019 Share Posted January 11, 2019 I wonder if they're still working on the car shampoo that was specifically for coated cars Link to comment Share on other sites More sharing options...
2Fords Posted January 11, 2019 Share Posted January 11, 2019 So the official word from Adams is, the towels you use are no longer usable because of the ceramic coating drying on them.....correct? Link to comment Share on other sites More sharing options...
dg150 Posted January 11, 2019 Share Posted January 11, 2019 What is the advantage to this compared to paint sealant? The longevity is about the same but the price of the ceramic spray is a lot higher. Link to comment Share on other sites More sharing options...
tlbullet Posted January 11, 2019 Share Posted January 11, 2019 2 hours ago, zw470 said: I wonder if they're still working on the car shampoo that was specifically for coated cars I hope not 🤑. Could use a break!! Would be nice though ObsessedDetailer 1 Link to comment Share on other sites More sharing options...
TheWolf Posted January 11, 2019 Author Share Posted January 11, 2019 Here is the instructions from the bottle label. RayS and Nickfire20 2 Link to comment Share on other sites More sharing options...
zw470 Posted January 11, 2019 Share Posted January 11, 2019 "DO NOT UNCAP AND SMELL THIS PRODUCT" Because they know that's what every single one of us does as soon as we get a shipment BrianT 1 Link to comment Share on other sites More sharing options...
Parad0x Posted January 11, 2019 Share Posted January 11, 2019 8 hours ago, dg150 said: What is the advantage to this compared to paint sealant? The longevity is about the same but the price of the ceramic spray is a lot higher. I've always been under the impression that ceramic coatings provide better protection from bird bombs and chemicals than paint sealants. Link to comment Share on other sites More sharing options...
Hamilton Detail Posted January 11, 2019 Share Posted January 11, 2019 11 hours ago, zw470 said: I wonder if they're still working on the car shampoo that was specifically for coated cars If you don’t want to wait, it’s already been done by several other companies. Link to comment Share on other sites More sharing options...
GolfR Posted January 11, 2019 Share Posted January 11, 2019 11 hours ago, zw470 said: I wonder if they're still working on the car shampoo that was specifically for coated cars I've seen it noted a few times that their Wash & Wax goes well with Ceramic paste wax and ceramic coatings. It has SIO2 in it. Nickfire20 1 Link to comment Share on other sites More sharing options...
