i bought a craftsman 2800 psi / 2.3 gpm gas pressure washer (briggs and stratton engine) and the foam cannon / snub nose attachment from adams. when i first got the pressure washer i used it a few times for a couple minutes with no issues. i was finally able to wash my truck for the first time using the foam cannon today.
hooked it up and started the pressure washer and installed a 40 degree 2000psi tip to the adams snub nose attachment. pulled the trigger and the tip shot off the gun in one pressure release then the water dribbled out slow. put the tip back on and the same thing happened. stopped the washer and made sure everything was hooked up correctly and it was. restarted it and everything was fine. used the 40 degree tip to rinse off my truck then connected the foam cannon and everything was fine.
i washed my truck them installed the 40 degree tip again to rinse it off and the tip shot off in one large pressure release then low pressure. i could not get it to produce pressure. i made sure everything was connected properly and none of the fittings were leaking. checked the inlet screen and nothing there. still no pressure.
finished rinsing my truck with the regular hose and tried the pressure washer again with different tips and still no pressure. it shoots the tip off with the first trigger pull with one big pressure release then it goes to low pressure. you can hear the engine picking up when i release the trigger and the hose stiffening with pressure but when you pull the trigger there is one pressure release then low pressure.
ragin_cajuns
any ideas what may be happening?
thanks,
8 answers to this question
