Want to try some spray ceramic on a vehicle. The FAQ is kinda sketchy and contradicts itself in my opinion.
" Can I reuse my Microfiber towels after being used with Ceramic Spray Coating?” Treat your towels as you would with any other coating. With Ceramic Spray Coating, you have bought yourself some extra time since it's so thin, but that doesn’t mean it doesn’t crystalize and harden over time. If you apply the coating and then toss the towels in the washing machine, you’ll remove most of the residual coating in the towel. The longer you expose your towels to oxygen, the more susceptible it is for crystallization. If you coat your car, then leave the towel overnight perhaps, then you might have a tougher time removing the coating from the microfibers. "
First sentence says to treat the towels as with any other coating. Which to me means throw away before it gets mixed in with anything else. But it goes on to talk about machine washing it right away. I hate throwing away microfibers but I really don't want to keep them if they have crystallized product in it?
I would like to be able to ceramic coat more often but if it comes at the expense of throwing away towels it seems I would be better to stick with regular ceramic coat. The only problem with regular ceramic coat is that it means I have have the vehicle parked overnight so I can get cure time and then boost.
rrmccabe
Opinions?
9 answers to this question
