I am thinking of changing up the procedure on my wife's car. I have not decided to do the same on mine. First her car is as mentioned in the title is a 2018 equinox. When we first bought it, I did the normal wash, clay, polish and a coat of Americana. Seeing it is time to do a fresh detail, I was thinking of going with a ceramic protection. Not sure I want to go with the full ceramic coating or not. Was thinking of the CPW and then maintain it with the boost. Can I use the spray coating instead of the wax or can they be used in conjunction with one another? Also I will get the ceramic waterless wash. The car is not what I would consider a daily driver as we are both retired and it is garage kept, but it is used a lot more then the Corvette which spends most of its time in the garage covered.
So here is what I believe is the procedure. Strip wash, clay, correct any paint issue (if any), then either spray coating and used the boost every 4-6 weeks or apply the wax either paste or liquid and maintain with the ceramic waterless wash and/or the wash+coat.
Am I on the right track and of the two which would you recommend?
TR6speed
9 answers to this question
