Ok, I finally found out that the Ceramic Spray UV is the exact same formula as the new Ceramic Spray. Only difference is on has the UV tracer and other does not. I also now believe that the original Ceramic Spray Coating kit that came with the Prep, Coating and Boost is most likely the same except that it did not have the longer last properties of the newer versions. So I happened to watch a video with Adam applying the Ceramic Spray Coating and he even applied it to the glass areas and the plastic trim. I did not see that when I order the kit originally so I assume I can use it (UV version) the same way as he did in the video.
TR6speed
5 answers to this question
