Spazz318 Posted August 17, 2019 Share Posted August 17, 2019 I have some black plastic trim that needs some trim restorer. Can I put ceramic trim coating on it after it’s fully cured? Link to comment Share on other sites More sharing options...
0 falcaineer Posted August 17, 2019 Share Posted August 17, 2019 Absolutely! If you want longer last lasting results, you can also use Paint coating. And welcome! Be sure to post your own individual intro on the new member forum so we can all welcome you properly... Link to comment Share on other sites More sharing options...
0 Spazz318 Posted August 17, 2019 Author Share Posted August 17, 2019 Perfect. Thank you. falcaineer 1 Link to comment Share on other sites More sharing options...
0 brihvac Posted September 7, 2019 Share Posted September 7, 2019 On 8/17/2019 at 1:10 AM, falcaineer said: Absolutely! If you want longer last lasting results, you can also use Paint coating. And welcome! Be sure to post your own individual intro on the new member forum so we can all welcome you properly... I want to use my remaining paint ceramic on my plastic. I used the trim restorer a couple weeks ago so I plan on using ISO to wipe it all down then apply the ceramic. My question is can I just leave it outside afterwards to cure or does it have to sit in the garage overnight for curing? Also if I get some on the paint as long as I wipe it off right away will I be ok? Link to comment Share on other sites More sharing options...
0 brihvac Posted September 7, 2019 Share Posted September 7, 2019 Just now, brihvac said: I want to use my remaining paint ceramic on my plastic. I used the trim restorer a couple weeks ago so I plan on using ISO to wipe it all down then apply the ceramic. My question is can I just leave it outside afterwards to cure or does it have to sit in the garage overnight for curing? Also if I get some on the paint as long as I wipe it off right away will I be ok? Do I use Ceramic Boost on the plastic also? Link to comment Share on other sites More sharing options...
0 falcaineer Posted September 7, 2019 Share Posted September 7, 2019 1 hour ago, brihvac said: I want to use my remaining paint ceramic on my plastic. I used the trim restorer a couple weeks ago so I plan on using ISO to wipe it all down then apply the ceramic. My question is can I just leave it outside afterwards to cure or does it have to sit in the garage overnight for curing? Also if I get some on the paint as long as I wipe it off right away will I be ok? I'd highly recommend you leave if indoors, if possible, to cure. Otherwise dust, etc. could stick to it. Or worse, unexpected rain. And yeah, if you just wipe away it'll be fine. Link to comment Share on other sites More sharing options...
Spazz318
5 answers to this question
