BoomerSooner Posted April 3, 2020 Share Posted April 3, 2020 Good morning, I still have plenty of deep wheel cleaner that’s been stored in a temperature controlled environment. Is it still recommended to use a 1:1 ration for iron decontamination? New 2020 Ram 1500 in silver that I need to get looking right. Link to comment Share on other sites More sharing options...
0 Dan@Adams Posted April 3, 2020 Share Posted April 3, 2020 Hi Chris, yes I would recommend to dilute Deep Wheel Cleaner at least 1:1 for iron decontamination. Do not use it in direct sunlight, only decontaminate one panel at a time, and do not let the cleaner dry onto any surface - rinse very thoroughly! Link to comment Share on other sites More sharing options...
0 BoomerSooner Posted April 3, 2020 Author Share Posted April 3, 2020 10 minutes ago, Dan@Adams said: Hi Chris, yes I would recommend to dilute Deep Wheel Cleaner at least 1:1 for iron decontamination. Do not use it in direct sunlight, only decontaminate one panel at a time, and do not let the cleaner dry onto any surface - rinse very thoroughly! Thanks @Dan@Adams. I’ll make sure to do it one panel at a time and then rinse with the pressure washer. Is Iron Remover more forgiving? Link to comment Share on other sites More sharing options...
0 Dan@Adams Posted April 3, 2020 Share Posted April 3, 2020 1 minute ago, BoomerSooner said: Thanks @Dan@Adams. I’ll make sure to do it one panel at a time and then rinse with the pressure washer. Is Iron Remover more forgiving? Iron Remover is a more thin formula that spreads more evenly and works very effectively, but both chemicals are very strong, so you do need to exercise caution when using either 👍 Link to comment Share on other sites More sharing options...
0 falcaineer Posted April 4, 2020 Share Posted April 4, 2020 I'll also add Iron Remover smells WAAAAAAAAAAYYYYYYYYYYYYYYYYYYYYY better than the original Deep Wheel Cleaner. That pink stuff is 🤢🤢🤢😷😷😷 RayS 1 Link to comment Share on other sites More sharing options...
0 BoomerSooner Posted April 4, 2020 Author Share Posted April 4, 2020 1 hour ago, falcaineer said: I'll also add Iron Remover smells WAAAAAAAAAAYYYYYYYYYYYYYYYYYYYYY better than the original Deep Wheel Cleaner. That pink stuff is 🤢🤢🤢😷😷😷 Yeah it smells terrible, but I still have half a gallon 🤷🏻♂️. Link to comment Share on other sites More sharing options...
0 falcaineer Posted April 4, 2020 Share Posted April 4, 2020 10 hours ago, BoomerSooner said: Yeah it smells terrible, but I still have half a gallon 🤷🏻♂️. I get it. Power through. There's relief on the other side 😆 Link to comment Share on other sites More sharing options...
BoomerSooner
Good morning,
6 answers to this question
