CleanFreak13 Posted May 23, 2019 Share Posted May 23, 2019 I accidentally posted this in the new member check-in area. Was just wondering if applying the Ceramic Paste Wax over the Paint Sealant would work like a normal wax? Didn't know if the Ceramic Paste Wax should bond to the naked paint surface or not. I have had great success with all of the products, and just want to make sure I am not being redundant with the application. Thank you Link to comment Share on other sites More sharing options...
0 nateeric Posted May 23, 2019 Share Posted May 23, 2019 I think it would work like a normal wax...my understanding is it's a good quality wax with a 30% silica content. It can be removed with a strip wash, so I would bet it would bond to the PS just like any other wax. Link to comment Share on other sites More sharing options...
0 falcaineer Posted May 24, 2019 Share Posted May 24, 2019 I asked Adam's this same question a while back, when it first came out. Most thought it would work fine, but I couldn't really get a consensus. They probably know more now, but in interest of time and my customer's wishes, I ended up just applying only the CPW and he was thrilled. I think the results speak for themselves... RayS, mc2hill, shooterjgs and 2 others 5 Link to comment Share on other sites More sharing options...
0 TOBASCO Posted June 14, 2019 Share Posted June 14, 2019 falcaineer - car looks fantastic - nice job. My question with the paste wax is should it be applied similar to liquid coatings where you apply a section in one direction and then go over the same section in the opposite direction. It really didn't say one way or another in their instructions. Thanks! falcaineer 1 Link to comment Share on other sites More sharing options...
0 falcaineer Posted June 15, 2019 Share Posted June 15, 2019 3 hours ago, TOBASCO said: falcaineer - car looks fantastic - nice job. My question with the paste wax is should it be applied similar to liquid coatings where you apply a section in one direction and then go over the same section in the opposite direction. It really didn't say one way or another in their instructions. Thanks! Just make sure to apply a thin, even layer... patterns or directions you apply it in don't really matter. Also work one panel at a time, too, as it can be a bit difficult to remove if left on for too long. A little goes a long way, but when the applicator starts to stick and is dry, one quick dip and twist into the container and you're good to go! Post some pics! Link to comment Share on other sites More sharing options...
0 RayS Posted June 15, 2019 Share Posted June 15, 2019 18 hours ago, falcaineer said: Just make sure to apply a thin, even layer... patterns or directions you apply it in don't really matter. Also work one panel at a time, too, as it can be a bit difficult to remove if left on for too long. A little goes a long way, but when the applicator starts to stick and is dry, one quick dip and twist into the container and you're good to go! Post some pics! ^^Agree^^ I've found that a 1/2 turn of the applicator provides plenty of CPW without it getting too thick. If the humidity is high, 75 or above, you will be able to do two panels or the complete hood since the drying time takes a bit longer. If you end up with the towel turning black, then you are using too much wax and make sure you avoid getting it on a convertible top, it is a real pain to get off. falcaineer 1 Link to comment Share on other sites More sharing options...
CleanFreak13
Thank you
5 answers to this question
