First let me say a BIG thank you to everyone on this board for your help but a Special BIG thank you to Dan@Adams. He was able to help me behind the scene and gave me the extra confidence I needed to attempt this.
So I did it. After washing, claying, paint correcting, touch up paint,, then the ceramic process I am done. I will say this, When I first finished I was a little disappointed. When I was paint correcting I used too much compound and it exposed a lot of rock chips that were not as visible as before because of the white compound getting in there. No big deal a oft of those came out when I used the spray prep. The ceramic was not as hard to apply as I thought. It smells horrible though. I did it in my garage and it was very humid. Took about 3.5 minutes to be able to wipe it off. Once I was don, or so I thought, I pulled it outside. This was the best thing I did. I saw immediately all the spots I missed when removing. Some were easy to get off others were not. Took a long time to get it right. Not sure if I did it right but I would try and buff them off and if that didn't work I reapplied ceramic and wiped down after about 40 seconds to a minute. My initial thought was I wasn't going to like the end result. I was sure I messed it up in a lot of areas. I pulled it out this morning to apply the boost and was really happy with the result. all the areas that thought were going to be bad seemed to have disappeared. There are a few small areas that I will follow up with BG to address. The beading is amazing! I haven't touched it with water yet but while spraying the boost on it dripped right off the car. I had to spray the towel and then wipe for the boost to stay.
I would say the ceramic only part took me a little over 5 hours. The car looks amazing don't get me wrong, just not sure I would do this again. I will have to wait to see how long this last.
Some helpful tips and tricks that I learned:
I started with the roof and worked my way down. Found this helpful so I knew were I was going. I also used a stopwatch. I timed how long the roof took to cure to wipe then timed each other section accordingly. I figured if I messed up the roof who cares
The stop watch helped me a lot because after a minute I wanted to remove it because it felt like 3 minutes
Don't put ceramic on the pad while standing over the car.
A detail cart would have helped big time.
Get your bucket to sit on.
I used three applicator pads. Well really only 2 but I dropped one so I threw it away. I turned the applicator every section.
Best thing I did was move it into the sun after I was done to see where I missed.
Let me know your thoughts
Last two pics are after the ceramic was applied and was in the garage. First 5 are from after the 2 hours plus boost.
SS LeadFoot
19 answers to this question
