bakchoi Posted March 31, 2019 Share Posted March 31, 2019 I would like to know the difference between FOAM SPRAYER and MULTI-SPRAYER is it just the tip? Can the foaming tip be obtained separately so I can use the multi sprayer? Link to comment Share on other sites More sharing options...
0 ObsessedDetailer Posted April 1, 2019 Share Posted April 1, 2019 5 hours ago, bakchoi said: I would like to know the difference between FOAM SPRAYER and MULTI-SPRAYER is it just the tip? Can the foaming tip be obtained separately so I can use the multi sprayer? The foaming sprayer is more for products that foam obviously, ie car shampoo, TRC, wheel cleaner, ultra foam, rubber mat cleaner, stuff like that. While the multi sprayer is more of a mist that is constantly sprayed. You could put iron remover, detail spray, glass cleaner, things of that nature instead. I have not been able to find JUST the sprayer tips to switch out but i would like to get both tips so i can switch out thee purposes for the sprayer itself. Link to comment Share on other sites More sharing options...
0 Amiguel6 Posted April 1, 2019 Share Posted April 1, 2019 6 hours ago, bakchoi said: I would like to know the difference between FOAM SPRAYER and MULTI-SPRAYER is it just the tip? Can the foaming tip be obtained separately so I can use the multi sprayer? The Rag Company sells the tips separately, although I’m not sure if they are compatible with each other. www.theragcompany.com Link to comment Share on other sites More sharing options...
0 red94chev Posted April 1, 2019 Share Posted April 1, 2019 No, the tips are not interchangeable nor are the insides of the "lid". The foamer is an aerator where the sprayer is just a sprayer. The only thing interchangeable between the 2 is the bottle part. I believe that's the answer you are looking for. mc2hill 1 Link to comment Share on other sites More sharing options...
0 ObsessedDetailer Posted April 1, 2019 Share Posted April 1, 2019 https://www.theragcompany.com/ik-multi-1-5-straight-stream-fan-nozzle-kit/ this is what it says If you lost your IK 1.5 nozzles or just want extras, The Rag Company carries almost all IK Sprayer spare parts. This package comes with 2 nozzles for the Multi 1.5 Sprayer. Does not work with the iK Foam 1.5 Sprayer. Link to comment Share on other sites More sharing options...
bakchoi
4 answers to this question
