Currently running into an issue with a ceramic not coming out the way that I had planned after a few months of not seeing the car it cam back to me with a haze and pretty heavy water spots all over the vehicle. I boosted the vehicle once I got it and that removed the haze from the vehicle, but there is still quite a bit of water spots around the entire vehicle that I can't seem to rub off with boost. Is the only way to remove water spots by removing the coating if possible or is there a way that using a high PH soap will be able to get rid of those spots? any answers will be greatly appreciated, and any advice will also be greatly appreciated.
ShadowBrookeShine
10 answers to this question
