Ok so I am a little confused on which pad I need for polishing my car prior to applying the ceramic coating. After watching video 12 where he demos the orbital long throw which is what I am going to use. I see he uses a black microfiber pad (with orange backing) with the normal orange correcting polish. I assume that black pad is basically the same as the white one you offer? Doesn't look as thick but I did not see the black one that is in the video unless I overlooked it. Would that be the idea? Or should I just use the orange form pad with the orange correcting polish and if I need to switch to the heavy correcting polish and then switch to micro fiber? I was told my car has hard paint so I assume I will start with the orange and then move to the blue, but which pads?
vcordaro
Thanks in advance
2 answers to this question
