I have a new project coming up soon. The owner of a 2007 Black Toyota Tundra has asked me to do a full restoration on the truck. He also asked me to try to address a key scratch that he has on the paint. I normally wouldn't offer touch up paint services, but the owner here has acknowledged that he doesn't expect a perfect outcome, but just for it to look better. I accepted the challenge partially because I wanted the experience and to at least try and see if I can help him.
I have seen several referrals on here to Dr. Color Chip... I have looked into using either them (Dr. Color Chip) or just a factory paint pen from the dealership. I have extra tools and brushes to fit tighter spaces as needed.
Anyways, while I start to plan my process, I have a few questions.
- For those that have used Dr. Color Chip, what are some experiences you've had? Anything I should look out for? Do you know of any quirks or anything? I'm also going to apply a Ceramic Coating, will there be a cure time that is going hinder me from that application?-The website claims the products to be fast drying.
- On Dr. Color Chip's website, their recommended process is backwards to what I was picturing - They recommend Polishing prior to applying the Touch Up Paint. I'll share the process I have been planning, I would love any input:
- After Wash and Decon, I plan on cleaning out the scratch with IPA, and then doing a very very light wetsand on the edges of the scratch to create a rough surface for the paint to stick to.
- Then I would apply the paint to fill the scratch and to mound up farther than the existing painted surface.
- Then once the paint is dry, I plan on going back and wetsanding/polishing as needed to create a flat surface and remove the mounding that I created. Also to remove any defects that may have been introduced throughout the process.
- Then following up with a Ceramic Coating.
I understand the only real answer to address this is to respray, but the owner and I both have the understanding that this is just in hope to make it look better than before. Just want to help him out.
Yo-Yo Ma's Cousin
Hello friends.
I'll update with the picture I have.
4 answers to this question
