Twilcox Posted April 11, 2019 Share Posted April 11, 2019 What is the difference between Boost 2.0 and the new Ceramic Boost or are they the same product in a newer bottle? Link to comment Share on other sites More sharing options...
0 TheWolf Posted April 11, 2019 Share Posted April 11, 2019 56 minutes ago, Twilcox said: What is the difference between Boost 2.0 and the new Ceramic Boost or are they the same product in a newer bottle? Same product in a different bottle. Rich 1 Link to comment Share on other sites More sharing options...
0 rleipold Posted April 14, 2019 Share Posted April 14, 2019 Ceramic boost 2.0 is supposed to streak less. Therefore it takes less effort to wipe clean after applying. Link to comment Share on other sites More sharing options...
0 jeffawats Posted April 14, 2019 Share Posted April 14, 2019 I used CB 2.0 on my wifes 2018 Ford Edge metallic blue and it is very streaked on the hood this morning.... Link to comment Share on other sites More sharing options...
0 falcaineer Posted April 14, 2019 Share Posted April 14, 2019 3 hours ago, jeffawats said: I used CB 2.0 on my wifes 2018 Ford Edge metallic blue and it is very streaked on the hood this morning.... As I mentioned in your other post, you're probably using too much. A couple sprays per panel, especially as the towel gets primed from using it, is sufficient. And only every month or two, most, not daily or even weekly. RayS and tlbullet 2 Link to comment Share on other sites More sharing options...
0 tlbullet Posted April 14, 2019 Share Posted April 14, 2019 7 hours ago, jeffawats said: I used CB 2.0 on my wifes 2018 Ford Edge metallic blue and it is very streaked on the hood this morning.... 4 hours ago, falcaineer said: As I mentioned in your other post, you're probably using too much. A couple sprays per panel, especially as the towel gets primed from using it, is sufficient. And only every month or two, most, not daily or even weekly. Def using too much product..i find it better to apply lightly, wipe with MF. Do the whole car then return and wipe car with another clean MF. Usually does the trick. RayS 1 Link to comment Share on other sites More sharing options...
0 rrmccabe Posted April 15, 2019 Share Posted April 15, 2019 12 hours ago, jeffawats said: I used CB 2.0 on my wifes 2018 Ford Edge metallic blue and it is very streaked on the hood this morning.... Is the car clayed and containment free? My experience with the Boost and detail spray for that matter is you need a vehicle that is CLEAN. I clay 2 or 3 times a year for this reason. Link to comment Share on other sites More sharing options...
0 jeffawats Posted April 15, 2019 Share Posted April 15, 2019 my wifes car is clay bar'd and contaminent free I was just using the CB way to much. Link to comment Share on other sites More sharing options...
0 colorado.e9x Posted April 15, 2019 Share Posted April 15, 2019 Are we talking one even mist on the towel per panel or? Link to comment Share on other sites More sharing options...
0 RayS Posted April 15, 2019 Share Posted April 15, 2019 Using the wet method, I usually spray the panel. However, when it is a smaller panel or things like the back of the mirrors, I spray the towel if the towel does not already have plenty on it. For a 2 door car, say a Monte Carlo SS, I'll use one spray for an entire door and that is plenty. For the hood, it is usually two sprays. rleipold 1 Link to comment Share on other sites More sharing options...
Twilcox
9 answers to this question
