buffalobob920 Posted August 9, 2019 Share Posted August 9, 2019 Hello I have a question about ceramic trim I have recently restored my black plastic trim with the trim restorer when and how can I use the ceramic trim Link to comment Share on other sites More sharing options...
0 Yo-Yo Ma's Cousin Posted August 9, 2019 Share Posted August 9, 2019 Ceramic trim coating? You would first clean the trim as well as possible with APC or Tire and Rubber cleaner. Not sure if surface prep will be needed prior to trim restorer. Then you would Use the Trim Restorer, and let it cure/dry for the full amount of time. (I think it's 6 hours indoor if possible) Then apply Ceramic Trim Coating and let it cure for the full cure time. (I think this is about 2 hours, the label on the product should specify) Then you should be ready to go. Link to comment Share on other sites More sharing options...
0 buffalobob920 Posted August 9, 2019 Author Share Posted August 9, 2019 5 hours ago, Yo-Yo Ma's Cousin said: Ceramic trim coating? You would first clean the trim as well as possible with APC or Tire and Rubber cleaner. Not sure if surface prep will be needed prior to trim restorer. Then you would Use the Trim Restorer, and let it cure/dry for the full amount of time. (I think it's 6 hours indoor if possible) Then apply Ceramic Trim Coating and let it cure for the full cure time. (I think this is about 2 hours, the label on the product should specify) Then you should be ready to go. Yes trim coating ok thanks for the information Link to comment Share on other sites More sharing options...
0 RayS Posted August 9, 2019 Share Posted August 9, 2019 1 hour ago, buffalobob920 said: Yes trim coating ok thanks for the information The Humidity will affect the drying and cure times and you want to make sure everything is cured before putting outside. If you have the facilities, my recommendation is to keep it in the garage for at least 4 hours and I prefer overnight. Yo-Yo Ma's Cousin 1 Link to comment Share on other sites More sharing options...
0 Yo-Yo Ma's Cousin Posted August 10, 2019 Share Posted August 10, 2019 I agree with @RayS for both steps I would let cure overnight as a minimum. RayS 1 Link to comment Share on other sites More sharing options...
0 GXPaycheck Posted August 10, 2019 Share Posted August 10, 2019 8 hours ago, Yo-Yo Ma's Cousin said: I agree with @RayS for both steps I would let cure overnight as a minimum. Second and thirded. RayS 1 Link to comment Share on other sites More sharing options...
0 falcaineer Posted August 10, 2019 Share Posted August 10, 2019 You can also use Paint Coating on hard plastic trim if you want longer life. It's not meant for flexible rubber trim, though, like around windows. Link to comment Share on other sites More sharing options...
0 buffalobob920 Posted August 11, 2019 Author Share Posted August 11, 2019 Thanks again Link to comment Share on other sites More sharing options...
buffalobob920
