stay_tuned Posted July 14, 2020 Share Posted July 14, 2020 Hey all, so i just had my foam cannon (from the other “guys”) that’s only 3 months old crap out on me. wanted to know what you all recommend as a replacement that will actually last longer than 3 months and 20 uses? Link to comment Share on other sites More sharing options...
Rich Posted July 16, 2020 Share Posted July 16, 2020 I just have the foam gun, but it's worked fine for me for at least two years, maybe even 3. No complaints. Link to comment Share on other sites More sharing options...
BRZN Posted July 16, 2020 Share Posted July 16, 2020 I've got Adam's Standard Foam Cannon, which is just the Red Foam Cannon with black external plastic pieces. I've also got the Limited Edition Foam Cannon, and the MTM Hydro PF22.2 Foam Cannon. My go to is the Standard, or Red Foam Cannon. The key to longevity with a Foam Cannon is to run clear water, using the pressure washer, through the thing after every use to keep the internals clear of soap. The soap will dry inside plugging the thing up. Rich 1 Link to comment Share on other sites More sharing options...
stay_tuned Posted July 17, 2020 Author Share Posted July 17, 2020 i’m considering the mtm pf22.2 anyone first hand on longevity? i talked them into the sending me a replacement for the foam cannon that crapped out but i’d like to get something better Link to comment Share on other sites More sharing options...
Mike E. Posted July 17, 2020 Share Posted July 17, 2020 I had the Adam's Foam Cannon and had issues with it. I returned it and upgraded to the MTM PF22. Adam's had the PF22 in stock so it was an easy exchange. I've had great luck with the PF22. Use it multiple times a week. I've been using it for the last year. I just ordered the new PF22.2 bottle from Obsessed Garage as Adam's didn't have just the bottles available. I like the bigger base on the new bottle. Link to comment Share on other sites More sharing options...
BRZN Posted July 18, 2020 Share Posted July 18, 2020 On 7/16/2020 at 11:49 PM, stay_tuned said: i’m considering the mtm pf22.2 anyone first hand on longevity? As I put in the post just above yours: The key to longevity with a Foam Cannon is to run clear water, using the pressure washer, through the thing after every use to keep the internals clear of soap. The soap will dry inside plugging the thing up. The first Foam Cannon I had years ago stopped working properly. I disassembled it and found there to be a wad of course stainless Steel/Steel Wool inside, near the air flow dial. I'd not been rinsing this one out after use and it was clogged with dried soap. I soaked the wadding (once removed) in hot water and APC for several hours to clean the dried soap out, put it back together and it's still working fine today. I bought one of the MTM PF22.2 Foam Cannons when Adam released them a couple years ago, it's still working fine. Mike E. 1 Link to comment Share on other sites More sharing options...
ol 65 Posted March 11, 2021 Share Posted March 11, 2021 I have the premium foam cannon (35 oz) How much Mega Foam goes in the canister ? And do u add water or let the power washer pick it up. Link to comment Share on other sites More sharing options...
falcaineer Posted March 11, 2021 Share Posted March 11, 2021 8 hours ago, ol 65 said: I have the premium foam cannon (35 oz) How much Mega Foam goes in the canister ? And do u add water or let the power washer pick it up. 1-2 ounces is plenty. Add the water first, warm works best, and then the soap. ol 65 1 Link to comment Share on other sites More sharing options...
itsmejerry04 Posted June 7, 2021 Share Posted June 7, 2021 The whole idea behind the foam being applied to your car before the wash is that (allegedly) it can break up the bond between dirt and paint, and lead to a safer wash. Link to comment Share on other sites More sharing options...
