I purchased a new Toyota Avalon Hybrid over the weekend. It is unfortunately another white car. I can't seem to get away from having a white car.
Anyway, I want to use the Ceramic Spray Coating on the car but figured I better decontaminate first. Do I need to use Iron Remover if I'm going to Clay Bar the car? I can't see any brown spots but that doesn't mean they aren't there. I watched Adam's video for the Iron Remover and he mentioned it is not a replacement for Clay Bar. But I'm not sure if I need to use both.
Next question is what type of Clay Bar should I use? Being a new 2020 I figure the "Fine Grade" clay will suffice. I am also looking at the "Visco Clay Bar" but I don't really understand the difference. Which should I use? Since I am going to use Ceramic Spray, what should I use to lubricate the Clay Bar? I have Detail Spray but since I'll be applying Ceramic I was thinking not to use Detail Spray. But then I'm thinking since I'll be using the Ceramic Surface Prep, that should take care of the residue from the Detail Spray, right?
Then the process would be to wash, dry, apply Surface Prep, apply Ceramic Spray Coating. Should I use Ceramic Boost after applying the Ceramic Spray or is that not necessary at this point? I already have a bunch of the Ceramic Waterless I'll be using routinely with the Boost every 4-6 weeks.
So, do I need to use Iron Remover? Which Clay Bar should I use? Am I correct about the Detail Spray residue being removed by Surface Prep?
SgtLip
Hi All,
Thanks in advance.
29 answers to this question
