The Guz Posted January 2, 2020 Share Posted January 2, 2020 Product: Adams Ceramic Black Trim Restorer Description: Quote Restore your faded black trim and ceramic coat it in one step! Restores black trim, plastic, and rubber components Easy wipe-on and allow to air dry Ceramic Coating and Pigment Restoration in one Ceramic Protection for years I picked this up at the local cars and coffee at the Anaheim location. I had a front cowl that I picked up at a local salvage yard that I ended up using as it is a two piece design rather than a one piece design. It is a better design and allows for easier replacement of the cabin filter. This ceramic trim restorer does two things with one product. It restores using the black dye while offering protection of a ceramic coating. The trim piece was cleaned and prepped prior to application. Hard to capture the true condition of the trim. During the restoration process Even used it on this plastic push pin that was pretty faded by the So Cal sun over the last 20 years. After. Much better The trim after the application is black and has life after two coats of product. The ceramic black trim restorer did a good job at restoring this trim piece. I will see how it holds up over the next few months. Application is straight forward. I would recommend wearing gloves to not get the dye on the hands. If you have older trim that needs some restoration this will work. The plastic trim may need multiple applications. If the trim is newer then I would stick with the regular ceramic trim coating. There is rubber on this trim price and I found that it can be streaky if used on rubber. It absorbs differently into the rubber than plastic. Wiping the rubber helps to even out the coating applied to rubber. RayS, falcaineer, tlbullet and 2 others 5 Link to comment Share on other sites More sharing options...
Yo-Yo Ma's Cousin Posted January 2, 2020 Share Posted January 2, 2020 Nice write up! The Guz 1 Link to comment Share on other sites More sharing options...
mc2hill Posted January 2, 2020 Share Posted January 2, 2020 Nice write up Guz! The Guz 1 Link to comment Share on other sites More sharing options...
RayS Posted January 2, 2020 Share Posted January 2, 2020 Thank you Michael for doing the write up. The Guz 1 Link to comment Share on other sites More sharing options...
Chris@Adams Posted January 2, 2020 Share Posted January 2, 2020 Looks good, nice job. The Guz 1 Link to comment Share on other sites More sharing options...
The Guz Posted January 3, 2020 Author Share Posted January 3, 2020 17 hours ago, Yo-Yo Ma's Cousin said: Nice write up! Thank you. 12 hours ago, mc2hill said: Nice write up Guz! Thank you. 7 hours ago, RayS said: Thank you Michael for doing the write up. Thank you. Glad you enjoyed the write up. 7 hours ago, Chris@Adams said: Looks good, nice job. Thank you. The trim does look good a day later after a couple coats. Link to comment Share on other sites More sharing options...
Rich Posted January 3, 2020 Share Posted January 3, 2020 Excellent write up. I have black plastic trim on the bottom of my Equinox . I've only used the Ceramic Spray Coating on it, but then again it's a new car. Once it starts to fade, I'm for sure going to use the trim restorer thanks to your write up! The Guz 1 Link to comment Share on other sites More sharing options...
The Guz Posted January 3, 2020 Author Share Posted January 3, 2020 1 hour ago, Rich said: Excellent write up. I have black plastic trim on the bottom of my Equinox . I've only used the Ceramic Spray Coating on it, but then again it's a new car. Once it starts to fade, I'm for sure going to use the trim restorer thanks to your write up! Thanks. The trim on yours should hold up and not need the trim restorer as long as you use the ceramic spray often. Nickfire20 1 Link to comment Share on other sites More sharing options...
Rich Posted January 4, 2020 Share Posted January 4, 2020 20 hours ago, The Guz said: Thanks. The trim on yours should hold up and not need the trim restorer as long as you use the ceramic spray often. I normally only keep cars till they're paid off, so if it lasts 5 years......I'm good. But I still like to keep them looking showroom new. Link to comment Share on other sites More sharing options...
quebert Posted January 7, 2020 Share Posted January 7, 2020 Nice nice, I could use some of of this, I don't know whether to order this or the Ceramic Trim Coating though. It sounds like maybe this is better for heavily faded trim? Link to comment Share on other sites More sharing options...
The Guz Posted January 7, 2020 Author Share Posted January 7, 2020 19 hours ago, quebert said: Nice nice, I could use some of of this, I don't know whether to order this or the Ceramic Trim Coating though. It sounds like maybe this is better for heavily faded trim? If the trim is in need of restoration then this would be the one you want. If the trim is still relatively new and not faded the regular trim coating will work just fine. Link to comment Share on other sites More sharing options...
M_carlisle Posted January 12, 2020 Share Posted January 12, 2020 (edited) Does anyone know if you can use the black trim restore and top it with ceramic trim coating or ceramic black. I have a 2013 dodge ram with ram boxes and just the black plastic on top of the boxes turned almost white. I cleaned them good per directions of ceramic black trim coating and am going on 3 coats of ceramic black coating and its still lighter than the other plastics around it. Just wondering for next time if i can apply the restore then the ceramic? update: tried using the black trim restore instead of ceramic black trim coating and it worked about the same so i went right over it with ceramic black coating... guess that answers that!! Edited January 12, 2020 by M_carlisle BrianT 1 Link to comment Share on other sites More sharing options...
falcaineer Posted April 29, 2021 Share Posted April 29, 2021 9 hours ago, imakeaway said: Rubber window trim is my problem area. I tried Cerakote Trim Coat, which turned sticky and could not be leveled out nicely (over-saturation of product on the wipes didn't help). How easy was it to wipe down / level out this 2-in-1 Ceramic Black Trim Restorer from Adam's? Also, how long did it last? Thanks for any insight you can offer. I love detailing my new blacked out Ram Limited, but the amount of work involved with keeping it sharp for more than a week (and removing failed junk products) has been exhausting. First, welcome! Be sure to post an intro so we can properly welcome you and post some pictures as well of the new ride! My recommendation would be to use the Graphene Ceramic Coating/Spray Coating, and get the kit. It would need to be completely cleaned, but assuming the trim is in good condition especially since it's new, would add some deep richness and last a long time. It's easy to apply, but one caveat... Be sure to level it out like you would on the paint (allow a couple of minutes or so), or you could get difficult to remove streaks. Link to comment Share on other sites More sharing options...
