I got a Chemical Guys Torx polisher for Christmas, and I'd like to get pads for it to apply glaze/sealant/wax.
Both Adam's and CG offer these pads, but I'm curious if you guys feel they can be used interchangeably? I currently have all Adam's Polishes products as far as glazes, sealants and waxes. Does anyone know if I'd be fine using Adam's products on a Chemical Guys pad, or vice versa? I'd like to use the CG pads, but I have a ton of Adam's products that I'd like to use, so what is my best way forward?
Would an Adam's pad attach to the Torx polisher just the same? Maybe I could just use the Adam's pads on the Torx polisher? If they both fit, realistically, can I expect much difference in how the two pads perform?
WMUCarGuy
Hi guys,
https://adamspolishes.com/collections/exterior-polishing-pads/products/adam-s-new-6-red-foam-glazing-pad
Moderator Edit: Per Group Rules, no direct-linking of competitor products. Thank you for understanding.
1 answer to this question
